Old Fri, Aug-19-2016, 05:27:09 PM   #1
because_racecar
that's why.
because_racecar's Avatar
Reputation: 0 because_racecar is on a distinguished road
Default Diff rattle... but not another M-clunk thread
Searching is difficult due to the endless m-clunk threads on the subject and most of the responses in those threads say "SEARCH!"
My rear end is extremely noisy and rattles over bumps and between shifts even at high speeds. I usually drive pretty tame especially between shifts because it's extremely noisy. For example, in neutral, clutch out, going over little dips gives the same clunk sound as the typical m-clunk but it's just much louder and happens frequently. Get back in gear and feels like the gear backlash or driveshaft is slamming pretty hard.
I have aluminum subframe bushings so i'm already aware of the increase in noise and vibrations but the rattle is intense... almost as if my subframe is cracked and rattling. But its not, I'm sure of it.
So my question is, what's the issue? Is this as simple as replacing some parts or do I need a new diff?
PHOTOS: E46 M3 on WRAPFOLIO.com - PM me for custom vinyl stickers or any vinyl questions.
WHEELS: VOLK TE37-SL Diamond Black // 18x9.5 22mm front 265-35-18 // 18x10.5 20mm rear 275-35-18 dunlop direzza
Jump to top because_racecar is offline   Reply With Quote
Old Fri, Aug-19-2016, 06:43:58 PM   #2
ctres
ctres's Avatar
Reputation: 0 ctres is on a distinguished road
Default Re: Diff rattle... but not another M-clunk thread
Have you checked your diff bolts? They are prone to backing out if you don't have the updated ones.
Jump to top ctres is offline   Reply With Quote
Old Fri, Aug-19-2016, 09:24:02 PM   #3
fattycharged
can't even
fattycharged's Avatar
Zimbabwe
maybe it's not what you think it is, have you been under the car and made sure everything surrounding is good? I wouldn't assume it's your diff or subframe till you confirm everything is secure & bolted in place, especially if you performed an installation of those aluminum "bushings" recently. Pretty easy to overlook something, and definitely easy for someone else to overlook something if you paid a shop to do the work
Topo Chico
Old Fri, Aug-19-2016, 11:38:13 PM   #4
because_racecar
that's why.
I need to get back under. I've had the car for 4 years and the work was done by the previous owner. It's just worse now than it was. Every gear feels like a huge backlash and slaps together when drag becomes load.
Old Mon, Jul-17-2017, 07:40:04 AM   #5
Skuzm3
Reputation: 0 Skuzm3 is on a distinguished road
Ever get this sorted out? Btw i have the same car as you its crazy i just stumbled across your page
Jump to top Skuzm3 is offline   Reply With Quote
Discussing Diff rattle... but not another M-clunk thread in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
