Old Sun, Apr-10-2016, 01:43:04 PM   #51
Default Re: Torque Spec thread
i'll look into merging them tonight
Old Sun, Apr-10-2016, 04:41:18 PM   #52
Threads are merged. I believe I made it so that all the relevant info is in the first 3 posts, though I had to delete some positive feedback posts to do it.
Old Sun, Apr-10-2016, 05:36:42 PM   #53
Flow
Flow's Avatar
France
PDF updated.
I believe there are some mistakes in post #1, like the differential to carrier bolts torques..
See post #3 for current PDF link.
2004 M3 TiAg / LSB SMG
Old Sun, Apr-10-2016, 05:55:23 PM   #54
Flow
Flow's Avatar
France
After my research, here is what I think is wrong in post #1 :
lower strut slip-fit to kingpin/clamshell bolt: 74 ft-lbs (100 Nm)
-> Should be 81 Nm
control arm ball joint: 44 ft-lbs (60 Nm)
-> Should be 90 Nm
rear lower control arm to trailing arm bolt: 57 ft-lbs (77 Nm)
-> Should be 110 Nm
front subframe bolts: 66 ft-lbs (90 Nm)
-> Should be 110 Nm (E46 M3 uses M12 10.9 Grade bolts)
1 front diff mount bolt: 128 ft-lbs (174 Nm)
2 rear diff mount bolts: 70 ft-lbs (95 Nm)
-> Should be 200 Nm for the front / 20 Nm + 90 degrees for the rear
guibo to transmission/driveshaft: M12 - 74 ft-lbs (100 Nm)
-> Should be 115 Nm
driveshaft to differential flange: 63 ft-lbs (85 Nm)
-> Should be 70 Nm
transmission to oil pan bolts: M8 Allen - 17 ft-lbs (24 Nm)
-> Should be removed since the better text / description is a couple of lines down
Old Mon, Apr-11-2016, 02:53:47 PM   #55
jdev
Reputation: 0 jdev is on a distinguished road
-> Should be 81 Nm
-> Should be 90 Nm
-> Should be 110 Nm
-> Should be 115 Nm
-> Should be 70 Nm
Flow, where are you referencing these values from? Is there a link, or source we can access or even purchase from?
02 Silver/Red
Jump to top jdev is offline   Reply With Quote
Old Mon, Apr-11-2016, 03:12:50 PM   #56
Flow
Flow's Avatar
France
I have the TIS software on my computer and went through it.
You can find it online here : http://workshop-manuals.com/bmw/3_se...mw_gs_90003-2/
I linked you directly to the torque spec section.
I read through it 3 or 4 times before understanding it all.
Old Mon, Apr-11-2016, 03:22:25 PM   #57
ThrowinShapes
ThrowinShapes's Avatar
Reputation: 0 ThrowinShapes is on a distinguished road
Nice solution
[06' AW/Cinnamon] [6MT] [Slicktop] [Manual Seats]
Journal - Update 2017-02-28
FS: Center Console | US Headers / Rear O2 | Rent: SIR B90-BMW Rear Wheel Bearing Tool
Jump to top ThrowinShapes is offline   Reply With Quote
Old Sun, May-15-2016, 05:47:25 PM   #58
cyberlando
cyberlando's Avatar
hay man just a quick note..........is it possible for you to add the page number each change was made on.........instead of reprinting each change of all the pages over again?
would help out alot
Engine:
Interior:
Suspension/Handling:
Old Sun, May-22-2016, 10:36:00 PM   #59
cyberlando
cyberlando's Avatar
Default Re: Torque Spec Thread
Also some of the pages are cut off further to the bottom.....like you would see some items in the diagram but the part number and the item number at the bottom of the page is cut off.
Sent from my SM-N910F using Tapatalk
Engine:
Interior:
Old Mon, Jul-04-2016, 08:12:17 AM   #60
v1rotate1
v1rotate1's Avatar
Reputation: 0 v1rotate1 is on a distinguished road
Another reason why I love this forum. Great resource to be shared
Jump to top v1rotate1 is offline   Reply With Quote
Discussing Torque Spec thread in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
