Old Sun, Jul-16-2017, 03:58:27 AM   #1
HolyChitMeng
Alpine White Hoarder
HolyChitMeng's Avatar
Reputation: 0 HolyChitMeng is on a distinguished road
Default EGT Sensor Fuse?
Hey guys, ran my car through an DME diag test on INPA, and pulled code 79 otherwise known as the Abgastemperature sensor, which I believe is the EGT Sensor. I purchased a new EGT sensor, as I'm replacing the headers anyway, but wanted to know where the fuse was to see if I can unplug it and replug it and see if it's was caused the problem. Does anyone know where the EGT fuse it?
AW/BLK 09' 6MT ///M3: ESS VT2-650, BBS LM, Stoptech Trophy, Evolve, Full Supersprint Race, KW Sleeve Kit
TIAG/IR 04' 6MT ///M3: BBS CH, Eibach Pro-Street-S, Full SS Race, Eventuri, Evolve, AS 30% SSK, OE CSL Bootlid
AW/BLK 95' ///M3: 16k miles, LTW Strut Brace
Jump to top HolyChitMeng is offline   Reply With Quote
Old Sun, Jul-16-2017, 05:06:56 AM   #2
PITT M3 RR
PA
PITT M3 RR's Avatar
Default Re: EGT Sensor Fuse?
79 4F P1490 Signal, temperature sensor, exhaust gas
post a screen shot of the read out
S54 E36 BUILD
Old Sun, Jul-16-2017, 07:59:10 AM   #3
HolyChitMeng
This is what it says... the thing is I don't have a Check Engine so i'm skeptical.
Old Sun, Jul-16-2017, 11:09:28 AM   #4
ThunderMoose
Does not appear to have its own fuse. It is connected directly to DME.
#67 2017 NASA TX TT3 Champion
Old Sun, Jul-16-2017, 01:59:03 PM   #5
HolyChitMeng
So Would you recommend just changing the whole senor then?
Old Sun, Jul-16-2017, 03:04:53 PM   #6
PITT M3 RR
PA
PITT M3 RR's Avatar
Its there with the car off and no load and the logistics counter is at 40, meaning it was present the exact time that you read it.
"Short circuit vbatt o. Value too big, error present, static error"
Martyn's tool will allow you to code it out, or you can do it manually, free. Or jus grab a new sensor ya know. Good luck!
S54 E36 BUILD
Old Sun, Jul-16-2017, 04:39:02 PM   #7
HolyChitMeng
Interesting, I just remembered that Martyns tool allows for adjustment of EGT, would I just put the maximum value? if it's there with the car off... what's causing the error then? If I turn it off are there any downsides?
Old Sun, Jul-16-2017, 07:04:27 PM   #8
warpig12354
Reputation: 0 warpig12354 is on a distinguished road
There's a box you can check to disable it.
2003 M3 CB 6MT | Rogue Engineering | Michelin | Beisan | Dinan | AKG | TMS | BBS | Bilstein | BimmerWorld | GroundControl | PFC | CPI
Jump to top warpig12354 is offline   Reply With Quote
Old Sun, Jul-16-2017, 11:35:12 PM   #9
HolyChitMeng
Should I just disable cat enrichment as well?
Is there any downsides to this?
Old Sun, Jul-16-2017, 11:42:23 PM   #10
bigjae1976
The EGT signal goes right to the DME connector and there's also a ground. If you're installing headers...why do you need the EGT sensor?
2013 F30 328i - Melbourne Red
2004 E46 M3 - Imola Red
Discussing EGT Sensor Fuse? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
