Old Mon, Jan-11-2016, 05:58:47 PM   #1
VailM3
VailM3's Avatar
Reputation: 0 VailM3 is on a distinguished road
Default 2017 E-Class
Once all the “OMG, it looks like a larger C-Class/smaller S-Class” Internet comments start to die down, the 2017 Mercedes-Benz E-Class should settle down as the first sedan in Stuttgart to encompass some downright scary technology features in a rather recognizable body.
Sure, the overall exterior design is a bit too cookie cutter for some people, but Mercedes-Benz will try to address this issue by offering up to four different design lines, depending on which side of the Atlantic Ocean the model is sold.
The base model in Europe, which is also set to soon become Germany's favorite taxi, will feature the classic Mercedes-Benz grille with the three-pointed star on the hood, similar to the so-called Exclusive line, which will add a few more luxurious details. Both the Avantgarde and the AMG Line have a sportier engine grille, with a much larger three-pointed star sitting right in the middle.
In the United States, only two design lines will be offered, with the Sport line being the equivalent of the Avantgarde/AMG line in Europe while the Luxury version will be quasi-identical with the Exclusive line on the Old Continent.
Thanks to an increase in both wheelbase and length, the 2017 E-Class W213 should provide slightly better accommodation to its passengers. The length has increased from 192.1 in (4880 mm) to 193.8 in (4923 mm) while the wheelbase has jumped from 113.1 in (2874 mm) to 115.7 in (2939 mm). Of course, some of those extra inches have also gone to the much longer hood, which is set to cover at least a pair of inline-sixes in a couple of years or so.
The interior design harmoniously blends the two wide screens similar to those found in the S-Class with the flowing center console of the C-Class, the result being at least two generations ahead of the W212 E-Class. For the first time in a production car, Mercedes-Benz has gifted the E-Class with a steering wheel that has touch-sensitive control buttons, which can respond to vertical or horizontal swiping gestures just like a modern smartphone.
Due to LED technology, you can choose from no less than 64 colors for the interior ambient lighting system, while the optional Warmth and Comfort package includes heated armrests, center console, steering wheel and rapidly-heating front seats.
Powertrains and suspension
In Europe, the first E-Class W213 models will have four engines to choose from in the beginning. On the gasoline front, the E 200 has a turbocharged 2.0-liter, four cylinder with 184 hp and 300 Nm (221 lb-ft) of torque, while the E 250 e is a plug-in hybrid that pairs a turbocharged 2.0-liter, four cylinder with an electric motor for a combined 279 hp and 600 Nm (442 lb-ft) of torque.
As far as diesel goes, things are just as interesting, as Mercedes-Benz has finally replaced the old 2.1-liter four-cylinder with an entirely new unit. Therefore, the E 220 d will come with a 2.0-liter diesel that delivers 195 hp and 400 Nm (295 lb-ft) of torque. Those wanting a bit more oomph will be met by the E 350 d, with the familiar 3.0-liter diesel developing 258 hp and 620 Nm (457 lb-ft) of torque.
A few months after the start of production, the new E-Class will also get E 250, E 300 and E 400 gasoline versions, while the new 2.0-liter diesel will also get a slightly less powerful version for the E200 d model.
In the U.S., only a 2.0-liter turbocharged four-cylinder will be available in the beginning in the E 300, but more versions will arrive shortly after, including a diesel, despite the crash that the diesel market suffered because of VW's Dieselgate. All engines available at the start will be paired exclusively with the 9G-Tronic nine-speed automatic transmission.
No less than five types of suspension will be available, with the standard model featuring steel springs. Three Direct Control types of suspension with selective damping systems are available with the steel-springed version: a Comfort suspension, a slightly sportier Comfortable Avantgarde suspension that is lowered by 15 mm, and a Sporty suspension with adaptive damping, which replaces the sports suspensions from the previous E-Class. Those with deeper pockets can opt for a fifth type of suspension, since the new E-Class W213 can also be equipped with the only multi-chamber air suspension in its segment.
Gadgets for everyone
The biggest changes compared to the previous generations revolve around the new semi-autonomous features. By far the most impressive one is the Drive Pilot, which can allow the E-Class to follow the car in front at speeds of up to 210 km/h (130 mph), automatically braking and accelerating, while the Steering Pilot can take care of moderate bends without driver intervention.
A Speed Limit Pilot sub-function can autonomously adjust the car's speed in response to speed limits that were either detected by a camera or already logged in the navigation system.
The Active Lane-change Assistant is a radar- and camera-based system that can automatically steer the car into the lane selected by the driver. If the lane is unoccupied and the driver has indicated the turn for more than two seconds, the car will steer on its own into the adjacent lane when overtaking.
Another interesting feature is the Remote Parking Pilot, which needs a smartphone app to allow the car to be moved into and out of garages or parking spaces remotely. From the first info available, it seems that the system is somewhat similar to the one recently introduced by Tesla on the Model S as a “summon car” feature.
While it was introduced back in 2013 as a retrofit solution, the Car-to-X communication feature comes fully integrated from the get-go into the new E-Class. The mobile phone supported system allows information to be shared with other vehicles so that the driver is prepared in case there's an imminent danger ahead, with the car acting as both a receiver and a transmitter.
Pre-Safe gets two new extra features as well, both being downright futuristic. The Pre-Safe Impulse Side comes as part of the Driving Assistance Plus package. If a lateral collision is detected as being imminent, the driver or front passenger is moved away from the closest door in a fraction of a second by way of an inflatable chamber in the side bolster.
Pre-Safe Sound is just as impressive, as it emits a short interference signal through the car's sound system if the risk of an imminent collision is detected. Thanks to the so-called “stapedius reflex” in the inner ear of a human, the signal can trigger the passengers' natural reflex and prepare their ears for the unexpected sound of the crash.
The Multibeam LED lights first introduced on the facelifted CLS-Class are present on the new E-Class as well, only this time they each consist of 84 individually controlled LEDs, which allow the light distribution to adapt to any driving condition.
Thanks to the implementation of Near Field Communication (NFC) technology, the driver's own smartphone can be technically used as a key.
Last but certainly not least, it seems that the new E-Class will again become the most aerodynamic sedan in its segment, with certain versions having a drag coefficient value of just 0.23. This should, of course, improve fuel consumption at higher speeds and also give the model a quieter interior.
Jump to top VailM3 is offline   Reply With Quote
Old Mon, Jan-11-2016, 06:16:30 PM   #2
AutoUnion
AutoUnion's Avatar
Reputation: 0 AutoUnion is on a distinguished road
Germany
Default Re: 2017 E-Class
Beautiful interior! Exterior is expected. Excited for the AMG. Digging that green
After seeing that all the Benz sedans look nearly identical, people need to STFU about Audi styling. One design, 3 lengths
Jump to top AutoUnion is offline   Reply With Quote
Old Mon, Jan-11-2016, 06:25:41 PM   #3
HelloNewman
( ͡ ͜ʖ ͡)>⌐■-■
HelloNewman's Avatar
Reputation: 0 HelloNewman is a glorious beacon of lightHelloNewman is a glorious beacon of light
Way too in your face for my taste, but I can see how some would like it.
Jump to top HelloNewman is offline   Reply With Quote
Old Mon, Jan-11-2016, 06:59:25 PM   #4
chsbmw
Reputation: 0 chsbmw is on a distinguished road
Looking forward to seeing the AMG treatments.
Jump to top chsbmw is offline   Reply With Quote
Old Mon, Jan-11-2016, 07:03:16 PM   #5
Rakshas
Rakshas's Avatar
Reputation: 0 Rakshas has a spectacular aura about
Would have preferred a unique taillight, but it looks good just like the other two lengths and i'll take it over outright frumpy ala F10.
Interior is best in class.
Jump to top Rakshas is offline   Reply With Quote
Old Mon, Jan-11-2016, 07:13:13 PM   #6
M3Dom
M3Dom's Avatar
Reputation: 0 M3Dom is on a distinguished road
car will be the best bang for the buck in its class. S class for 1/2 off
https://www.instagram.com/d_sicily/
Porshapwr:I thought every day was steak and BJ day?
Ghost : "She'll prolly suck your balls so hard they'll hatch"
Ben Z.;The Ultimate Driving Simulation Machine
LALaw :OP has been surprised by everything that's happened since the 13th Amendment
Cars : some verts some bikes and a 2012 veyron
Jump to top M3Dom is offline   Reply With Quote
Old Mon, Jan-11-2016, 09:25:24 PM   #7
StJamesM
Store Bay
StJamesM's Avatar
Reputation: 0 StJamesM has disabled reputation
Trinidad and Tobago
thought the same at first, then realized.... a unique taillight/rear would mean it would need a coupe of its own...or we'd then question the lack of the Ecoupe at the very least.
since they've done away with the Ecoupe; and since the Ccoupe replaced it, it makes sense why they kept it as it, with obvious minor touches.
doesnt look tremendously nicer than the 5er IMO, but its certainly a level/equal alternative across the board... AMG version may look overly-refined, considering how plain the C's AMG has ended up..
that said, my prediction: M5 > this AMG, but current E-AMG over both..
will need to see BMW's update to the current 5er still.
'99 e36M-5mt
'12 e92M-6mt
Akrapovic Evolution Titanium Exhaust [no Cats], GruppeM Intake, Evolve-R ECU, Eriscsson front bumper, Ericsson Amuse trunk lid, Strasse forged SM8, Bilstein B12 sportline
past
- F355GTS-6mt
- JCW CooperS
in a perfect world i'd have a singer and a fully restored goat, period
Jump to top StJamesM is offline   Reply With Quote
Old Mon, Jan-11-2016, 10:03:27 PM   #8
EKaru
EKaru's Avatar
Reputation: 766 EKaru PorshaEKaru PorshaEKaru PorshaEKaru PorshaEKaru PorshaEKaru PorshaEKaru Porsha
Yep, all of that...
Bystander: "Hey is that a C-class, e-class, or s-class? Who knows, all I know is that it's a Benz and it looks good."
Jump to top EKaru is offline   Reply With Quote
Old Mon, Jan-11-2016, 11:51:13 PM   #9
white out
ohite wut
white out's Avatar
Reputation: 0 white out is on a distinguished road
I don't like the roundness of this and its little brother. Good looking car, just not as good looking as the last model.
Jump to top white out is offline   Reply With Quote
Old Tue, Jan-12-2016, 12:10:49 AM   #10
cornerjunkie
I wake up every morning and piss excellence.
cornerjunkie's Avatar
Reputation: 0 cornerjunkie is on a distinguished road
I love it.
'02 DINAN M3-RIP
'03 Steel Gray M3
Jump to top cornerjunkie is offline   Reply With Quote
Discussing 2017 E-Class in the Off Topic Forum - Place to discuss this and that. Note: We also have "request to join" forums: Guns and Fitness.
