Old Wed, Sep-08-2010, 07:23:17 PM   #1
Jaycent@Mpact
top down, wind deflector up :)
Jaycent@Mpact's Avatar
Reputation: 0 Jaycent@Mpact is on a distinguished road
Default looking for post with OEM 19s rear wheels installed on the front
I am looking for pictures of a E46 M3 with rear wheels installed on the front. I have seen a posting with this before...but can't find it when I searched again. Com someone point me in the right direction. Thanks!
Jump to top Jaycent@Mpact is offline   Reply With Quote
Old Wed, Sep-08-2010, 08:59:24 PM   #2
phoenx
Always cruising
Reputation: 0 phoenx is on a distinguished road
06' M3, 16' M3
Jump to top phoenx is offline   Reply With Quote
Old Wed, Sep-08-2010, 09:40:07 PM   #3
Touring
E46Fanatics
Touring's Avatar
Reputation: 0 Touring is on a distinguished road
Puerto Rico
Looks good!
In the Ft. Bragg area come on by for a detail or
A valve adjustment
My alcantara ZCP is for sale.
Jump to top Touring is offline   Reply With Quote
Old Wed, Sep-08-2010, 09:43:28 PM   #4
theBeachBoy
Reputation: 0 theBeachBoy is on a distinguished road
looks very good!!! + square setup!
Jump to top theBeachBoy is offline   Reply With Quote
Old Thu, Sep-09-2010, 01:37:54 AM   #5
Str8Down
Reputation: 0 Str8Down is on a distinguished road
Looks very good, but looks like it would rub badly.
94 Black RX-7 TT heavily modded
02 PY/Black M3 6MT
Jump to top Str8Down is offline   Reply With Quote
Old Thu, Sep-09-2010, 06:40:07 AM   #6
l djayr l
Reputation: 0 l djayr l is on a distinguished road
looks sick. hows fitment?
Jump to top l djayr l is offline   Reply With Quote
Old Thu, Sep-09-2010, 09:38:54 AM   #7
kaiv
SoCal S54 specialist :P
kaiv's Avatar
France
OP: What you are looking for is called a square setup. Square because you are running the same size wheel on all 4 corners.
Also, when speaking of OEM square setups it is understood that you are speaking of 4 rear wheels.
It doesn't. I ran OEM18 , lowered, with 275 tires all around and didn't rub.
E46 ///M325i Touring journal
Old Fri, Sep-10-2010, 07:07:12 PM   #8
donnatronious
Reputation: 0 donnatronious is on a distinguished road
Running a 9.5 inch 27 offset wheel on the front with 275 tire is cutting it very close. The ideal is around 37 or 38 ET. I believe this is the most you can move a 9.5 inch wheel inside without hitting the strut. I'm running 33 ET with 2.4 camber and I don't have rubbing. If my wheel were available in 37, I'd be running that.
2003 Tiag/Red 3 pedals - Under Construction
2007 S2000 Grand Prix White on Black/Red Interior - KW V3 - Direzza Star Specs 225/45ZR17, 255/40ZR17 - T1R Forged Halfshaft Spacers - CR interior bits
Jump to top donnatronious is offline   Reply With Quote
19s, front, installed, oem, post, rear, wheels
Discussing looking for post with OEM 19s rear wheels installed on the front in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
