Old Mon, Jul-17-2017, 01:37:45 AM   #1
duracellttu
I think fast, I talk fast and I drive fast...
Reputation: 0 duracellttu is on a distinguished road
Default Power steering rack leak
Hey everyone, looking for a little advice regarding a leak from the passenger side of my power steering rack. The other day in my garage I noticed some oil on the ground. Jacked up the car and saw a wet spot coming from the front diaper/cover. Removed it and saw that the passenger side boot was torn on the power steering rack and a small leak. Fluid levels were fine in the reservoir.
Is this an indication that my steering rack is in its way out?
I have a competition package model, and noticed that there are two different part numbers for the steering racks. Is that accurate?
2005 BMW M3 ZCP - Black/Black Built not bought. All DIY!
Evolve-R | AP V2 Headers | CPI Euro200R (200 cell) | SS Non-res X-pipe + Race | 3.91 w/ 3 stage clutch | TCK SA 450/500 | Vorshlag Camber Plates
Rogue Engineering ASP, RSM, RTABs, TM | TMS Sway Bars, Camber Arms, Pullies | Mason Race Strut, Rear X-Brace | AS 30% SSK | aFe Stage 2 | SPAL Fan
AKG FCABs, SFB | Redish Reinforcement | Turbo Toys V2 Hub | WPC Treated Rod Bearings
Jump to top duracellttu is offline   Reply With Quote
Old Mon, Jul-17-2017, 04:21:13 PM   #2
E46Hoonigan
Reputation: 0 E46Hoonigan is on a distinguished road
Default Re: Power steering rack leak
Check the high pressure steering line; that is the most common steering fluid leak area in our cars. Its also a good idea to replace that broken boot. Dust and road debris can get into the rack and ruin it.
And yes, the competition package cars have a quicker ratio steering rack compared to the non ZCP M3s.
Jump to top E46Hoonigan is offline   Reply With Quote
Old Mon, Jul-17-2017, 05:57:31 PM   #3
MrVond
The Phanto///M
Reputation: 0 MrVond is on a distinguished road
do check the HPPS line, mine was leaking, also look at the line that goes to the PS cooler. mine are leaking, and have less than 20k miles in them.
///M
Jump to top MrVond is offline   Reply With Quote
Old Tue, Jul-18-2017, 04:25:46 AM   #4
duracellttu
Thanks. It's not the high pressure line. I confirmed that the leak is coming from the rack itself. Likely a seal going bad?? I'll probably take the boot up so debris doesn't get in the rack piston.
Old Tue, Jul-18-2017, 02:05:12 PM   #5
http://rackdoctor.net/
Current Cars: 2005 IR/IR M3, 2001 LMB/blk M5, 03 530i, 04 M3 wagon
Old Wed, Jul-19-2017, 01:47:44 AM   #6
duracellttu
Thanks Obi. Do you know if they have ZCP racks too?
Old Wed, Jul-19-2017, 01:53:32 AM   #7
duracellttu
...also curious what "green tag" means??
Old Wed, Jul-19-2017, 04:03:33 AM   #8
van_basten
Reputation: 0 van_basten is on a distinguished road
Get the ZHP rack. It has a shorter ratio than ZCP.
Jump to top van_basten is offline   Reply With Quote
Old Wed, Jul-19-2017, 04:41:35 AM   #9
kuksul08
Reputation: 0 kuksul08 is on a distinguished road
My power steering line has had a small leak for over 30k miles. The hose is wet and there are a few drops beneath it. It's not a real concern.
The torn boot should be addressed very soon though.
~*Mods*~: High Flow Carbon Fiber Strut Pipe Trim, Custom Aero DME Shift Linkage, Forged Titanium Race-Euro-Spec Illuminated Diff Sleeves, Catless Dog CSL Retrofit, Mod Bug Delete & More
S54 Valve Adjustment DIY, Excel, Print out: http://dl.dropbox.com/u/28231781/S54...ent%20info.zip
S54 VANOS DIY video (cam bolts, oil pump disk, etc.): http://www.youtube.com/watch?v=9SkT2j3jsU0
Jump to top kuksul08 is offline   Reply With Quote
Old Wed, Jul-19-2017, 05:03:31 AM   #10
duracellttu
Do you know the ratio differences between the standard, ZCP and ZHP?
Discussing Power steering rack leak in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
