Old Thu, Dec-14-2017, 07:06:29 PM   #1
TheCoder
TheCoder's Avatar
Reputation: 0 TheCoder is on a distinguished road
Default Adjusting Diff backlash
Hey fellas,
Ive been experiencing the m clunk and i narrowed it down to the diff. i am certain it's the backlash. Ive been doing some Research and the process seems straight forward.
1. Remove output flangs
2. Remove diff cover
3. Remove the ring, carrier and shims
4. Remove the pinion
5. Replace the crush sleeve
6. Install and Preload the pinion gear to spec. Install new seal.
7. Install the ring gear and carrier, install shims as needed while measuring backlash
8. Verify ring runout and adjust shims as needed.
9. Verify breakaway torque of input flang
10. Install output flangs with seals
11. Install diff cover and seal.
Ill use an inch lb torque for preload verification and dial indicator.
1. Am i missing any critical steps here ?
2. Can i reuse my existing shims ? Do i need a new set?
Thanks
Sent from my SM-G935T using Tapatalk
2002 Titanium Silver BMW 325Ci SOLD
2003 Estoril Blue BMW M3
2003 Estoril Blue BMW M3 Journal
How to Import a car from Canada
Jump to top TheCoder is offline   Reply With Quote
Old Thu, Dec-14-2017, 07:08:48 PM   #2
Default Re: Adjusting Diff backlash (eliminate M clunk)
I would suspect there's a reason it's there.
It was there, from new, from the factory, in every e46 M3. BMW/M knows how to set backlash. Clunking does not fit in the BMW corporate image. If it could be eliminated by changing backlash without negative consequences, I'm fairly certain they would have done so.
Per wikipedia,
Reasons for the presence of backlash include allowing for lubrication, manufacturing errors, deflection under load, and thermal expansion.
lubrication and thermal expansion are both quite important to our diffs.
IMO don't **** with it.
Old Thu, Dec-14-2017, 07:18:00 PM   #3
TheCoder
TheCoder's Avatar
Per wikipedia,
I realize backlash is there for a reason. My backlash is out of spec though. I am not trying to eliminate it, I'm trying to reset it to spec.
Old Thu, Dec-14-2017, 07:25:40 PM   #4
Ah, sounds good!
Though it won't eliminate M clunk. That's a "feature" of the car.
Old Thu, Dec-14-2017, 07:30:07 PM   #5
cmstrilchuk
Reputation: 0 cmstrilchuk is on a distinguished road
CV, guibo and U-joints are good?
New driveshaft 'cured' my clunk.
06 ///M3 ZCP SMG FStreet
Jump to top cmstrilchuk is offline   Reply With Quote
Old Thu, Dec-14-2017, 07:43:15 PM   #6
TheCoder
TheCoder's Avatar
Cv and U joints are fine. Guibo needs replacement , but it is not the cause because i held the diffs input flang, turned the output and observed a clunk.
Old Thu, Dec-14-2017, 08:46:21 PM   #7
M3_Pilot
Hmm, I’ve never heard my car clunk before?
2004 Jet Black/Cinnamon 6MT
Old Thu, Dec-14-2017, 08:49:06 PM   #8
OneFastSicilian
Frankie
OneFastSicilian's Avatar
Italy
I have an 05, i purchased it from an older lady who bought the car because she wnted something fun to drive and never went over 5k rpms.. so she says.... but I dont have any clunks at all.. I think there's more to it.. i wouldn't mess with the backlash but if you're in there.. do some gears!
Previous:
  • 01 - AW/IR - Sold
  • 03.5 - IR/Impulse - Sold
  • 02 - TiAg/Blk - Sold
  • 05 - IB/Blk ZCP - Sold
  • 02 - LSB/Blk - Sold
  • 05 - SG/Blk - Current!
Check out my Journal!
*Instagram*
@E46m3_Owners_OTW
Jump to top OneFastSicilian is online now   Reply With Quote
Old Thu, Dec-14-2017, 09:22:10 PM   #9
Fhcrubarb
Fhcrubarb's Avatar
Reputation: 0 Fhcrubarb is on a distinguished road
How likely is it that our diffs completely fail and self destruct, especially during track conditions? My diff has been clunking and probably feels as yours does OP the feeling of slop in the diff (I just did vince bar, poly diff and subframe bushings etc. so everything is pretty well locked down). I'm contemplating having it rebuilt and or just leaving it. It's a track only car.
Jump to top Fhcrubarb is offline   Reply With Quote
Old Thu, Dec-14-2017, 10:57:58 PM   #10
MOTRSPRT
4CFEDM3
MOTRSPRT's Avatar
Reputation: 0 MOTRSPRT is on a distinguished road
The clunk in my car was HORRIBLE. My wife stopped driving it altogether. I relearned how to shift to avoid the clunk. I finally took it to my Indy shop to replace the rear diff bushings. Iíve already replaced the GUIBO and CSB when I installed adjustable camber arms. When my Indy shop got it in the air they found the bushings were in pristine shape but noticed the one bolt which goes
In from passenger side going across towards driver side had backed out. After they tightened it down 95% of the clunk went away.
Something to check I guess.
MOTRSPRT
2003 M3 SMG Imola Red--AP headers, SGT sec. 1 w/200 cell cats, AR20'resonators sec. 2, SGT SCZA muffler, K&N cai, Tein springs, 19" factory wheels
1998 M3/4 Dakar Yellow--supercharged
Jump to top MOTRSPRT is offline   Reply With Quote
Discussing Adjusting Diff backlash in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
