Old Thu, Apr-15-2010, 06:27:54 PM   #11
rkmM3
Reputation: 0 rkmM3 is on a distinguished road
checked for the code again and its gone. also when i hit the gas pedal when the car is off i hear a squeak from the engine back its the thing that opens the TB's...i think it may need some lubing b/c i think it got stuck when i was driving for like a split second and i was off the gas.....i need to call bmw and ask them why my car isn't a Camry and my **** got stuck :
i think it needs some lube on it.
Jump to top rkmM3 is offline   Reply With Quote
Old Thu, Apr-15-2010, 07:04:52 PM   #12
AUTOB0T
AUTOB0T's Avatar
Reputation: 0 AUTOB0T is on a distinguished road
I had the same issue over the winter, i replaced the tps on the front of the engine right above the oil filter... checked my tb's and everything works like a charm now..
Maverik
"keep your eye on the horizon"
Jump to top AUTOB0T is offline   Reply With Quote
Old Sat, Apr-17-2010, 01:17:11 AM   #13
rkmM3
I have read we have a few TPS's which one would be associated with my code?
ok got EML again, is it my TPS above the oil filter or the one on the pedal?
Old Sat, Apr-17-2010, 03:54:33 AM   #14
rkmM3
bump.
Old Sat, Apr-17-2010, 05:24:55 PM   #15
playskool1
NorCal's S54 S65 S85 Rod Bearing spc.
playskool1's Avatar
Reputation: 0 playskool1 is on a distinguished road
Originally Posted by HammerMan View Post
I just went through this same issue a couple weeks ago. I would order the parts and get them replaced. You can temporarily resolve the issue by restarting your car but in my case the issue got worse and worse with time. I would get the EML Light, DSC and amber break light and limp mode more than once. I replaced both the front TPS sensor and the gas pedal. Part numbers are below:
TPS Pedal:
35426772706 - $112.82
Throttle Valve Switch:
13631402143 - $81.28
getbmwparts.com
i did the exact same thing. first i replaced the front TPS near the oil filter and it did not resolve my limp mode problem. shortly after i replaced the gas pedal potentiometer and never went into limp mode again.
IIRC the gas pedal potentiometer is a newer revision from 2008 in replace of my 2001 pedal potentiometer.
01/01 build date[LSB][Cinn.][6 Spd.]MAXIMUM PSI TURBO 14psi PT6266 [230k total miles][original motor]
[115k supercharged miles][17k E85 miles][9k turbocharged miles][1.9k track miles]
INSTAGRAM: @skweakykleen
Full Beisan VANOS overhaul, TMS Subframe Reinforcement, WPC rod bearings = bulletproof
fully built S54 w/ Precision 6870 coming soon!
Jump to top playskool1 is offline   Reply With Quote
Old Mon, Apr-19-2010, 10:34:53 PM   #16
siasimba
Reputation: 0 siasimba is on a distinguished road
Funny topic, I was driving today after getting car serviced from bmw and all of a sudden 4 lights came on:
1. Engine service soon
2. EML
3. Yellow Brake light
4. DSC
I restarted the car and only "engine service" came on... Then as I was driving the EML and DSC came on again. restarted engine again and only "engine service" was on. Did not feel any lack in power, but I was only going 30mph top.
I drove my car back to BMW which was a mile away to get it serviced. I will ask them exactly what the issue is when I get my car back. My warrenty should still cover the problem you think?
BTW... I just installed angel eyes on my car, you don't think that has anything to do with it right?
Jump to top siasimba is offline   Reply With Quote
Old Mon, Apr-19-2010, 10:53:59 PM   #17
rkmM3
I dont think so...but i left my radar in, and it stays on...so i dont know if voltage has to do with it...my radar stays on if the car is off....im not sure if thats the case....thats the only new thing i have noticed with my car, i have cleared it my second time if it comes on again im taking it to the indy. i read some posts that it can be a glitch...so we'll see...keep me posted on your issue.
Old Thu, Apr-22-2010, 01:43:13 AM   #18
siasimba
So got my M3 back from the dealer today. They were nice enough to give me a free car wash. Too bad it was raining outside anyways.
Issue with the problem was throttle more specifically they mentioned about the potentiometer.
They replaced the throttle and test drove my car, now everything is working fine.
They did not say anything about TPS replacement.
All work was covered under warrenty, however, they charged about 600 bucks as I noticed on receipt.
Old Thu, Apr-22-2010, 02:12:54 AM   #19
JohnA
Greenhill Zone Act 1
JohnA's Avatar
Reputation: 0 JohnA is on a distinguished road
seems like this is happening ALOT, wish BMW had a service bulletin for it
Jump to top JohnA is offline   Reply With Quote
Old Tue, May-18-2010, 01:15:31 AM   #20
jrf313
Reputation: 0 jrf313 is on a distinguished road
I just picked my '06 M3 Coupe MT from the dealer. Had the exact same issue.
EML
Service Engine soon
Yellow Brake light
DSC light
limp mode
restarted a few times and limp mode went away. Got it to the dealer.
Replaced 2 Throttle Valve Switches (potentiometers) (both had many faults stored) under warranty.
part number 13-63-7-840-383 (qty 2)
Jump to top jrf313 is offline   Reply With Quote
dsc, eml, light
Discussing EML light then DSC light... in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
