Old Sun, Jul-14-2019, 09:55:11 PM   #1
M3 dude
Default shimmed power steering pump
hi all,
in preparation for upcoming trackwork i've decided to shim the pressure regulator in my steering pump according to Volke's guide. i've got an old pump lying around so i've pinched the shims off that.
just added 1 shim to begin with.
1. was there a pump bleed procedure i missed (lol)? lost all steering assist for like 5-10 mins. no weird noises from pump so i'm thinking nothing's permanently damaged. steering assist came on in dribs and drabs. seems ok now.
2. to those who've done it, your long term impressions?
i'm still getting used to the new weighing and assist...
thanks
Old Sun, Jul-14-2019, 10:05:55 PM   #2
bigjae1976
Default Re: shimmed power steering pump
Thereís no priming procedure since the pump is a PD gear pump.
Itís a good balance of increased effort and feel without being a torturous arm work out. I do feel some tiredness in my arms a little at the end of the day but not bad at all. Kind of like I did a light arm workout.
2013 F30 328i - Melbourne Red
2004 E46 M3 - Imola Red
Old Thu, Jul-18-2019, 07:33:39 PM   #3
BBRTuning
BBRTuning's Avatar
Reputation: 0 BBRTuning is on a distinguished road
thanks
Wow, that much of a difference from one shim? I just re-assembled mine with 3 Volke shims (in addition to the factory one) and was going to put it back in the car today. Wonder if I should have started with one or two..
///BBRTuning | 2001 LSB M3 6MT | AEM Infinity + flex fuel | JE 11.5/Carillo S54 | Streamline CSL box | Dbilas 288/280 cams | Moton 3WR rear coilover, 700/500 | Stoptech Trophy BBK 6F/4R | Slicer-spec BBS RIA Japan 18x10.5 et22 (x4) | BMW M 4.10 | Turner monoball FCAB/RTABs | Turner lower-rear + Wisefab upper arms | Z3 rack | Lang Racing CF roof | full interior 3310lb wet
-- @bbrtuning --
Jump to top BBRTuning is offline   Reply With Quote
Old Thu, Jul-18-2019, 07:45:56 PM   #4
Steve M3
I bled my new rack by turning the wheel from lock to lock slowly with the engine running. I also left the cap open while doing this. Didn't have any issues or weird things happen once it was back on the ground.
Jump to top Steve M3 is online now   Reply With Quote
Old Sun, Jul-21-2019, 10:36:30 PM   #5
M3 dude
did that for rebuilt rack also.. but dry pump doesnt seem to like it. all ok now.
the shimmed pump was really good at the track though. less strain on power steering system (but a little more on my arms)
Old Mon, Jul-22-2019, 02:54:53 PM   #6
BBRTuning
BBRTuning's Avatar
Interesting, I barely noticed the effect from adding 3 shims.. I’d be surprised if it changed more than 10-15%. I’m pretty sensitive to stuff like that on this car so it’s odd it changed so little. I didn’t have a problem with bleeding, just filled the reservoir, turned the wheel a few times and topped it off again (to the fill line of course).
Guess I’ll be adding another shim or two..
-- @bbrtuning --
Old Mon, Jul-22-2019, 03:35:48 PM   #7
I forget how many shims I used, but I did whatever it is that results in a 25% assist reduction. I found it noticeable immediately! Not regrettable, but certainly perceptible.
Old Mon, Jul-22-2019, 06:21:12 PM   #8
bigjae1976
I think Iím at the max allowed shimmage...
Is that a technical term? Lol
Love it. I also deleted the cooler and expansion loop. It hasnít given me any issues even with 135 degree track surface temps.
Discussing shimmed power steering pump in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
