Old Sat, Sep-22-2018, 01:52:40 PM   #1
GrendelsbaneM3
GrendelsbaneM3's Avatar
Reputation: 0 GrendelsbaneM3 is on a distinguished road
Default Water Wetter vs Purple Ice
For people who are using additives in their coolant, what do you use use Purple Ice or Water Wetter? Anybody have any problems with them? I am reading where both will sometimes create a brown sludge or gunk. But people are swearing by it to help control their temps. At this point, I am looking at anything that will help me control my temps.
Forum does show a lot of older posts of folks using Water Wetter, but I did also read one guy saying steer clear.
Thanks!
2004 Silver M3 / SMG / TC Kline DA Coilovers / Eibach front and rear sway bars / Proflex bushings / Predator Orion V2 Multi-Color LED Angel Eyes / ALPS Jammers / Clear Bumper Reflectors / Zionsville Competition Cooling Kit with Offset Fan / AKG Motor mounts / Rogue Engineering Transmission Mount / AKG differential bushings / Euro mirrors / B&B Exhaust / CSL SMG tune /DME CSL tune / ESS 575 Supercharger / Stillen AP Racing BBK / J-Fiber Carbon Fiber Driveshaft
Jump to top GrendelsbaneM3 is offline   Reply With Quote
Old Sat, Sep-22-2018, 01:59:15 PM   #2
CommanderW
Reputation: 0 CommanderW is on a distinguished road
Default Re: Water Wetter vs Purple Ice
Always water wetter; I've seen my coolant go a little brownish but I do a basic flush pretty regularly (basic being just the lower rad hose and not the block drain). The water wetter really helps lower surface tension.
1000+RWHP, Lab22 Built Turbo S54 - BMW Half Mile Record Holder
Jump to top CommanderW is offline   Reply With Quote
Old Sat, Sep-22-2018, 03:26:11 PM   #3
Neither.
Old Sat, Sep-22-2018, 03:35:30 PM   #4
WOLFN8TR
/// MONEY \\\
WOLFN8TR's Avatar
Grew up riding dirt bikes everyone used water wetter in their bikes. I started using it in my M3 a few years ago and it does help. I would say it dropped the coolant temps by 8-10 degrees. I haven’t noticed any brown sludge. In hot desert climates every little bit helps.
Old Sat, Sep-22-2018, 03:44:15 PM   #5
Drewster
Drewster's Avatar
Neither.
Agreed. Iron blocks are just asking for corrosion - if you have cooling problems, repair/ upgrade your cooling system
Old Sat, Sep-22-2018, 03:46:56 PM   #6
GrendelsbaneM3
. I have noticed any brown sludge. In hot desert climates every little bit helps.
You HAVE noticed brown sludge?
Old Sat, Sep-22-2018, 03:51:27 PM   #7
GrendelsbaneM3
I think I am out of options or my wits end.
I am running
-ESS 575
-Zionsville radiator
-CSF oil coller
-New thermostat
-New Water pump
-Bled it dozens of times with no bubbles.
-No coolant/oil mix showing. Coolant level is not changing. So no headgaket leak
I am still getting a temperature creek under hard acceleration. It doesn't stay in the middle for my ride.
Old Sat, Sep-22-2018, 03:57:04 PM   #8
WOLFN8TR
/// MONEY \\\
WOLFN8TR's Avatar
Stupid spell check. “Haven’t” noticed brown sludge.
Old Sat, Sep-22-2018, 05:16:59 PM   #9
jared212
Reputation: 0 jared212 is on a distinguished road
Blown HG goes cylinder to cylinder so symptoms would be compression loss on 2 adjacent cylinders, 20%+ power loss, RPM dependant pre-ignition with a growing range as the passage gets bigger, and over heating.
Zionsville is just a stock core with aluminum end tanks welded on, so not a cooling upgrade but a theoretical reliability upgrade. I would suggest Koyo for increased capacity if there isn't another underlying problem. Might even net a few dollars to swap. I know people who are N/A track rats prefer airflow to capacity but with over 500hp more capacity is worth something.
I run 25% bmw coolant, purple ice and the rest is spring water for something like 10 years now and the 3 times I have opened it up the mix looked just like it did when I put it in there.
Although it doesn't sound like the culprit, what is your fan situation?
'04 SGM/Blk|SMG|AA/FS Prima Elite kit|Hacksaw built engine w/ JE/Molnar/Supertech/ARP/lots of ceramic TBC|ID1050x injectors|Radium rail+FPD-XR|Aeromotive FPR|-6an fuel system walbro 450 e85|RMS headers|Magnaflow custom 2.5" sec1|Besian|Redish|ZCP springs/Koni's|Hotchkis front sway bar+deleted rear|Turner Pulleys|Southbend stg 3 DD clutch|Innovate/Spek gauges|relocated SMG|Mishi OCC|Koyo Radiator|CSF oil cooler|basically stock interior and exterior
Jump to top jared212 is offline   Reply With Quote
Old Sat, Sep-22-2018, 05:26:22 PM   #10
GrendelsbaneM3
Fan is built into the Zionsville shroud. It is a 16' SPAL. If you are talking about the AC fan its just the stock one, but I have tested it and it is running correctly.
Discussing Water Wetter vs Purple Ice in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
