Old Fri, Dec-08-2017, 06:50:13 PM   #11
BeerHat
BeerHat's Avatar
Reputation: 0 BeerHat is on a distinguished road
Default Re: M3 axle bolts, stock are longer???
Originally Posted by BeerHat View Post
The replacements DO have locking teeth, just not all that visible through the bag. I may have to take a trip down to the dealer. This is a buncha crap.
The bolts I pulled are 50mm, the replacements are 46mm.
It appears I somehow have '95 M3 spec bolts in my 8/96 car. Correct part number according to realoem is 33211227279. These are M10x50mm.
Hope this saves someone some time, I've wasted a ton.
Dan
Jump to top BeerHat is online now   Reply With Quote
Old Fri, Dec-08-2017, 07:40:27 PM   #12
BeerHat
BeerHat's Avatar
What is the length on the new bolt?
BMW consolidates parts, usually superceeding older models with new model parts. Usually it is just a simple coating change (yellow zinc to ZNS3 zinc flake for example) but it’s becoming more common for the parts to be completely different.
I figured it out.
33211227279 M10x50mm (used on '95 M3)
33211227664 M10x46mm (96+ M3)
My car's diff, 08/96 build date, was apparently assembled using the pre-96 model year bolts.
The crappy part, those older axle bolts are like 20+ bux each now (not including shipping) everywhere I look, including dealer.
Anyone got any extra '95 diff bolts layin around they'd like to donate? :O)
Dan
Old Fri, Dec-08-2017, 08:00:08 PM   #13
No, your 1996 is correct. 95 to very early 97 the rear ends are all 6-bolt CV driveshafts with solid axles. Sometime in 97 they switched to 4-bolt dual ujoint driveshaft and hallow axles.
It’s the ETK that is wrong. Normally it’s accurate, so good catch going back to 95 for the different length.
FYI your driveshaft tail end is identical to Euro. 6-speed swaps are easy, just switch the front half of the shaft.
Old Fri, Dec-08-2017, 09:51:02 PM   #14
Buy the Mini Cooper version for $5 each. Mini 32106774042. Google is great.
Old Fri, Dec-08-2017, 11:30:44 PM   #15
Bimmerman325i
Beardface McMountainMan
Bimmerman325i's Avatar
Yup, those bolts are expensive.
I went with a set of bolts from McMaster, because $20 for a bolt is ridiculous.
pics from build thread:
These are obviously not OEM, but were $20 total for both sides of the diff (I think I bought 20 bolts)
1998 BMW M3/4/5 -- DD rev1
Jump to top Bimmerman325i is online now   Reply With Quote
Old Sat, Dec-09-2017, 12:03:24 AM   #16
BMW switched away from allen cap bolts in favor of E-Torx. They easily deform and strip out. I would stick with E-Torx.
Old Sat, Dec-09-2017, 12:04:47 AM   #17
Bimmerman325i
True, and a fair point.
Old Sat, Dec-09-2017, 08:49:16 PM   #18
BeerHat
BeerHat's Avatar
Hey so it looks like ONE of the old bolts you removed was the newer style!
Old Mon, Dec-18-2017, 04:06:52 AM   #19
englishtom1596q
englishtom1596q's Avatar
Almost every other manufacturer with this style of axle uses Allen cap bolts. They're fine as long as you use the correct Allen and seat it fully. I switched to them also because I got them for the GKN axle and bearing facility my buddy works for and were at a 5 finger discount. They're also easier to access because you the Allen socket gives more room from the boot.
Old Mon, Dec-18-2017, 04:12:33 PM   #20
JitteryJoe
You can get a complete set with reinforcement plates from ECS for 134.00
https://www.ecstuning.com/b-genuine-...33211227664kt/
Discussing M3 axle bolts, stock are longer??? in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
