Old Sun, Oct-16-2011, 01:27:34 AM   #31
suss1173
suss1173's Avatar
Reputation: 0 suss1173 is on a distinguished road
Default Re: rear coil spring removal and re-install help.....
Thanks to all the info in this post I was able to replaced my rear OEM springs today with new OEM springs. I did both in about 35-40 minutes.
I was able to undo the bottom of the shock and use a bar. For the reinstall it was easyest to get the top of the spring in first and then wiggle the bottom into place.
Jump to top suss1173 is offline   Reply With Quote
Old Sun, Oct-16-2011, 01:55:43 AM   #32
roarf
Jimmies: Not Rustled
roarf's Avatar
Reputation: 0 roarf is on a distinguished road
When I did the shocks and springs on my E36, I was doing the RTABs too so I had the RTAB carrier unbolted from the car. I think that helped a little too. My friend pushed on the trailing arm with his foot while I pulled the spring out.
'02 M5 - Carbon Black/Silverstone
'01 M3 - Imola Red/Black
Jump to top roarf is offline   Reply With Quote
Old Sun, Oct-16-2011, 05:06:12 AM   #33
JDMRRS
Reputation: 0 JDMRRS is on a distinguished road
Get yourself a broomstick.
Jump to top JDMRRS is offline   Reply With Quote
Old Sun, Oct-16-2011, 06:27:14 AM   #34
bh1976
Reputation: 0 bh1976 is on a distinguished road
Originally Posted by pjbm3 View Post
you don't need anything...remove wheel, unbolt bottom of rear shock, push down on rear rotor hat with your foot while holding onto the edge of the wheel well to get leverage, if the spring doesn't fall out by itself get someone to pull it out while you push down on the rotor...on reinstall, put the top rubber piece in the car first, push down on the rotor, put the new coil in, pull down on the rear shock until the holes line up and thread the bolt
I did this exactly.
Jump to top bh1976 is offline   Reply With Quote
Old Fri, Mar-08-2013, 11:29:44 PM   #35
forzanerazzurri
forzanerazzurri's Avatar
Is an alignment required after replacing the rear springs?
Old Sat, Mar-09-2013, 06:09:40 PM   #36
silbul
Reputation: 0 silbul is on a distinguished road
Is it necessary/recommended to disconnect the Xenon light level sensor on the right rear before attacking the right spring?
Jump to top silbul is offline   Reply With Quote
Old Sat, Mar-09-2013, 08:27:09 PM   #37
m3 hal
with stock? I probably wouldn't bother unless you haven't had an alignment in a while
I never have and I've r&r'd rear springs several times.
I did finally forget to disconnect the leveling arm on the front passenger control arm last time and broke it
Old Sat, Mar-09-2013, 09:29:34 PM   #38
5ABIVT
Reputation: 0 5ABIVT is on a distinguished road
I did the same. Both sides up in the air and both shocks unbolted. Springs just pulled out by hand :/
Jump to top 5ABIVT is offline   Reply With Quote
coil, rear, reinstall, removal, spring
Discussing rear coil spring removal and re-install help..... in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
