Old Sun, Jul-16-2017, 08:10:56 PM   #11
Engrmikl
Reputation: 0 Engrmikl is on a distinguished road
Default Re: What worn out suspension parts to replace to return car back to factory ride?
I just picked up an 02 with 100k and starting the rear this week. Rear first since I have slight cracking on the subframe. Front after when some cash frees up.
I am using the ECS Tuning refresh kits that pretty much covers everything plus a few extras like shock tower reinforcement and rcab spacers. I upgraded the rcabs and sway bars to Rogue Racing poly.
Don't forget while you have this all out you will probably want to reinforce the subframe. The kits are not expensive but do require welding.
Stage 3 is cooling, rod bearings, vanos, engine and trans mounts.
And yes it is going to be an expensive few months
Jump to top Engrmikl is offline   Reply With Quote
Discussing What worn out suspension parts to replace to return car back to factory ride? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
