Old Wed, Sep-19-2018, 11:02:44 PM   #11
bigjae1976
Default Re: Mysterious ticking then knocking - after all maint done!
Spit.. As in a valve shim(or more) popped from its place .
Thx!
2013 F30 328i - Melbourne Red
2004 E46 M3 - Imola Red
Old Wed, Sep-19-2018, 11:46:21 PM   #12
Speed Monkey
Bananas, Just Bananas
Speed Monkey's Avatar
How many miles on all the pulley/idler wheels up front? If you can sticke your arm down there, determine if there is any wobble in the bearing. While you're in there, grab the WP pulley for wobble also. Amongst the least expensive items to start knocking, the pulleys are it; I hope it's not in your valvetrain... Happy hunting.
Jump to top Speed Monkey is offline   Reply With Quote
Old Wed, Sep-19-2018, 11:54:53 PM   #13
Ottereffect
Reputation: 0 Ottereffect is on a distinguished road
Thanks I hope so too! Water pump, belts and tensioners were all done in the last 5K. I though that it could be the alternator however I donít think pulleys would account for the ticking.
Jump to top Ottereffect is offline   Reply With Quote
Old Mon, Sep-24-2018, 09:16:12 PM   #14
Ottereffect
Finally had time today to pull the valve cover and take a look.
Everything was perfect. All valves were within spec and no broken or spit shims.
All coil packs were seated properly with no burn or char marks. Also inspected the cylinders with a Borescope. Everything looked good with no sign of metal on metal impact between the cylinder and the valves.
There was what appeared to be a tiny metal flake/spec on cylinder 2. Dead center (Iíll try and get a picture). I thought maybe it was contacting the spark plug? But the spark plug was in perfect condition.
I will be preforming a leakdown and compression test and hopefully have another update by tomorrow
Old Tue, Sep-25-2018, 01:16:36 AM   #15
Ottereffect
I should mention too that there is 0 sign of metal shavings in the oil filter.
Here is another video from when the car was making the noise.
Old Tue, Sep-25-2018, 04:57:19 AM   #16
HassanEido
HassanEido's Avatar
Lebanon
https://youtu.be/7gWxvOOjTBU
Oh man that sounds different than before. It still sounds too fast for a rod bearing.. and has about the same tone as a spit shim tbh. Are u sure u pulled all 24 followers and verified there are shims?
When my car spit one, I could hear it was at cyl 5 and promptly found a missing shim there, and thankfully the shim too.
If u can't find any and are sure. I'd think it's bearing, no much else knocks on this engine , but I'm still doubtful at this point
Mods:
-Custom CF airbox
-Cat Cams 280 272.
-Custom dyno tune
368.4 whp 289.1 wtq
Old Tue, Sep-25-2018, 05:32:24 AM   #17
Ottereffect
Iím doubtful too. I would think that if it was a bearing it would sound like that all the time. The car only made those noise once and never again. Iím didnít pull each follower, but I measure ever valve. Wouldnít a valve be out of spec if it was missing a shim?
Old Tue, Sep-25-2018, 09:44:18 AM   #18
L0ADED
L0ADED's Avatar
I’m doubtful too. I would think that if it was a bearing it would sound like that all the time. The car only made those noise once and never again. I’m didn’t pull each follower, but I measure ever valve. Wouldn’t a valve be out of spec if it was missing a shim?
It would.
The sound is very similar to these two videos -
https://www.youtube.com/watch?time_c...&v=goDPL26X0x8
Both had a worn cam follower and camshaft. Could be premature wear or a flat spot on one of the new cam followers (rocker arms).
Old Tue, Sep-25-2018, 01:28:55 PM   #19
HassanEido
HassanEido's Avatar
Lebanon
Originally Posted by L0ADED View Post
It would.
M3 E46 S54 engine knocking [SOLVED] - YouTube
agree, pull them out and inspect one by one
Mods:
-Custom CF airbox
-Cat Cams 280 272.
-Custom dyno tune
368.4 whp 289.1 wtq
Old Tue, Sep-25-2018, 04:31:31 PM   #20
Ottereffect
Okay, thanks for the help guys. Iíll see what I can do today.
It would some seriously pre mature wear - the cams only have a few thousand miles on them. The weird thing too is that it only sounded like that for a minute or two. Every start since has sounded normal.
Discussing Mysterious ticking then knocking - after all maint done! in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
