Old Sun, Feb-28-2010, 08:20:13 PM   #1
Stellaris
Stellaris's Avatar
Reputation: 0 Stellaris is on a distinguished road
Default shark fin removal
For anyone out there who has done this themselves, did you have any problem with denting once it was removed? And the method that you used. Also what did you do to remove the wire running up the beading?
2004 Jet Black M3 6MT
Linea Corse LM // KWv2 // CSL Bumper // CSL Diffuser // Depo Smoke Corners // JL Audio // Kenwood // Macht Schnell Spacers // Toyo T1R // AFE Stage 1 // Supersprint Race // 1x1 CF Interior Trim
Jump to top Stellaris is offline   Reply With Quote
Old Sun, Feb-28-2010, 09:54:55 PM   #2
lmtfi
lmtfi's Avatar
Do a Search for the thread of the same name earlier this week.
Old Mon, Mar-01-2010, 12:42:48 AM   #3
Stellaris
Stellaris's Avatar
thanks, just got it off. took about 30 mins because its 40 degress outside and took longer to get the metal hot. pulled the cord all the way out and unhooked it from the trunk so it can easily be replaced again if I need. Looks soo much better though
Old Wed, Jul-09-2014, 09:55:20 PM   #4
kokgo20
kokgo20's Avatar
Default Re: shark fin removal
Back from the dead, any one has pics that shows how it looks under the fin and the removal process?
Does that fine antenna has anything to do with bluetooth?
Build thread
Jump to top kokgo20 is online now   Reply With Quote
fin, removal, shark
Discussing shark fin removal in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
