Old Sat, Aug-20-2016, 11:31:27 PM   #1
TudiM3
TudiM3's Avatar
Reputation: 0 TudiM3 is on a distinguished road
Default MSS54 Final drive changed to 4.45->limp mode.Please HELP!
Hi,
I searched for this but without succes.
I changed my rear differential to 4.45.
Now my SMG switched to limp mode and cannot switch gears.
DME in limp mode too and I cannot push full throttle.
Is there any solution to re-calculate gear ratios per gear or any other solution?
Thank You!
http://www.youtube.com/watch?v=w8cLyrNQX6A <- My E30 Touring with E46 M3 engine
Jump to top TudiM3 is offline   Reply With Quote
Old Sun, Aug-21-2016, 07:35:29 AM   #2
MartynT
MartynT's Avatar
United Kingdom
Default Re: MSS54 Final drive changed to 4.45->limp mode.Please HELP!
Hi buddy,
Unfortunately you can't compensate for 4.45, 4.25 is the greatest final drive value the DME will accept so that's probably why you have the issue.
Flash back to your original read and the car should be happy for now or flash a modified original with the valve changed for 4.25 gears.
Jump to top MartynT is offline   Reply With Quote
Old Sun, Aug-21-2016, 11:41:29 AM   #3
TudiM3
TudiM3's Avatar
Originally Posted by MartynT View Post
Hi buddy,
Hi,
Thanks!
But i do not flash nothing yet.
I am interested about how can i calculate the gear ratio for 4.45 final drive or 4.25.
Because i don't know where is the map or table in the DME for this.
That's what i like to know.
And another question
SMG ECU has any software settings for vehicle speed vs rpm?
Or just the DME tells to the SMG what to do?
Thank You!
Old Sun, Aug-21-2016, 12:30:01 PM   #4
MartynT
MartynT's Avatar
United Kingdom
Ah, my bad!
What version of software is your DME running?
Old Sun, Aug-21-2016, 04:35:29 PM   #5
TudiM3
TudiM3's Avatar
Ah, my bad!
No problem!
This is my version: 211322002101JD39
I can't find it in p0lar's list...
Old Sun, Aug-21-2016, 04:54:46 PM   #6
MartynT
MartynT's Avatar
United Kingdom
0x1AB4 for 2101.
For 4.25 change 'DA' to 'FF'.
Old Sun, Aug-21-2016, 07:48:10 PM   #7
TudiM3
TudiM3's Avatar
0x1AB4 for 2101.
Thank you!
But i am interested why it works if i change this DA value to FF?
And why it works only with 4.25?
If i am correct this adress is the first gear of smg.
Why not possible to make a working map to work with 4.45 final drive?
Thank you again!
Old Sun, Aug-21-2016, 08:23:07 PM   #8
MartynT
MartynT's Avatar
United Kingdom
4.25 * 60 = 255. 255 in hex = FF
Old Sun, Aug-21-2016, 11:43:10 PM   #9
Originally Posted by TudiM3 View Post
Thank you!
Thank you again!
It's a single byte value. Maximum value you can store in a single byte is 0xFF (255). Conversion factor is x/60. 255 / 60 is 4.25, hence that's the maximum ratio the DME supports. It may be possible to change those bytes to words (and thus allow a value between 0 and 65535), but I haven't examined the code thoroughly to see if that would break anything else.
The other values that might be giving you issues are all the gear recognition factors
Try setting:
K_GANG_GRENZE1_2 to 120
K_GANG_GRENZE2_3 to 80
K_GANG_GRENZE3_4 to 50
K_GANG_GRENZE4_5 to 40
K_GANG_GRENZE5_6 to 32
K_S_GANG1_NV_MAX to 160
K_S_GANG1_NV_MIN to 148
K_S_GANG2_NV_MAX to 95
K_S_GANG2_NV_MIN to 85
K_S_GANG3_NV_MAX to 64
K_S_GANG3_NV_MIN to 58
K_S_GANG4_NV_MAX to 48
K_S_GANG4_NV_MIN to 42
K_S_GANG5_NV_MAX to 38
K_S_GANG5_NV_MIN to 34
K_S_GANG6_NV_MAX to 32
K_S_GANG6_NV_MIN to 28
K_S_GANG7_NV_MAX to 144
K_S_GANG7_NV_MIN to 135
Old Mon, Aug-22-2016, 11:06:42 AM   #10
cossie1
Reputation: 0 cossie1 is on a distinguished road
United Kingdom
What happens if you change DA to 0C ?
Jump to top cossie1 is offline   Reply With Quote
Discussing MSS54 Final drive changed to 4.45->limp mode.Please HELP! in the Coding and Tuning Forum - Discuss all avenues of coding and tuning here! at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
