Old Thu, Mar-03-2005, 09:40:00 AM   #21
bvnmspt
bvnmspt's Avatar
Reputation: 0 bvnmspt is on a distinguished road
Originally Posted by Doctor Love
Does the wire bundle from the headlight switch go through the firewall? If so, couldn't you just wire the halos to the same wire on the other side instead?
No, the 12V parking light wire from the bundle doesn't go through the firewall. The headlight, high-beam, fog lamps, blinkers, and 6V parking light wire go through the firewall.
Dream as if you'll live forever. Live as if you'll die today.
Jump to top bvnmspt is offline   Reply With Quote
Old Thu, Mar-03-2005, 04:33:40 PM   #22
Doctor Love
Doctor Love's Avatar
Reputation: 0 Doctor Love is on a distinguished road
So if I understand you correctly, you connect the halos to the switch in lieu of the parking lights themselves instead of in addition to? Otherwise if they are both connected your parking lights and the halos would be on at the same time and look rather silly, no?
Jump to top Doctor Love is offline   Reply With Quote
Old Thu, Mar-03-2005, 05:18:28 PM   #23
bvnmspt
bvnmspt's Avatar
I'm not sure what you mean by "both," but the wire from the switch is the parking light wire. The Light Control Module distributes power to all of the lighting in the car. The light switch (LCM) is a convenient location to tap into vs. wiring a connection to the rear of the car. To Clarify, there is only one tap into the wire coming from the switch, which is the same thing as the parking light wire.
Old Thu, Mar-03-2005, 06:10:47 PM   #24
Doctor Love
Let me try to clarify my question - when you turn your headlight switch the the parking light position, do both the halos AND the parking lights come on? Or have you disconnected the parking lights from the box altogether?
Old Thu, Mar-03-2005, 06:21:07 PM   #25
bvnmspt
bvnmspt's Avatar
The parking light and the halos turn on at the same time. If I turn off the parking light, the halos turn off along with it. I did not disconnect the parking light at all. The trigger wire for the relay simply splices into the parking wire.
Old Thu, Mar-03-2005, 06:24:48 PM   #26
Doctor Love
Gotcha, thanks for clarifying
One more question, do you drive around with your parking lights on??
Old Thu, Mar-03-2005, 07:21:46 PM   #27
bvnmspt
bvnmspt's Avatar
I don't drive with my parking lights on during the day-time. I leave my light switch on auto. This will turn on my halos with the headlights automatically. If I want people to see all my lighting (6000k headlights and 6000k fogs), I press my fog switch and that turns on all my lighting provided that my switch is set to auto.
Did you buy your halos yet? You might want to check this out...
http://www.m3forum.net/m3forum/showthread.php?t=58821
Old Thu, Mar-03-2005, 10:36:25 PM   #28
dawgbone
Reputation: 0 dawgbone is on a distinguished road
You could do a real DYI and break the cold cathode out of a cold cathode lit PC fan...It's the same thing..you just have to find the bigger of the fans, not the 80mm one...That way you can pick whatever color you want...This one even has a little brother, that you might could find a home for :nixweiss: ..http://www.pccasegear.com/prod1901.htm
Jump to top dawgbone is offline   Reply With Quote
Old Fri, Mar-04-2005, 11:18:02 PM   #29
Quick M3
Quick M3's Avatar
Reputation: 0 Quick M3 has disabled reputation
Well there goes my plans! My instructions say to remove the parking light bulb and connect the wire to the positive side.
I guess I will run them with the driving lights.
08 E63 AMG
03 20th GTI
Jump to top Quick M3 is offline   Reply With Quote
Old Sat, Mar-05-2005, 01:40:33 AM   #30
dawgbone
Noooo..that sounds ghetto..I hooked mine up to a red/white striped wire with yellow dots in the junction box on the drivers side of the car using a t-tap..It turns the Halos on anytime the running(daytime) lights are lit..It'll also stay on over 10 sec after shutting down the car..looks awesome when you walk away..you can even hit the high beams after shutting down to light them up as the walk away feature...Trust me...You can then go to the dealership and have them program the running lights off, that way during daytime..all that is lit is your halos..which are usually bright enough to be running lights...at least Phosphyre's are...looks nice
diy, halos, parking light, wiring
""""""""1st Mini M3 Meeting in Qatar"""""""""" Silver///M Member Photos and Videos 34 Mon, Dec-25-2006 06:57:32 AM
Best Parking light Delete DIY? murdock_ E46 M3 (2001-2006) 5 Wed, Nov-29-2006 07:16:36 PM
DDE wiring to parking light.......finally got it to work!!!! (kinda long) jfabes Faults, Fixes and DIY 2 Wed, Aug-23-2006 08:26:15 AM
DIY: Now you can have "Titanium WP Halos"....Cost $2 Grimm333 Faults, Fixes and DIY 38 Thu, Aug-04-2005 07:22:15 AM
""NEW"" CLR Halos For E46s ** take a look ** Jeff@Fusion Parts for Sale/Wanted 80 Tue, Jun-22-2004 03:26:45 PM
Discussing DIY: Wiring Halos to "Parking Light" in the Faults, Fixes and DIY Forum - Please share your experience and knowledge with other members by contributing your own DIY, or by helping another member find the elusive fix! at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
