Old Fri, Nov-12-2010, 09:39:54 PM   #11
azndrunk74
Reputation: 0 azndrunk74 is on a distinguished road
Taiwan
so i had the upper control arm replaced. it was not necessary to remove/unbolt the rear diff and took the mechanic less than 2 hours to do.
surprisingly it also fixed the following additional issues i had before:
1) my rear passenger side would ALWAYS be much lower than the driver's side, i compensated for this by getting coilovers and had the sleeve adjusted all the way to the top (compared to midway for the driver's side). even then, it was still too low and i had to add an additional thicker spring pad to make it even aesthetically. after replacing the upper arm i had to lower the collar/sleeve back down a good inch and threw in the original spring pad to make it even again.
2) my rear passenger wheel could never align correctly. it would always toe out with anything less than -3 degrees camber. i replaced the OEM lower control arms with aluminum adjustables thinking they were bent, and the alignment was still no good. with the new upper arm, the camber has changed which leads me to believe the old upper arm was bent to hell. i am certain i can have it aligned correctly now (FINALLY, 3+ years later).
3) i always had this weird clunk/thud sound from the rear passenger side going slowly over speed bumps. i thought it had to do with my soft top mechanisms, the issue is now gone.
LSB|Cinnamon
Jump to top azndrunk74 is offline   Reply With Quote
Old Sun, Oct-16-2011, 12:37:36 AM   #12
e46coupee
e46coupee's Avatar
Reputation: 0 e46coupee is on a distinguished road
Default Re: well my rear spring perch ripped, question about removal of control arm
I'm just about to do this. I had the same issue. Hopefully this fixes it.
SILVER E36 M3 SOLD
IB on CINNAMON ///E46 M3 SOLD
DAKAR YELLOW E36 M3 SOLD
SG on LSB ///E46 M3
Jump to top e46coupee is offline   Reply With Quote
Old Fri, Oct-21-2011, 12:09:29 PM   #13
yamashek
@ttsad
yamashek's Avatar
Reputation: 0 yamashek has disabled reputation
congrats on the fix...
do you happen to have the pictures of the damage on your rear suspension arms?
were the coilovers installed according to its manual? if so, it will be a problem for other users with risks of ripping the rear control arm...
Jump to top yamashek is offline   Reply With Quote
Old Fri, Oct-21-2011, 05:47:50 PM   #14
azndrunk74
Taiwan
yes the coilovers were installed correctly.
dug around my computer and happen to have pics...
top view of ripped control arm
bottom view of ripped control arm
ripped control arm while still on the car...rubbing the axle
with the new arm and reinforcement plates installed
LSB|Cinnamon
Old Fri, Oct-21-2011, 05:54:56 PM   #15
Serious
Serious's Avatar
Reputation: 0 Serious has a spectacular aura about
Is it not possible to run the pss9 adjuster on the top of the spring (chassis side)? That's what you're supposed to do with all the other coilover systems due to aluminum control arms.
Jump to top Serious is offline   Reply With Quote
Old Fri, Oct-21-2011, 07:58:02 PM   #16
ferrarix99
ferrarix99's Avatar
Reputation: 0 ferrarix99 is on a distinguished road
When the subframe is down change all the bushings back there.
Edit: too late lol
click for pics of the old ride...
-Nick the Greek-
euro.techniks
Bimmerworld Epic Tune | OEM Euro Headers | CSL Brakes | CPI Rasp Term. V3 | B&B TriFlo | PSS10 | Varrstoen TE37 | ZKW Lens Swap
Want your car coded in the NY/NJ area? PM me.
Jump to top ferrarix99 is offline   Reply With Quote
arm, control, perch, question, rear, removal, ripped, spring
Discussing well my rear spring perch ripped, question about removal of control arm in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
