Old Sun, Jul-16-2017, 08:37:14 PM   #1
Ebonywolf
Ebonywolf
Reputation: 0 Ebonywolf is on a distinguished road
Unhappy Ignition not turning over
When I try to start my 2005 M3 it usually takes 3-4 attempts at resetting the process in order for her to start. Sometimes it may start of the first try but usually it's 3-4 and this happens with both keys. Also, one of my keys cannot unlock the door or the trunk.
I know (the) keys are rechargeable but are we able to replace the battery or do I have to order a new set. Could his be a key-communication issue due to low key/battery power?
There doesn't seem to be noise from a failing starter or low car battery issues.
Jump to top Ebonywolf is offline   Reply With Quote
Old Sun, Jul-16-2017, 10:35:50 PM   #2
Good
@GOOD_M3
Good's Avatar
Default Re: Ignition not turning over
SMG or 6 speed?
2006 M3 Competition | Jett Black [Current Part Out]
Jump to top Good is online now   Reply With Quote
Old Sun, Jul-16-2017, 10:37:07 PM   #3
Good
@GOOD_M3
Good's Avatar
If SMG it means your pump has lost a significant amount of pressure. You should probably either preform a tranny swap or replace the pump.
Old Sun, Jul-16-2017, 11:13:49 PM   #4
whips333
whips333's Avatar
Based off of what the OP said...how did you conclude that the issue was the SMG?!?!
Any codes OP? Could be a number of different issues from fuel pressure, starter, CPS etc
Old Sun, Jul-16-2017, 11:47:02 PM   #5
Good
@GOOD_M3
Good's Avatar
Could be anything, the pump is a common issue with these cars that are smg equipped. Seems almost as if it's smg pump if below 100k miles.
Old Mon, Jul-17-2017, 12:32:56 AM   #6
Ebonywolf
Ebonywolf
SMG or 6 speed?
6 Speed.
Old Mon, Jul-17-2017, 12:44:10 AM   #7
ThunderMoose
Originally Posted by Ebonywolf View Post
6 Speed.
There goes good's theory
#67 2017 NASA TX TT3 Champion
Discussing Ignition not turning over in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
