Old Fri, Jul-14-2017, 03:03:27 AM   #41
PITT M3 RR
PA
PITT M3 RR's Avatar
Default Re: Weighted Alignment
This will seriously ease the process.
S54 E36 BUILD
Old Fri, Jul-14-2017, 03:17:45 AM   #42
Kdubski
Kdubski's Avatar
This is awesome, never thought I could diy an alignment. Cannot wait to get out of work tomorrow to tear into this project. Building blocks and the steering wheel tool. Will align for daily driving, may be slightly sporty, but will surely be setting an autocross alignment in a few weeks.
Thank you everyone for your input, it's going a long way. Will post my progress this weekend
Sent from my SM-G920V using Tapatalk
Old Fri, Jul-14-2017, 04:22:29 AM   #43
PITT M3 RR
PA
PITT M3 RR's Avatar
Use fishing line for extreme accuracy.
S54 E36 BUILD
Old Fri, Jul-14-2017, 03:22:08 PM   #44
Kdubski
Kdubski's Avatar
As for the measuring goes, can I use any other than a measuring tape? I saw a tutorial using a "digital caliper" but can't find it now to save my life.
It used something like this:
https://www.harborfreight.com/6-inch...per-47257.html
Old Fri, Jul-14-2017, 03:30:21 PM   #45
Kcalhoun27
Reputation: 0 Kcalhoun27 is on a distinguished road
I saw a video where a guy used a ruler. My only thought after reading and researching is making sure you use something that you can be sure is squared to the line. Though, i suppose half a millimeter is probably only a measurement that a race car would need.
Any thoughts on this? At what point does a bees dick of difference matter for good measurement?
Jump to top Kcalhoun27 is offline   Reply With Quote
Old Fri, Jul-14-2017, 04:57:06 PM   #46
PITT M3 RR
PA
PITT M3 RR's Avatar
I use a ruler, just use the same one for everything you do.
S54 E36 BUILD
Old Sun, Jul-16-2017, 10:46:47 PM   #47
Kdubski
Kdubski's Avatar
Spent the day building the wooden stands to PITT M3 RR's spec. Time came to do the alignment, I couldn't easily get the car on the stands. The tires sag too much. I used another jack to lift the individual suspension components enough to slide the wood under, but by the time I finished I was exhausted.
Will try again this week/weekend on proper slip plates(borrowed from friend) on the ground.
Not giving up!
Old Mon, Jul-17-2017, 03:54:21 PM   #48
PITT M3 RR
PA
PITT M3 RR's Avatar
Yea should have mentioned. Lift car onto 2x10s, then get it onto stands, then put a 2x6 square on the jack and raise it the last bit. Take about 15 min to set up.
S54 E36 BUILD
Discussing Weighted Alignment in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
