Old Sun, Dec-11-2011, 12:08:13 PM   #11
jcreme
Mechanical? Engineer?
jcreme's Avatar
Reputation: 0 jcreme has disabled reputation
Originally Posted by teknoswede View Post
Great DIY on this forum!
Thanks a lot!
Original Owner 2003.5 IR 6MT
Jump to top jcreme is offline   Reply With Quote
Old Wed, Dec-28-2011, 09:57:50 PM   #12
///mtree
Reputation: 0 ///mtree is on a distinguished road
Default Re: Rear Differential input seal replacement
Thanks for the DIY!
Quick question, do you happen to know the part # for the seal?
Thanks!
Jump to top ///mtree is offline   Reply With Quote
Old Thu, Dec-29-2011, 01:35:02 PM   #13
ECSTuning
ECSTuning's Avatar
Reputation: 0 ECSTuning is on a distinguished road
Originally Posted by ///mtree View Post
Thanks for the DIY!
Thanks!
Your output seals are going to be the ones found HERE.
ECS Tuning
ECS Tuning your #1 source for all things German automotive
Customer Service Hours: M - F 8:00am - 8:00pm EST | Saturday: 10:00am - 7:00pm EST
Sales Team Hours: M - F 8:00am - 11:00pm EST | Saturday: 10:00am - 7:00pm EST
800.924.5172 | OEM BMW Part Number Search
sales@ecstuning.com | customerservice@ecstuning.com
Jump to top ECSTuning is offline   Reply With Quote
Old Sun, Mar-18-2012, 04:00:43 AM   #14
M3novo
Reputation: 0 M3novo is on a distinguished road
I disassembled the Input shaft that comes from engine from the diff flange and noticed there is a blue gasket in between both. It was damaged and I am not sure if it needs to be replaced as I didn't see it on this DIY.
Jump to top M3novo is offline   Reply With Quote
Old Thu, Jun-13-2013, 12:39:42 AM   #15
snikwad
EOMFD
snikwad's Avatar
Reputation: 0 snikwad will become famous soon enough
Jamaica
Hey guys. If you swap input flanges from one diff to another. How do u know where to put one in and mark it, etc?
Secondly, if I opt not to do that, where might I find JUST the I put flange for purchase.
I can't seem to find a part # on realoem. Any idea? I bought a diff and FedEx managed to damage/dent the input flange and the back cover.
01 IR on Blk Vert with lots of stuff!
Jump to top snikwad is online now   Reply With Quote
Old Sun, Sep-29-2013, 06:45:11 PM   #16
Kaveh
Kaveh's Avatar
Reputation: 0 Kaveh has disabled reputation
Excellent write up. Did mine today and changed the fluid.
No more leaks and no more grinding Diff noise. I strongly suggest anyone doing this, to go ahead and change their Guibo as well and also purchase a new Diff output shaft locknut plate as they will be destroyed in most cases.
I need to replace the Guibo and the Nutlock P/N: 33121205138
'05 IB/Black ZCP ::: SMG ::: LEDs ::: CWP ::: NAV (Keeper)
Jump to top Kaveh is offline   Reply With Quote
Old Thu, Nov-28-2013, 11:17:18 PM   #17
eimkeith
eimkeith's Avatar
Reputation: 0 eimkeith is on a distinguished road
Originally Posted by jcreme View Post
Sorry I don't have a link for you, but I'm certain that when I was researching for my job, I found a DIY on bimmerforums or e46fanatics and his assembly routine was not based on marking but based on torque alone. It requires a new crush sleeve.
And if I remember right, requires you to measure the torque required to turn the diff and rear wheels before disassembly (although, I bet an estimate is close enough).
Search bimmerforums or e46fanatics and see if you can find it.
Where is this crush sleeve? I didn't see it in the images shown?
keith
'72 911, '67 M715, '03 M3
'70 TD2B, '73 CB750
www.zuffenhaus.us
Jump to top eimkeith is online now   Reply With Quote
Old Tue, Apr-01-2014, 10:47:21 PM   #18
kokgo20
kokgo20's Avatar
Back from the dead, but anyone knows the proper torque for the input flange nut?
Build thread
05/2004 SMG PY/BLK - 600 TCKline - CPI Headers & resonated Sec1- Stoptech BBK 6 pod front & 4 pod rear with steel lines - 75mm Studs conversion - SDW monoball RTABs - AKG subframe bushings - Multi color AEs - FR-X 3.0 Projectors - Smoked Side markers - Euro bumper - V1 with hard wire & Stealth one - M Track Mod - ZCP steering rack - Dual LI - CSL Style diffuser - SCZA Exhaust - E9x Door handle LED retrofit - SCZA CSL bootlid - VEI systems custom air vent A/F & boost gauge - VEI custom air vent Water temp & oil pressure guage- Active Prima plus + FS tune - Mishimoto Radiator & Oil cooler - H&R front Sway - UUC camber arms - keyless & push to start system - clear bra - interiors red stitching contrast - Apex PS7s - 16" Spal fan
Old Tue, Apr-01-2014, 10:56:32 PM   #19
NetFixer
NetFixer's Avatar
Reputation: 0 NetFixer is on a distinguished road
I think you're suppose to mark and put back at same spot. Take pictures of thread count.
2005 AW M3S. S for stock!
Jump to top NetFixer is offline   Reply With Quote
Old Wed, Sep-17-2014, 03:49:44 PM   #20
M3_RU33ER
M3_RU33ER's Avatar
Reputation: 0 M3_RU33ER is on a distinguished road
Would you have the part number for the Lock nut Locking Plate?
Jump to top M3_RU33ER is offline   Reply With Quote
differential, input, rear, replacement, seal
Discussing Rear Differential input seal replacement in the Faults, Fixes and DIY Forum - Please share your experience and knowledge with other members by contributing your own DIY, or by helping another member find the elusive fix! at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
