Old Wed, Oct-31-2018, 01:25:50 AM   #1
lore2486
lore2486's Avatar
Reputation: 0 lore2486 is on a distinguished road
Default any way to disable adaptations
Ms54 gurus this is my situation
I installed one of the American racing headers a few days ago and while the car sounds great and ran ok for a little while, its all messed up now. Basically I decided to erase adaptations since I installed new pre cat o2 sensors and given that the all 6 cyl are in the same stream the car is having problems adapting.
bank 1 would add gas and bank 2 would remove it and given enough time this causes bank 2 to run lean and misfire which is then solved by reseting adaptations again. So im thinking if there is a way to copy adaptation values from bank 1 to bank 2 (mirror them) or simply lock the whole adaptation part of the software. if there is no way to do this via software I might have to use o2 sims for both banks and just make sure that the tune is correctly set with a wide band.
Thanks
Jump to top lore2486 is offline   Reply With Quote
Old Wed, Oct-31-2018, 01:51:00 AM   #2
lore2486
lore2486's Avatar
Default Re: any way to disable adaptations
and just like that I found my answer, Thanks
http://www.m3forum.net/m3forum/showthread.php?t=458141
Discussing any way to disable adaptations in the Coding and Tuning Forum - Discuss all avenues of coding and tuning here! at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
