Old Fri, Jul-14-2017, 06:57:18 PM   #1
MFNATIK
Reputation: 0 MFNATIK is on a distinguished road
Default What worn out suspension parts to replace to return car back to factory ride?
My new to me convertible is sitting around 95k miles and it doesn't feel quite as tight as I like it to. What worn out parts should I start replacing? I'm sure the stock shocks are probably done and I'd like to maintain the stock ride, would going with a set of Koni's be cost effective and come close to stock ride? I've never heard of anyone replacing worn out stock shocks with factory shocks (probably not cost effective). Any advice is appreciated.
TIA!
2005 Imola M3 Convertible
2017 LSB F80
2017 Protonic Blue i3REx
2002 525iT M Sport
Jump to top MFNATIK is offline   Reply With Quote
Old Fri, Jul-14-2017, 07:03:23 PM   #2
Default Re: What worn out suspension parts to replace to return car back to factory ride?
Koni yellows
Front control arms
FCABs
Tie Rods
steering guibo
rear inner upper control arm bushings
rear inner lower control arm bushings
rear out upper control arm bearings
rear outer lower control arm bearings
RTABs
front sway bar end links
rear sway bar end links
front sway bar bushings
rears sway bar bushings
RSMs
engine mounts
trans mounts
diff mounts
subframe bushings
Most of the time, rubber bits are pretty used up by ~100,000 miles (all cars, not unique to this one).
If you want it drive like new... replace all of it.
Old Fri, Jul-14-2017, 07:08:14 PM   #3
MFNATIK
Koni yellows
Front control arms
FCABs
Tie Rods
steering guibo
RTABs
RSMs
engine mounts
trans mounts
diff mounts
subframe bushings
Lovely list lol. What's an estimated cost partswise to replace all? What are the key ones that you'd recommend if I were to prioritize to do in 2-3 stages?
2017 LSB F80
2002 525iT M Sport
Old Fri, Jul-14-2017, 07:16:14 PM   #4
If you wanted to do it in 2 stages, I'd do the front of the car first and the rear of the car second, assuming your RTABs aren't shot. It's the only way you won't be paying for labor twice.
Your 3rd stage can be the cooling system, if that's original. It, like all BMWs, should also be replaced at 100,000 mile intervals
Part wise, depends on how you go. If you get all OE BMW with BMW badge it'll be more than if you hunt it down piece by piece and get the OEM (as in, the company that made it for BMW-- which generally results in 30-50% part cost savings.
The OEMs found here:
http://www.m3forum.net/m3forum/showthread.php?t=566749
I'd estimate ~$3000 for OE suspension bits, $2000 for the OEM suspension bits, and ~$1000 for the cooling system (the OEM not available for the expensive bits).
Old Fri, Jul-14-2017, 07:19:37 PM   #5
MFNATIK
That's a sensible approach (2 stages, F and then R). Good thing this isn't my daily! I'll be spreading this out over the next year as it approaches 100k
2017 LSB F80
2002 525iT M Sport
Old Sat, Jul-15-2017, 09:02:36 AM   #6
Karter16
Reputation: 0 Karter16 is on a distinguished road
New Zealand
Koni yellows
Front control arms
FCABs
Tie Rods
steering guibo
RTABs
RSMs
engine mounts
trans mounts
diff mounts
subframe bushings
This...
I did the above (plus some other stuff) as part of my quest to refresh the mechanicals of my car. I can confirm first hand that people are not exaggerating when they say "it's a completely different driving experience". I've been surprised at the difference it's made. The car handles and rides so crisply and smoothly. Interestingly lots of the interior rattles are vastly reduced now that the car rides over rough road so much better. Well worth the effort to do it all in my opinion.
2005 ///M3 SMG Coupe Silbergrau Metallic/Black Leather
Build Thread: http://www.m3forum.net/m3forum/showthread.php?t=564562
Jump to top Karter16 is offline   Reply With Quote
Old Sat, Jul-15-2017, 01:17:39 PM   #7
m3e46freak
M3 Freq
m3e46freak's Avatar
Reputation: 0 m3e46freak is on a distinguished road
Germany
That is a big ass list lol...
I would do these for immediate change:
1. FCAB
2. RTAB
3. Front control arms and links
That'll do for now... but eventually all of that other hard to reach shit should be taken care of also... and inner outer tire rods
Rock Hard Abs Racing
KWV2!
18X10 CCW CLASSIC!
CPI Headers!
RESONATORS AND SUPERSPRINT!
DINAN!
FRANK!! 311RWHP-260Torque
m3e46freak@yahoo.com for outside contacting
ebay/craigslist verified 100% FEEDBACK
m3forum 96% FEEDBACK
m3post/e46fanantics Great FEEDBACK
zpost/bimmerforum Great FEEDBACK
Jump to top m3e46freak is offline   Reply With Quote
Old Sat, Jul-15-2017, 05:08:19 PM   #8
MFNATIK
Thank you for the abridged list! That's good to know and is what I'm going to try first to get some immediate fixes in place
2017 LSB F80
2002 525iT M Sport
Old Sat, Jul-15-2017, 06:06:09 PM   #9
black bnr32
Reputation: 0 black bnr32 is on a distinguished road
assuming nothing is actually completely worn out, the largest differences will probably be from stiffening the FCABs, RTABs (limiters), shocks, and sway bars
and maybe a better alignment
Jump to top black bnr32 is offline   Reply With Quote
Old Sun, Jul-16-2017, 02:41:50 AM   #10
m3e46freak
M3 Freq
m3e46freak's Avatar
Germany
^ as yes, forgot about alignment.
KWV2!
18X10 CCW CLASSIC!
CPI Headers!
DINAN!
Discussing What worn out suspension parts to replace to return car back to factory ride? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
