Old Fri, Jun-09-2017, 07:09:37 PM   #951
IronJoe
IronJoe's Avatar
Reputation: 0 IronJoe is on a distinguished road
Default Re: SMG troubleshooting FAQ
Sorry to read your troubles I can't help you with your specific issue, but if I were you I would look into the rebuilt-pump option. When I thought my pump was dying I had considered going that route, and when it DOES eventually die I think I will replace the motor with a rebuilt one.
But make sure the pump is the problem first! There is a great deal of troubleshooting that can be done as I learned, just starting with my SMG in April.
http://eurtonelectric.com/catalog/mo...p_motor_repair
EDIT:
My recommendation would be first to buy the USB data cable and download the BMW reader software (several options available). That was you will not only be able to read the codes but can check up on the various sensors, etc. I was able to see exactly when my pump was turning on and how much pressure it was producing. Inexpensive DIY troubleshooting tool!
E30 M3 cabriolet build
Cosmos Black E36 M3 Sedan
Topaz Blue E46 M3 build journal
Jump to top IronJoe is offline   Reply With Quote
Old Fri, Jun-09-2017, 07:36:02 PM   #952
brichter
Unregistered Abuser
brichter's Avatar
Reputation: 0 brichter is on a distinguished road
Note that the above linked company only rebuilds the pump motor. You can get the motor and pump for a few bucks more here:
https://parts.bmwofsouthatlanta.com/...wd=&origin=pla
I just realized this is not the correct part for M cars! My bad!
2002 AW M3
Jump to top brichter is offline   Reply With Quote
Old Sun, Jun-11-2017, 12:49:28 AM   #953
UncleDad61
Reputation: 0 UncleDad61 is on a distinguished road
Thanks all for info and support, really appreciate it. Cable ordered, finally got Windows 7 x32 installed on my old mac (surprisingly a major PITA given that the cd drive is broken and Apple doesn't want to make booting from USB on laptops with CD drives easy... hopefully this part was harder than actually installing and using DIS/Progman).
Car's still sitting in the shop. They disassembled the intake box and got to the pump -- turns out there was a scrapyard pump installed that was undisclosed. I'm pretty peeved about that, because I now might have a crap pump with 120k on it that could go any time (even if this problem turns out to be something else). Still diagnosing what's going on. Could be an electrical thing -- relay light came on before the underpressure, overpressure, and no response codes came on. Changing the relay didn't do anything, and while I smelled burning when it died I suppose it could have been an electrical component BESIDES the pump's motor (maybe the pressure sensors, or just a wire somewhere).
It would be strange to go from seemingly fine to dead so fast if it were the pump motor, wouldn't it? I was able to do quick up and down gear changes just fine. Anyone know approximately how many bars of pressure are used per gear change? From what I read on the SMG service manual the normal operating range is 40-80.
Either way I really, really want to get the info on what the heck is going on with this pump.
EDIT: Yeah, pump's dead alright.
Jump to top UncleDad61 is offline   Reply With Quote
Old Wed, Jun-28-2017, 09:23:59 PM   #954
YellowDragon
YellowDragon's Avatar
Reputation: 0 YellowDragon is on a distinguished road
Taiwan
My 1st SMG pump failure was @ 70k miles. It was replaced with a BMW refurb part thru a BMW dealer.
Now @ 123k miles, it failed again and was replaced again.
It seems that the failure cycle is about every 60k to 70k miles.
With this rate I expect it to fail again @ 200K miles.
FYI, It's a 2002.
MENAGE A TROIS: 997 SPEED YELLOW GT3 & DAKAR YELLOW Z3 EXCLUSIVE EDITION & DAKAR YELLOW E46 M3 INDIVIDUAL
Jump to top YellowDragon is offline   Reply With Quote
Old Wed, Jun-28-2017, 09:29:22 PM   #955
DrLeadFoot
DrLeadFoot's Avatar
Reputation: 0 DrLeadFoot is on a distinguished road
My pump motor went out. Installed a new one and all is well.
Sent from my SM-G935V using Tapatalk
2003 SMG
///M3AN ONE's Headers, Billy Boat, TMS CF Intake, RE Elbow
SS brake lines, Performance Friction Pads, Slotted Rotors, ATE Super Blue
RE Spacers-10mm Rear 12mm Front
Red Line in Tranny and Diff
Zymol
Jump to top DrLeadFoot is offline   Reply With Quote
Old Thu, Jun-29-2017, 03:23:49 AM   #956
brichter
Unregistered Abuser
brichter's Avatar
FYI, It's a 2002.
145k on my 2002... got the motor sitting on the shelf in case it's needed.
2002 AW M3
Old Mon, Jul-03-2017, 11:27:29 PM   #957
Tove
They See Me Rollin'
Tove's Avatar
Reputation: 0 Tove is on a distinguished road
Thanks
BMW Enthusiast since 1987 | Tove aka Genuine
Jump to top Tove is offline   Reply With Quote
Old Thu, Aug-10-2017, 06:54:42 AM   #958
Sunny34
Reputation: 0 Sunny34 is on a distinguished road
United Kingdom
Could anyone shed any light on what Selector Lever Evaluation is?
Came up as a fault on my smg,tried goggle but
There's no real answer to what the fault actually is?
Thanks in advance
Jump to top Sunny34 is offline   Reply With Quote
Old Wed, Sep-06-2017, 02:17:41 AM   #959
turbosig
turbosig's Avatar
Reputation: 0 turbosig is on a distinguished road
Originally Posted by rve View Post
Yep, that's the hydraulic unit temperature sensor. You have an error code stored in the SMG computer saying "ON period, hydraulic unit (OBD II : P1717)" Happens in hot weather, I got it once for 3 years daily driving. If you turn off the engine while the SMG cog light is still on and then turn the engine on you'll get the Check engine light on as well though there's nothing wrong with it. Just a reminder that you need to connect your car to diagnosis software. As you have found out yourself all goes to normal after you let it cool. I've heard there a fix for that like installing additional thermistor in the temp sensor though I can't find that info out. I think it was spread over E46fanatics few years ago.
2004 Vert 98K and this finally happened to me. Drove today in NJ with temps in low 90's. At first Cog light came out, car drove and shifted just fine. Stopped the car for maybe 15 minutes to pick up my son and the Cog light was still on upon restarting the car, but now the SES light was on as well. Drove another 3 miles and the car fell out of 4th gear to N, was able to shift it back into gear almost immediately. Parked the car within 10 minutes from that and pulled the codes with my OBII reader. Got P1717.
I let the car cool down for a few hours. Started it again to pull it into the garage and the Cog light is off but SES still on. Pulled the codes again, same thing P1717.
I ordered a Salmon relay and will change that but wondering if any of you had experience with this and what your check list / troubleshooting solutions are after replacement of the Salmon Relay???
If it is the heat related sensor....its just very interesting as I use to drive this car on the 101 in LA during summer for years without any issues and the temps in the mid 90' degrees. Drive it in NJ where I lived for the past 7 years and this is the first time this has happened.
'04 M3 by way of Sunny SoCal to NJ/Philly
Jump to top turbosig is offline   Reply With Quote
Old Wed, Sep-06-2017, 02:38:44 AM   #960
brichter
Unregistered Abuser
brichter's Avatar
The sensor has probably shifted calibration just a bit due to age and now it triggers the issue. The temp isn't really that high when the code triggers normally (around 150-160f IIRC).
2002 AW M3
faq, smg, troubleshooting
Troubleshooting Codes AirDoc E36 M3 (1992-1999) 0 Sat, Nov-17-2007 04:49:53 AM
Troubleshooting a problem ----> HELP ! RoadShreader E36 M3 (1992-1999) 43 Sun, Dec-31-2006 08:05:57 PM
Eclipse Troubleshooting crazy32184 E36 M3 (1992-1999) 7 Thu, Jun-09-2005 08:03:15 AM
HELP PLEASE!!! Troubleshooting my ///M! M3nEwBoOtY E36 M3 (1992-1999) 6 Sun, Apr-03-2005 05:37:52 PM
Discussing SMG troubleshooting FAQ in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
