Old Sun, Jul-21-2019, 07:22:55 PM   #1
Cubieman
Reputation: 0 Cubieman is on a distinguished road
Default Thump sound when putting car in gear
Every so often when I put my car into 1st gear when ready to depart from a stoplight I hear a thump from the trunk area. It's not an extremely loud sound, but it's enough to take notice. Someone told me it's my trunk floor flexing...huh?
I have a 2004 and subframe has been reinforced.
I've also heard this noise when shifting into higher gears on occasion but it seems to be most pronounced when putting it into 1st. Doesn't happen all the time so its kind an intermittent deal. Seems to happen more often after the car has been driven hard.
Jump to top Cubieman is offline   Reply With Quote
Old Sun, Jul-21-2019, 07:31:41 PM   #2
Drewster
Drewster's Avatar
Default Re: Thump sound when putting car in gear
At a stop light? Every manual car does this.
Essentially, when you're sitting at a light in neutral, foot off the clutch, it means the crank, flywheel, clutch, and input shaft are all spinning at the same speed. When you clutch in and pop the car into first, the inertia of the still-spinning clutch and input shaft makes the trans and driveshaft go "thunk" as the synchros dissipate that energy and bring everything to the same speed (0).
If you're saying it happens as you let off the clutch and apply power, you likely have a trashed bushing somewhere either on the diff/ driveshaft/ etc. and should check it out.
Old Sun, Jul-21-2019, 07:45:53 PM   #3
Cubieman
It's just when I put my foot on the clutch and put it into 1st gear. Just strange to me that it's an intermittent deal.
Old Sun, Jul-21-2019, 07:52:02 PM   #4
cgeromi
Reputation: 0 cgeromi is on a distinguished road
Little trick I do with all manual transmissions is from a dead stop I cycle into 2nd gear then into first. Definitely relieves any stress compared to just putting her into 1st. I've owned many many 5 speed cars and all have made it past 250k miles with no synchro issues.
Also if first is a little wonky I'd dump the gear oil and go with some fresh. Never hurts.
Sent from my ONEPLUS A6000 using Tapatalk
Jump to top cgeromi is online now   Reply With Quote
Old Sun, Jul-21-2019, 08:35:59 PM   #5
Drewster
Drewster's Avatar
It probably corresponds to how much of a hurry you're in, but it might not hurt to bleed the clutch slave if you've never done it (with the assumption that the clutch isn't 100% releasing)
Old Sun, Jul-21-2019, 10:19:31 PM   #6
mainstreamer00
mainstreamer00's Avatar
Reputation: 0 mainstreamer00 is on a distinguished road
Another "M-Clunk" sighting.
Jump to top mainstreamer00 is offline   Reply With Quote
Old Sun, Jul-21-2019, 11:18:36 PM   #7
Joshe46
Joshe46's Avatar
Good thing you dont own an smg lol. You’d be terrified!
Jump to top Joshe46 is offline   Reply With Quote
Old Mon, Jul-22-2019, 12:27:56 AM   #8
Kurty
Reputation: 0 Kurty is on a distinguished road
I think 1st gear is straight cut gear not synro. Same with reverse. Someone correct me if im wrong. What you hearing is normal.
Jump to top Kurty is offline   Reply With Quote
Old Mon, Jul-22-2019, 01:28:13 AM   #9
Cubieman
This may not be best practice, but many times I will downshift from 4th 3rd when comming to a stop then just put it into neutral and coast on up to the light. I only do this when I know its going to a be a long light etc.
It's always been put into my head, brake pads are cheaper than clutches...
Old Mon, Jul-22-2019, 01:38:08 AM   #10
Aeko
Aeko's Avatar
Reputation: 0 Aeko is on a distinguished road
I do this as well when doing lots of stop-and-start through stop signs etc. The trans doesn't want to go directly into first because of the clutch inertia Drewster mentioned.
Check your diff bushings. Mine are shot and every time I take off too quickly or change speed (slowing down in gear) it clunks really loudly. Currently not driving it until I get the time to pull the diff and replace them.
If you wanna make REAL donuts, run Crisco in your diff.
Jump to top Aeko is offline   Reply With Quote
Discussing Thump sound when putting car in gear in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
