Old Sun, Jul-21-2019, 12:50:37 AM   #1
SQ13
Default PSA: Check your bolts/nuts frequently
I was at COTA yesterday and experienced brake failure during one of the sessions. Turns out, the lower bolt for the RR caliper carrier worked its way loose. See pics for the end result.
I wear earplugs and didnít hear anything until the checkered flag came out. I went through my video and, again, didnít hear anything until the checkered flag came out. Iím lucky the brakes kept working and that I didnít crash or anything.
Last time I worked on the rear brakes was back in August 2018, so I couldnít tell you if I forgot to torque or not. But I feel like I did torque given that my procedure for brakes is to torque two times right after the bolt goes on. Maybe I shouldíve used loctite. Regardless, itís my fault for not checking the bolts before going on track. My plan now is to torque literally all hardware and mark them with a paint pen before I drive the car again, check the pen marks every 3 or 6 months, and retorque annually. Just an FYI so you donít have to experience what I did.
On another note, I experienced pad knockback for the first time. I didnít think it could happen with stock calipers and my pace. I thought my front bearings might have been going bad, but maybe th RR caliper caused it. Idk
Old Sun, Jul-21-2019, 01:27:12 AM   #2
foolio
40oz. to Freedom
Reputation: 0 foolio is on a distinguished road
Default Re: PSA: Check your bolts/nuts frequently
Hard to tell from the pics but I would check that wheel carefully to make sure that caliper dragging didn’t start to machine it in half.
______________________________________________
1981 BMW 320is - 5MT - Polaris/Black
2001 BMW 325xiT - 5MT - TiAg/Grey Leather - ZPP, ZSP, ZCW, NAV, PDC
2002 BMW M3 - SMG - TiAg/Black Leather - KWV3
2003 BMW M3 - SMG - Laguna Seca Blue - Track car, track stuff
Jump to top foolio is offline   Reply With Quote
Old Sun, Jul-21-2019, 01:59:17 AM   #3
Metro81
Reputation: 0 Metro81 is on a distinguished road
Woah, same thing that happened to me at VIR on Memorial Day only it was my front right. I hadnít worked on the brakes since February and had two events before my Ďincident.í Like you I plan to torque and mark all the bolts/fasteners I can get eyes on - one of my buddies has a safety wire tool and has been looking for an excuse to use it!
TTFS | CPI | RE | APEX | PFC | KW | GC | CSF | KoyoRad | BimmerWorld | Hard Motorsports | Status Gruppe | n15DESIGN | RaceWerks
Jump to top Metro81 is offline   Reply With Quote
Old Sun, Jul-21-2019, 02:17:04 AM   #4
ThunderMoose
Had the exact same thing happen to me at WGI last July. I think mine was LR. I got away with just a bracket. Inside of my rim looked like yours.
#67 2017 NASA TX TT3 Champion
Old Sun, Jul-21-2019, 03:12:28 AM   #5
AXDB
AXDB's Avatar
Reputation: 0 AXDB is on a distinguished road
I paint pen everything as I check it. Touch every bolt I can before every event. Not re torquing. But inspection of paint mark and making sure it didnít back a perfect 1 full turn.
2003 M3 Carbon Black / Cinnamon
Jump to top AXDB is offline   Reply With Quote
Old Sun, Jul-21-2019, 05:40:09 AM   #6
Exclusivs
Exclusivs's Avatar
Reputation: 0 Exclusivs is on a distinguished road
Whereís the ideal place to Mark?
Or does everyone have preference. Iíd think 12oclock?
OP glad wasnít anything more severe.
Jump to top Exclusivs is offline   Reply With Quote
Old Sun, Jul-21-2019, 06:03:58 AM   #7
SQ13
Maybe retorquing everything is an overkill. I'll probably do critical components like brakes and studs anyways, and just check the others as AXDB does.
Where would you tie the safety wire?
Did you end up reusing the wheel? I was thinking I shouldn't use mine for anything other than a decoration piece.
My rear calipers are probably due for a rebuild, so I'm buying rebuilt calipers. They're only $75 ea.
Old Sun, Jul-21-2019, 10:58:46 AM   #8
ThunderMoose
I reused mine.
Old Sun, Jul-21-2019, 12:04:38 PM   #9
AXDB
AXDB's Avatar
Doesnít matter. Just mark on the bolt and on the chassis.
Old Sun, Jul-21-2019, 12:17:47 PM   #10
bigjae1976
Use red loctite for the caliper bracket bolts despite BMW not specifying it.
Only drawback is it wonít be fun removing the bracket. Really canít get a breaker bar or a torch in there. Just gotta be a man and get it off.
I just use my cheap ratchet and bang the handle with a small sledge.
Oh...and replace those bracket bolts periodically.
2013 F30 328i - Melbourne Red
2004 E46 M3 - Imola Red
Discussing PSA: Check your bolts/nuts frequently in the M3 Track: Racing and DE Forum - Best mod for speed is learning to get the most out of what you currently have. Tracks and DE's is the place to start! at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
