Old Fri, Dec-02-2005, 02:51:16 PM   #1
Hit_Apex
Riding the knock sensor
Hit_Apex's Avatar
Reputation: 0 Hit_Apex is on a distinguished road
Default CSL Bumper - Add Brake Cooling?
I'm thinking about buying another lower grille to play with. I'd cut in two black port tubes (like 3" dia.) and route them to the brakes. My question is for those who have done this, is it worth it? Many threads talk about losing the brake ducts on a ZCP not being a big loss. Something like this except I would want more discrete - not silver. The existing CSL intake hole is already plumbed for only the airbox.
| Platte Forme A.G. Aero | JRZ RS Pro | SS Stepped | Borla | Epic Tune | aFe | Apex ARC-8 | Stoptech | Recaro HANS | Kirk | Schroth |
Jump to top Hit_Apex is offline   Reply With Quote
Old Fri, Dec-02-2005, 04:40:10 PM   #2
E92 FTL
HENNAROT FTW!!!
Reputation: 0 E92 FTL is on a distinguished road
I think I read that Fern routed cooling lines from his CSL bumper with a piece of Y tubing.
Jump to top E92 FTL is offline   Reply With Quote
Old Fri, Dec-02-2005, 04:46:58 PM   #3
AudiOn19s
AudiOn19s's Avatar
Reputation: 0 AudiOn19s is on a distinguished road
The RRT and Bimmerworld cooling kits actually route the hoses into the belly pan towards the center of the car and then up and around to the stock ducts. I'd assume that as long as there is an opening behind the grill that you can route the hoses that it might even bet a better option using the center rather than the stock location.
Andy
'99 A4
'02 M3
'04 GT3
'04 E55
'99 996 Aero - Sold and badly missed
Jump to top AudiOn19s is offline   Reply With Quote
Old Fri, Dec-02-2005, 05:22:56 PM   #4
Hit_Apex
Hit_Apex's Avatar
From the lower center grill? Keep in mind the big hole on the right goes straight to my airbox - I don't want to tap anything else into it.
I'll look at the kits that route through the underpanel.
Old Fri, Dec-02-2005, 05:27:11 PM   #5
E92 FTL
HENNAROT FTW!!!
Nope. I'm almost positive he tapped into the single hole on the drivers side.
Old Fri, Dec-02-2005, 05:54:02 PM   #6
Army Chief
Moderator (Currently Inactive)
Army Chief's Avatar
Reputation: 0 Army Chief is on a distinguished road
Nick recently had some great advice regarding ducting (to the brakes), and it didn't involve the front bumper skirt. Instead, he proposed using the undertray as a more effective pick up point for forced air.
As you've correctly established, the single intake on the CSL is designed to feed the airbox, and not the brakes. Even on a standard M3, those lower skirt ducting ports really do little more than increase positive airflow behind the wheels. This helps, of course, but does not truly solve the problem one seeks to address with proper brake ducting.
I'd continue on with the ducting idea, but seek to rig it in a way that doesn't involve the front bumper skirt. There are a number of DIY leads out there related to this -- I think I even have a few posted on www.m3resource.com.
Chief
Jump to top Army Chief is offline   Reply With Quote
Old Fri, Dec-02-2005, 06:42:37 PM   #7
apexapex
Reputation: 0 apexapex is on a distinguished road
Japan
I remembered that on my evo, the holes in the sides were for intake (on the right) and cooling the oil cooler (on the left) and the undertray was designed very well on where the air flows and keeping it from lifting also. There were pathways under that directed air directly to the brakes no matter which degree the wheels were turned. I haven't gone under my m3 yet but if thats how it is also for the m3, I'm sure the regular ones on the regular bumper won't be as big of a loss.
S54 E36 Build
Jump to top apexapex is offline   Reply With Quote
Old Thu, Mar-23-2006, 11:49:43 PM   #8
///Icaris
IcarisInnovations.com
///Icaris's Avatar
Reputation: 0 ///Icaris is on a distinguished road
Anyone have an idea what rims are on the M on the top that has the tornado grill....i know its sounds crazy since there is almost no way to tell but incase anyone know the car.
Jump to top ///Icaris is offline   Reply With Quote
Old Fri, Mar-24-2006, 12:35:16 AM   #9
C5L
Reputation: 0 C5L is on a distinguished road
They are BBS Race Track LM's.
PS brake cooling, i know a CSL which runs modified Porsche GT3 RS braking ducts underneath !
Jump to top C5L is offline   Reply With Quote
Old Fri, Mar-24-2006, 02:16:58 AM   #10
jotti
///M so sexy
jotti's Avatar
Reputation: 0 jotti has disabled reputation
I started a thread a while back maybe 2 months ago for this exact thing. I had links/pics/prices on that grill as well as where you could get it from. There were some good posts in that thread, might want to dig it up.
jotti - E46 ///M3
Jump to top jotti is offline   Reply With Quote
Brake cooling for CSL Bumper Hit_Apex M3 Track: Racing and DE 49 Mon, Jan-12-2009 06:51:37 PM
CSL front bumper and Brake cooling? Is it an issue? jotti E46 M3 (2001-2006) 9 Fri, Sep-16-2005 10:34:01 PM
Brake cooling with CSL front bumper? STALKER E46 M3 (2001-2006) 29 Thu, Jul-14-2005 04:47:45 PM
CSL Bumper question - Brake cooling? Mo_Gs E46 M3 (2001-2006) 6 Tue, May-17-2005 09:14:43 AM
Is brake cooling negatively affected by CSL front Nixlimited E46 M3 (2001-2006) 20 Fri, Apr-22-2005 04:45:19 AM
Discussing CSL Bumper - Add Brake Cooling? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
