Old Sun, Jul-16-2017, 07:35:24 PM   #191
e46xxspeed
Reputation: 0 e46xxspeed is on a distinguished road
Default Re: Xtron PB7646BAP review
Harness is plug and play. Not sure what you're asking. The connectors can only go in specific ports on the head unit. The harness goes from the unit from the front to the trunk via the extension harness then connects to where the connects to where the old nav unit connected
Sent from my Pixel XL using Tapatalk
Jump to top e46xxspeed is offline   Reply With Quote
Old Mon, Jul-17-2017, 04:39:55 PM   #192
Kieffer87
Reputation: 0 Kieffer87 is on a distinguished road
Originally Posted by Good View Post
From the head unit, where is the harness suppose to be connected to?
When I put my Avin Avant2 in I had to purchase an additional harness that ran to the trunk since that's where all of the "brains" were with the factory NAV setup. In my current setup the Avin connects to that harness and that harness only from what I recall. I don't believe any of the connectors behind the dash are used but I'd have to confirm.
Unit should be here tomorrow, crazy fast shipping. I'll report back on what I find.
2003 M3 Alpine/Cinnamon Loaded
APEX ARC-8 18x9.5 ET35 wrapped in 265/35 PSS
TCKline D/A Coilovers (550F/600R) W/Monoball RSM, H&R Adjustable Sway Bars
Fabspeed Headers, UUC Corsa Exhuast, CPI RASP-X
Rogue Power Pullies, AA Tune, SS Lines, ZHP Steering Rack
Jump to top Kieffer87 is offline   Reply With Quote
Old Mon, Jul-17-2017, 06:32:12 PM   #193
m3atwad
Reputation: 0 m3atwad is on a distinguished road
just a headsup, the glare on this bad boy can be bad sometimes. if the sun is setting behind you and its coming through the back window, oh man, be prepared to be blinded by the light. my windows are tinted too. ill probably look for an anti-glare screen but not sure if any really work that well. other than that, unit works well. upgraded the software from the link they sent me with a microSD card. and its pretty simple.
Jump to top m3atwad is offline   Reply With Quote
Old Mon, Jul-24-2017, 06:04:14 PM   #194
KhanArt
CLEAN & SIMPLE
KhanArt's Avatar
Reputation: 0 KhanArt is on a distinguished road
Has anyone else purchased this?, reviews/complaints?
2004 Jet Black/Cinnamon 6spd ///M3
Build///Journal
IG: @Khan_Art_
Jump to top KhanArt is offline   Reply With Quote
Old Mon, Jul-24-2017, 06:32:42 PM   #195
e46xxspeed
Glare you can get anti glare screens for. It's a ***** to get in the console and flush because there isn't much room back there. So you have to be careful of placement of cables. Once you finally get it right. It works great if you have a wifi hotspot. It's super fast and no lag.
Old Mon, Jul-24-2017, 06:46:45 PM   #196
Mars
Reputation: 0 Mars has disabled reputation
I installed mine Saturday evening. I'll share my thoughts once I've had a few more days with it.
Jump to top Mars is offline   Reply With Quote
Old Tue, Jul-25-2017, 12:27:51 AM   #197
robgill
I'd rather be at the track.
robgill's Avatar
Reputation: 0 robgill is on a distinguished road
Pretty happy with mine. Once I got the cables sorted the fit was flush. As many have stated the screen glare is pretty bad. I haven't had a chance to try a anti glare decal.
As for functionality I had no problems setting up wifi, Bluetooth etc. I was primarily interested in the Torque app and on track timing, both of those work great.
For an added bonus, the audio for radio is much better and louder than the stock system.
My '02 E46M Build Thread
Jump to top robgill is online now   Reply With Quote
Old Tue, Jul-25-2017, 04:08:37 AM   #198
JamesSJ1
Reputation: 0 JamesSJ1 is on a distinguished road
Need anti-glare? When I got my 'vert with factory NAV a few years ago, the screen was scratched up enough to be annoying. Used a cleaner and removed the top coat, which leaves the screen super glossy and reflects the sun right into your eyes like a mirror...not to mention being impossible to see during the day with the top down.
Bang for the buck... buy this:
and then cut to fit. I used a cutting mat, a sharp x-acto knife and a metal straight edge.
Sorry to say the edges aren't always perfectly flush, but it's about 1mm of annoyance sometimes when I look at it vs. impossible to use without. The anti-glare is VERY good, with very good light transmission through it all the time too.
Jump to top JamesSJ1 is offline   Reply With Quote
Old Tue, Jul-25-2017, 04:40:54 PM   #199
KhanArt
CLEAN & SIMPLE
KhanArt's Avatar
Thank you, I appreciate it.
Thank you, I will look out for your review.
Thanks Rob
Bang for the buck... buy this: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 and then cut to fit. I used a cutting mat, a sharp x-acto knife and a metal straight edge.
Thanks, I was just about to ask for someone to post a link to an anti glare they recommend.
Looks like I may go ahead and try this unit out in the near future
Build///Journal
IG: @Khan_Art_
Old Mon, Jul-31-2017, 05:21:01 PM   #200
Intune
Intune
Intune's Avatar
Reputation: 0 Intune is on a distinguished road
I installed the Xtron PB764BAP on Friday in my E46 M3. I have HK, non-factory nav. Using the information I learned from this thread, I ordered the antenna cable with the 90 degree bend. I could see that it is needed for clearance.
This thread mentions that two blue wires need to be connected to get the audio to work. I checked my harnesses for these two wires and could only find one, so I connected the radio without connecting any blue wires and the audio works fine. Maybe Xtron updated the radio and corrected this problem.
I previously had a Dynavin D99 installed. I used the mic and GPS cables from the D99 unit since I already had them routed. They both plugged into the Xtron without any issues and the navigation and mic seem to work fine.
I haven’t had enough time yet with the Xtron to give a detailed operational review, but so far what I have noticed is the unit is much faster than my D99 unit was.
Jump to top Intune is offline   Reply With Quote
Discussing Xtron PB7646BAP review in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
