Old Tue, Nov-13-2018, 01:48:31 AM   #1
wichonewichone
Reputation: 0 wichonewichone is on a distinguished road
Default Eml woes
Can someone peer review my thinking?
So Iím throwing an eml light while driving randomly. May come on 20 minutes into a drive or 5 minutes. Never stays through a key cycle but always seems to come back on after a little driving.
Limp mode only ever kicks in if Iím very aggressively driving, or hitting the limiter (on accident)
So, onto diagnostics; using inpa, I can see that code 118 (tps #1) was thrown 4 times, 119 (tps #2) was thrown once, 120, 121, 230 all thrown once as well.
So since 118 was thrown the most frequently is it safe to assume thatís the origin of the other three codes and therefore my tps #1 is to blame? Is this a correct way of diagnosing or is frequency number not a function of error origination?
I know I can just replace my front TPS to find out if thatís my issue. Not really asking someone to solve my issue but more to tell me if the sensor that has the highest error frequency is most likely to blame for the other codes
Jump to top wichonewichone is offline   Reply With Quote
Old Tue, Nov-13-2018, 04:00:41 AM   #2
mrgizmo04
mrgizmo04's Avatar
Default Re: Eml woes
Prob safe to say tps1 gotta be replaced.
'85 528e 164k miles (sold)
'05 M3 6MT coupe
Old Tue, Nov-13-2018, 04:22:45 AM   #3
Pbj24
Pbj24's Avatar
Reputation: 0 Pbj24 is on a distinguished road
Yes start with the one by the oil filter housing. Use a genuine bmw sensor.
Jump to top Pbj24 is offline   Reply With Quote
Old Tue, Nov-13-2018, 04:14:48 PM   #4
wichonewichone
So loctite is a useful tool when replacing low torque tps bolts... mine had wiggled loose and on WOT or bumps it would shake and become out of sync with the system.
Discussing Eml woes in the Faults, Fixes and DIY Forum - Please share your experience and knowledge with other members by contributing your own DIY, or by helping another member find the elusive fix! at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
