Old Sat, Sep-22-2018, 01:52:33 AM   #1
Carbuilder723
Reputation: 0 Carbuilder723 is on a distinguished road
Default S54 standalone options
Hey everyone. So I'm interested in putting an S54 into a Datsun 260z and I want to know what my options may be for running this thing on a standalone DME. It will have a manual transmission so no SMG integration is needed.
Ideally I'd like to just have an alpha-N tuned MSS54 running everything but I don't know if that's possible or if I need to go to something like an AEM infinity. I already have the factory BMW engine harness that I want to use also.
Let meet know your experience or suggestions.
Thanks!
Sent from my Pixel 2 XL using Tapatalk
Jump to top Carbuilder723 is offline   Reply With Quote
Old Sat, Sep-22-2018, 01:58:55 AM   #2
rbmwiv
rbmwiv's Avatar
Reputation: 0 rbmwiv is on a distinguished road
Default Re: S54 standalone options
You know that you can have the factory dme reprogrammed and use in in your transplant car. Thatís what we do on every motor conversion. The hardest part will be putting in the drive by wire gas pedal. They can program out any emissions and ews etc. anything factory youíre not running. That would be the best and cheapest way to do it. You can do alpha-n on any s54 dme. You just program the alpha n add a map sensor and temp sensor and your ready to go.
Hope this helps.
Jump to top rbmwiv is offline   Reply With Quote
Old Sat, Sep-22-2018, 02:02:20 AM   #3
Arehman
Arehman's Avatar
Reputation: 0 Arehman is on a distinguished road
Pakistan
PRO EFI, or MOTEC seem to be the leaders now days for standalone.
2002 AW/IR 6spd coupe
Jump to top Arehman is offline   Reply With Quote
Old Sat, Sep-22-2018, 03:08:24 AM   #4
WALKD_U
WALKD_U's Avatar
No to pro EFI....
2005 AW/IR M3
BMB Stage 4
940whp/765wtq SAE Corrected
2005 JB/BLK 330i ZHP
NA Bolt-ons
207whp/216wtq SAE Corrected
1996 BLU/BLK M3
NA Bolt-ons
235whp/225wtq SAE Corrected
1988 SETA 325I
NA Bolt-ons
165whp/160wtq SAE Corrected
Instagram
M3HNGRY
Old Sat, Sep-22-2018, 03:13:48 AM   #5
STAATS
STAATS's Avatar
Turner Motorsport has that Bosch unit that you can use with the stock harness but it deletes cruise control etc but I think you can also transfer to a standard non-DBW throttle with it...
STAATS
Old Sat, Sep-22-2018, 04:00:14 AM   #6
Cronenberged
Cronenberged's Avatar
Reputation: 0 Cronenberged is on a distinguished road
Life Racing over the Motec if you want to save money.
Formerly known as ///M3_Letty
Jump to top Cronenberged is offline   Reply With Quote
Old Sat, Sep-22-2018, 05:36:29 AM   #7
Speed Monkey
Bananas, Just Bananas
Speed Monkey's Avatar
Hmmm, a S54 in a Z, sounds cool... Why not just buy a late MY M Cabrio/Coupe with a S54 in it? On a related matter, I got an e-ticket ride in a S52 M Cabrio fitted with all the Dinan goodies and let me tell you, boy howdy, I've never ridden in a sled that launched as hard as that little sled, outside of a rod fitted with a 383 topped with flowed heads, high lift bump stick, 4.11s and Mickey Thompson cheater slicks.
Jump to top Speed Monkey is offline   Reply With Quote
Old Sat, Sep-22-2018, 08:13:06 AM   #8
M3_#67
Reputation: 0 M3_#67 is on a distinguished road
Not an E46 M3 but Pro EFI is what a good friend of mine used for his boosted KA20 240SX which he also converted to throttle by wire. No complaints.
'02 Imola Red on Black
Jump to top M3_#67 is offline   Reply With Quote
Old Sat, Sep-22-2018, 10:49:38 AM   #9
HassanEido
HassanEido's Avatar
Lebanon
stock DME works fine, u'll need the e46 dash and throttle pedal
Mods:
-Custom CF airbox
-Cat Cams 280 272.
-Custom dyno tune
368.4 whp 289.1 wtq
Old Sat, Sep-22-2018, 10:52:21 AM   #10
Super easy to run the OE MSS54 as a standalone these days, and MUCH cheaper than any standalone. That's 100% the route I'd go.
Discussing S54 standalone options in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
