Old Sun, Sep-23-2018, 01:48:21 PM   #121
e36 323ti
e36 323ti's Avatar
Reputation: 0 e36 323ti is on a distinguished road
Norway
Default Re: Visualization of CAN data related to the e46 M3
Originally Posted by Turb02 View Post
Guess we'll never know. Seems to be him just showing off his :dunno
Sent from my Pixel using Tapatalk
I'm not sure how to respond on this. This thread is indeed a development blog...
A bit hard to respond to when will "this" be available, since there is no such thing as "this". With so many options and configurations the system is tailor made to each configuration. What is your preferred configuration?
In post 64 I said:
Have received so many requests about price etc...
This project started for fun, without any intentions to sell anything. Based on the feedback and questions, I realize that there exists other enthusiasts which would appreciate similar solutions in their cars. Being a developer both by profession and mind, I'm not convinced that taking this project to a product, involving customer service, installation issues, support etc. etc. is a vice step to take. However, as an attempt to clear my mind and (hopefully) make it clear what to offer, I have made a draft of a Web shop with product description and prices.
With so many options and configurations, it is too hard to answer the general question: "What is the price?" For those interested, please have a look at the Web shop to get a feeling. There is even a coupon code for m3f enthusiasts (coupon code m3f gives 10% discount). Link: airventdisplay.no
Maybe, in a not too distant future, I'll take the full step and open the Web shop, if the interest is still there. Still some development and test remaining. Enjoy...
In post 75 I said:
Thanks for the positive feedback. Plan to have ready some units within Spring 2018, at least the basic version + all options except brake rotor temperatures. The next in-car tests will be focused on the oil pressure and direct reading of the brake pressure sensors on the MK60. Then the temperature in the diff and the gear box temperature.
However, life is life, and due to issues not controlled by me, I had to focus elsewhere. Within Spring 2018 I had units available, but only for my own cars. The in-car tests of the temperatures in the gear box and diff is finalized, but the direct reading of the oil pressure and brake pressures is not. Seems to be quite a job to install the oil pressure sensor and hook up to the MK60 brake pressure sensors. Will test it during winter time though.
Since I would like to do it as perfect as I can, I had to do several iterations of the bezel. The true in-car installation revealed some annoying reflections in the screen from the rear window, and I had to do several time consuming iterations to get it perfect.
Further, the installation has not been plug and play. However, I have managed to get OEM sockets and socket housings such that the installation of the Basic configuration should be plug and play.
I am not going to promise anything, other than it is likely that some configurations will show up in a few cars within Spring 2019.
But you should be warned: Installation of such a system, even in the Basic configuration, can be costly beyond the cost of the system itself...
  • The installation in my car revealed an engine temperature issue, so I ended up replacing the radiator. It was quite easy to see that the radiator outlet temperature was too high. Better now.
  • After last oil change I saw higher oil temperatures, and changed the oil again, but to another brand. Did also realize that my oil cooler was very dirty and clogged, and I tried to clean it. Will probably replace it.
  • The diff temperature readings I'm sure will result in more frequent changes of diff oil, since the e46 m3 diff goes very hot. Have not tested at track yet, but I expect to see temperatures above 130'C...
Jump to top e36 323ti is offline   Reply With Quote
Old Sun, Sep-30-2018, 09:11:07 PM   #122
e36 323ti
e36 323ti's Avatar
Norway
airVent Display: Have added an IBus-interface to my KBUS2CAN hw. This opens up for requesting OBC data from the IKE over the IBus.
Will probably add an OBC page in the airVent Display containing fuel info, ambient temp, average speed, distance, fuel range, vMax, gMax (accelleration), average engine temp and average oil temp as well as current oil and engine temp. A first draft...
Those interested in how to request OBC data from the IKE over the IBus will find all they need in the python code in the following link: https://shared.kluczek.net/ibus.py
Old Mon, Oct-08-2018, 09:21:34 PM   #123
eacmen
Originally Posted by e36 323ti View Post
I imagine that the CAN info sent from the MK20 follows the same format as the CAN info sent from the MK60. The other modules are the same w.r.t CAN as far as I know. If that is the case, it should work in a non-MK60 M3 as well.
I have been trying to figure out the CAN messages from the MK20. Have you made any progress on this?
Jump to top eacmen is offline   Reply With Quote
Old Tue, Oct-09-2018, 05:28:18 PM   #124
e36 323ti
e36 323ti's Avatar
Norway
No, I have not looked into that.
Old Sat, Oct-27-2018, 11:04:39 PM   #125
e36 323ti
e36 323ti's Avatar
Norway
Plyaing with some of the components necessary for streaming, storing and do visualization of the CAN data. On the server side it seems like the NanoPC-T4 running 64bit Linux with 500GB PCIex4 SSD, MonetDB database system, Flask web server and JSONP can do the job. On the client side I am aiming for a pure Javascript solution. A bit tricky to combine async/await, web workers, an inMemoryDatabase and JSONP, but converged to a well performing solution (steep learning curve in JS). Still a long way to go...
Old Fri, Nov-09-2018, 09:14:28 PM   #126
e36 323ti
e36 323ti's Avatar
Norway
Replaced the development Flask web-server with an nginx server and uwsgi. Great performance.
Attached a gps to the RPi in the car that streams the CAN data to the database system. By utilizing the gps data, it seems like an easy task to add map overlays in the web page visualizing the live data.
Old Sun, Nov-18-2018, 05:59:13 PM   #127
e36 323ti
e36 323ti's Avatar
Norway
Spent a few evenings looking into what it takes to stream the CAN data to HLT. Since I am going to use a RPi3 to stream the CAN data to a private server, and since the RPi3 already have a BLE interface, I added the possibility to stream the CAN data to HLT from the RPi. Seems like a solution that can be used...
Old Thu, Nov-29-2018, 09:02:32 PM   #128
e36 323ti
e36 323ti's Avatar
Norway
A teaser from my dev blog regarding streaming data to Harry's Lap Timer:
Having installed the airVent Display with a KBUS2CAN device, an OBDII reader is simply out of the question, since the KBUS2CAN occupies the bus that the OBDII reader needs. The challenge was then how to feed Harry's Lap Timer with "OBD" data?
The airVent Display "eco system" utilizes a RPi3 for streaming CAN data to a database server, and since the RPi3 comes equipped with Bluetooth LE out of the box, why not use it?
... software has been developed on the RPi3 such that all the necessary CAN data is streamed to Harry's Lap Timer via Bluetooth LE. They are not only streamed, but streamed to a rate that outperforms most OBDII Bluetooth devices.
If someone are interested, then more to read here: http://www.airventdisplay.no/en/blog...ry-s-lap-timer
Discussing Visualization of CAN data related to the e46 M3 in the Coding and Tuning Forum - Discuss all avenues of coding and tuning here! at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
