Old Tue, Jul-11-2017, 07:07:31 PM   #21
forzanerazzurri
forzanerazzurri's Avatar
Default Re: Chasing E46 M3 never ending thud while shifting
Originally Posted by fattycharged View Post
You think this explains the thud in all occasions? I'm not so sure I agree
I think it explains the clunk that these cars had even from the factory.
Old Tue, Jul-11-2017, 08:12:00 PM   #22
EricSMG
40 something
Yes, I personally think it explains 100% of the 'normal' thud/clunk. Worn mounts and/or diff internals and/or flywheels can exacerbate it, but all cars will thud to some degree due to the driveline slack. Even the factory manual states that the thud is "normal".
All manual trans cars do this, it's just very very quiet in most cars. My brand new '17 Mustang GT did it badly, just like the 46.
It's also MUCH worse in SMG cars due to the less than perfect off throttle/clutch-in timing. When I swapped my Grey car I immediately noticed a 90% reduction in M clunk, zero other changes.
2004 E46 M3 6MT SG/Black
Old Tue, Jul-11-2017, 08:29:09 PM   #23
fattycharged
can't even
fattycharged's Avatar
Zimbabwe
How did this thread turn into an M clunk thread? ffs
Topo Chico
Old Tue, Jul-11-2017, 08:45:24 PM   #24
nowanker
"He's no wanker!"
It's dead, Jim.
Old Tue, Jul-11-2017, 10:00:44 PM   #25
dustins
dustins's Avatar
Reputation: 0 dustins is on a distinguished road
Sorry I can't quote and reply to everyone;
But again, its not "M-Clunk" I know what this sound is and how you are able to avoid the car producing it by manipulation.
I went with poly diff bushings because of a sale on ECS, during the time of ordering the Turner kit among other items. No noticeable noise difference with the poly diff bushings as I went with OEM subframe, combine the 2 together with poly and yes I get that there will be an increase. Thud is no harder for softer than prior to all of my work, only thing I noticed is slight diff whine at highway speeds. (Only if all the windows are up and blower is off).
Obviously my issue is in the diff, or transmission (DMF maybe even) I am just trying to narrow it down. Again going back to what I've said a couple times is that cursing 60-80km/h with the clutch fully depressed (pushed to the floor) I can shift back and forth from 3-4 4-3 and can reproduce the thud sound. I at one point thought that maybe the clutch wasn't fully disengaging and maybe it still isn't, but I've bleed it a couple times and removed the CDV.
Other things I notice I can do to avoid the thud is shift slow, I mean push the clutch in wait a full second or 2 without touching the shifter and then change the gear. I also notice it does not happen quite as often when I fully lift my foot off the gas pedal while switching gears, hard to get into the habbit of doing that as in all my other 4 bmw's I've owned (mind you none of them M3s) I was always able to rest my foot on gas though still letting up on the throttle while shifting (Just dont rest your foot on the clutch right ha )
No clutch stop in the car either.
Part of me thinks maybe the synchros are shot maybe, and that quick shifting while everything in the tranny is still moving is causing the thud. As I mentioned before, its super notchy down low (under 4k rpm through 1-2-3) but doesn't grind any gears when power shifting at 8k rpm.
I've spend countless hours reading threads from all the BMW forums and it always ends up talking about M-clunk and I understand what that is but I'm certain this is something deeper. It only bothers me anyways, car still drives fine, I still slide corners and rip on straights
Maybe this coming winter I'll just order an upgraded diff and try to find a low mileage Getrag 420g and see how that does. I thought about trying to find a 540i 6MT transmission that hasn't been abused and stealing the Getrag from it and swapping my bell housing to fit it into my M.
Jump to top dustins is offline   Reply With Quote
Old Wed, Jul-12-2017, 01:02:09 AM   #26
fattycharged
can't even
Zimbabwe
"m-clunk" isn't a miata
Topo Chico
Old Wed, Jul-12-2017, 01:48:09 AM   #27
EricSMG
40 something
Dude - that's completely normal for manual trans cars. The synchros are taking up driveline slack since you're forcing the trans input shaft to rapidly match the output shaft per ratio.
Normal. Unavoidable. Nothing is wrong.
It's just extra loud in these cars.
Old Wed, Jul-12-2017, 02:58:08 AM   #28
dustins
dustins's Avatar
Maybe I'm just super picky
Old Wed, Jul-12-2017, 05:06:36 AM   #29
bigjae1976
Default Chasing E46 M3 never ending thud while shifting
I had solid trans bushings and a JB flywheel. My car sounded like marbles being shaken in a can at idle. The 420g has a lot of noises which are usually well masked.
Clunking, rattles and other weird noises are normal with poly and solid bushings. I'm at the point with my track car where I can't tell if something's broken or if the sound is just normal.
2013 F30 328i - Melbourne Red
2004 E46 M3 - Imola Red
Old Wed, Jul-12-2017, 05:52:35 AM   #30
HassanEido
HassanEido's Avatar
Lebanon
the THUD you hear, is in my experience, due to the fact that your RACP acts like a drum. Being hollow and thin, the shift force strikes the RACP and creates a thud. This was greatly reduced when I did an Xbrace that went down to the mountings, as the shift force now goes to the shock tours and frame rails thru the reinforcement tubes. I don't hear the thud anymore Maybe a very muted one
Mods:
-Custom CF airbox
-Cat Cams 280 272.
-Custom dyno tune
385.7 whp 288 wtq
Discussing Chasing E46 M3 never ending thud while shifting in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
