Old Fri, Jul-14-2017, 09:33:00 PM   #31
Default Re: Just had inspection service, no valves needed to be re-shimmed, is this normal or
Ya know, I was just gonna post about loose push rod V8s. They're not like this hi strung straight 6.
Maybe a valve adjustment will net one HP on a 440ci V8 or really change the power curve, but not on this car.
Also worth noting that setting valve lash can have more (not a lot, again) effect on rich/lean and when the power's made - not that more power is made because of retarding/advancing the cam.
Like albino already alluded to, we've got Vanos anyway.
/// 2004 SilberGrau M3 Coupe 6MT slicktop manual seats no nav no xenon no anything JOURNAL
Evolve-R Alpha N Evolve CSL CF Airbox Eventuri Scoop Supersprint V1 stepped 63mm SS V1 S pipe 63mm + 200 cell HFC OE sect 2 60mm SS Sport 60mm BMW Motorsport 4.10 Besian RE pullies/fan delete WPC rod bearings TMS Camber & Subf plates RE Trans Mounts AKG poly SUB/DIFF 95a SDW RTAB ZHP knob + UUC DSSR GroundControl S/A (Koni/Eibach 376/440) + tall RSMs OE CSL trunk APEX 75mm Studs Sportline 8S 18"x8.5/9.5" MPSS 245/275 Brembo 996 36/40 345mm Textar Pioneer DEH-80PRS Eclipse PA5422 CDT HD-6 + WS-100i CDT EX-530 8" Kicker
Old Fri, Jul-14-2017, 09:51:12 PM   #32
Did you actually read that thread lol?
Might wanna choose another thread Brett.
Also, I don't like what you said about me responding the way I did because it's coming from you. The only bias I have is that I expect more from you because you know more about these cars than most and are a great DIYer. I don't have any other bias than that about you.
The thread was not the point. Your post was.
Old Fri, Jul-14-2017, 09:54:36 PM   #33
I don't get your point I'm afraid.
Old Fri, Jul-14-2017, 10:00:41 PM   #34
The point was you have already been presented with this topic. You don't take it seriously.
What is it that you think aftermarket cams do? Playing with the lash is a free cam change, just on a much smaller scale. A few hp here or a few torque there versus 5-10x that with a whole new cam... or does the VANOS negate that too
Old Fri, Jul-14-2017, 10:10:31 PM   #35
I was actually the one arguing earlier that a tighter clearance is like a hotter cam!
My other contention is that it's a very marginal amount.
We tell people they're in their heads when they claim to feel a 3whp increase from an exhaust, but now a .5 or 1 or 2 hp from a valve adjustment (one where you're adjusting all 24 valves I guess) is something?
I'm over it. We're OT anyway. Bottom line to the OP, it's possible to not need any adjustment, but more likely that a few need it. Worst case scenario being a little out of spec is a fractional loss of power and maybe running a little rich/lean. There are people who go 100k without valve adjustments and their cars are "fine."
Old Fri, Jul-14-2017, 10:26:53 PM   #36
I took it like Ian did, but I see your POV too - I think both are right. Ian and I thought he meant he used one feeler and decided whether the tolerance was good or not based on how much resistance when it should be more or less, a go no-go situation.
I'm replying to this because of a later edit you made after a post. In bold is how not to use the feeler gauge. Selecting the appropriate gauge that fits the gap and feeling the resistance based on whatever analogy you subscribe to (as defined in the video) is the correct method. The correct method is how the OP described it and this is why I quoted Ian.
As far as the power from valve lash. Yes agreed, it has gone off topic. I was only pointing out the long time accepted understanding in basic form. Anyone who wants to understand more should take the time to look up the pros, cons, and realistic expectations. I'm not out to be the educator of that, which is why I said, use whatever you feel is best.
Old Fri, Jul-14-2017, 10:44:39 PM   #37
If .178 (intake) feeler fits in the gap, you know you're not too tight. If it doesn't slip in, you're too tight. If .229 feeler fits, you're probably too loose. If .254 fits, you're def too loose.
That's what I meant by go no go.
You're getting too pedantic and over complicating it or have too narrow of an idea of how to use a feeler gauge. If you want to decide the tolerance by using one feeler and feeling the resiatance, good for you. You can also use multiple feelers to deduce the tolerance by wether or not a feeler fits.
Old Fri, Jul-14-2017, 10:52:24 PM   #38
You're over complicating this and just saying exactly what I already said and posted a video of. Please watch the video. It is explained properly and matches what the OP said.
Go or no go is not an appropriate method to describe feeler gauge use. Someone with no knowledge can interpret that into "if I can cram this in, it's good to go".
Old Fri, Jul-14-2017, 11:04:20 PM   #39
Jesus Christ Brett. Where did I or anyone say anything about cramming it in? I said "slip" and "fit." I know how to adjust my valves, thanks for your concern
Old Fri, Jul-14-2017, 11:09:28 PM   #40
Get over yourself. I'm not out to teach you anything. I posted to describe the correct understanding of use for others. You chose to respond with your go or no go nonsense which required clarification for OTHERS. Own up to your incorrect description and move on.
FFS. I'm done here.
Discussing Just had inspection service, no valves needed to be re-shimmed, is this normal or OK? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
