Old Mon, Apr-06-2009, 08:06:57 PM   #21
yjk1975
Reputation: 0 yjk1975 is on a distinguished road
If you reach in with your hands, you can just push it out from the back. After the vents are out.
Jump to top yjk1975 is offline   Reply With Quote
Old Mon, Apr-06-2009, 08:11:12 PM   #22
daytonaviolet
OEM CSL Whoore
daytonaviolet's Avatar
yeah.. u can do that and also weaken the area for your NAV as the dash board is made of cardboard.
Tischer aka GetBmwParts
Old Mon, Apr-06-2009, 08:18:28 PM   #23
AltF4
In for pics...
AltF4's Avatar
Reputation: 0 AltF4 is on a distinguished road
I tried that and couldn't ever get it pop out.
2002 E46 M3 ~ SMGII
VMR V710 : TR MT1 : ZCP Brakes : StopTech : PFC : AR20 : UUC / Corsa
Ground Control Susp/Sway : RE FCAB : DICE : BW : AFE : PF : DEPO : Scoops
Coby Wheel : Black Trimming : Custom Alcantera / Brushed Alum Dove Grey
Jump to top AltF4 is offline   Reply With Quote
Old Wed, Apr-08-2009, 06:18:01 PM   #24
CharlieTX
Reputation: 0 CharlieTX is on a distinguished road
Thanks to everyone for posting the information!
I'm stuck on the trim, but I think I just need to spend more time on it to convince myself I'm not going to break it. I haven't had the car a month yet, and its my first BMW new enough to use dealer service (the 1974 2002 was much easier to work on).
Jump to top CharlieTX is offline   Reply With Quote
Old Wed, Apr-08-2009, 07:07:52 PM   #25
AltF4
In for pics...
AltF4's Avatar
I feel your pain...I felt like I was going to break something when I went through this too!
Just be cautious and deliberate. Start popping the trim above the glove box from the side next to the passenger door. Pull gently but firm and you'll see what I mean. It pops right out.
Good luck!
Brian
2002 E46 M3 ~ SMGII
Old Sun, Apr-19-2009, 05:53:35 PM   #26
smiling M3
smiling M3's Avatar
Reputation: 0 smiling M3 is on a distinguished road
Default nav monitor removal
Hi all,
Can the monitor part of the nav be replaced without removing the entire unit from the dash? I have a bad scratch on the screen and found the part to replace it. What is involved?
Thanks, Jim
Jump to top smiling M3 is offline   Reply With Quote
Old Sun, Apr-19-2009, 06:27:22 PM   #27
daytonaviolet
OEM CSL Whoore
Originally Posted by smiling M3 View Post
Hi all,
Thanks, Jim
you have to remove the nav screen head unit out of the dash
Old Sat, Feb-27-2010, 03:53:48 PM   #28
GEO147
M3 Noob!
GEO147's Avatar
Reputation: 0 GEO147 is on a distinguished road
Ireland
Tried to remove Nav last night. Removed the trim, screws and vents and couldnt find the 2 "slots"that you need to insert the hanger or file into to release the unit.
Where the hell are they??
Jump to top GEO147 is offline   Reply With Quote
Old Sat, Feb-27-2010, 04:33:30 PM   #29
smileygladhands
Friendly Neighbourhood User
smileygladhands's Avatar
Reputation: 0 smileygladhands is on a distinguished road
my nav came out without having to use the tools...
my question tho, what part# are you guys w/nav using for the aux input? I ordered the OEM aux input kit part# 82110149389 and it doesn't seem to be compatible with my early '03 nav unit.
formerly: e36 M3, e46 M3, e90 335i, crown & coke
currently: e46 Touring, Nissan Pathfinder, BabyTrendz Stroller, sippy cup w/apple juice
Jump to top smileygladhands is offline   Reply With Quote
Old Sat, Feb-27-2010, 04:43:49 PM   #30
AltF4
In for pics...
AltF4's Avatar
I have an 02 Nav and needed "tools" to actually remove the unit. The two slits you're looking for are accessed by opening the face of the unit, like you're going to put a tape or CD in (depending on your year). Then in the short time
you have until the face wants to close again slide the two tools or in my case the metal nail filers into the unit just under the bottom of the screen flat at both edges. The unit should then be able to be pulled out.
Sounds more complicated than it is...
2002 E46 M3 ~ SMGII
e46, navigation, removal
HELP - E46 M3 Navigation Removal biglar Audio/In Car Entertainment (I.C.E.) 4 Fri, Mar-14-2008 04:16:21 AM
e46 Navigation Software FTR M3 E46 M3 (2001-2006) 1 Fri, Dec-28-2007 01:04:42 AM
E46 Navigation vs. iDrive ZeroG E46 M3 (2001-2006) 3 Sun, Jul-29-2007 08:19:12 PM
Stock Navigation removal apexapex Audio/In Car Entertainment (I.C.E.) 5 Sat, Jan-21-2006 04:43:23 PM
e46 navigation removal Thunberg E46 M3 (2001-2006) 3 Fri, Jul-02-2004 08:39:55 PM
Discussing HELP - E46 M3 Navigation Removal in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
