Old Sun, Jan-13-2019, 09:29:54 PM   #31
Default Re: J-Fiber E46 M3 CF Driveshaft Review
Edit: unless it's because a faster engine spins up faster, and therefore needs more hp to spin it up at that faster rate
That's true, but I still don't think it would be a percentage. You'll need more energy to spin up the flywheel from 7k RPM to 8k RPM than you would from 3k to 4k, but the power the engine makes shouldn't impact the amount of energy the flywheel needs to spin up.
Old Sun, Jan-13-2019, 09:33:01 PM   #32
Originally Posted by pbonsalb View Post
I think stock shafts are lightweight aluminum. The CF cuts the weight from maybe 22 lbs to maybe 12 lbs. Any rotational loss helps but the diameter here is small so not as much energy is used to rotate it as with a wheel where the weight is around a bigger diameter. The CF shaft is not a top priority mod. Itís more for the person who is chasing power and has done everything else.
Stock is 8.5 kg (18.73 lbs) according to realOEM. That includes the giubo, CSB, and CV joint
https://www.realoem.com/bmw/enUS/par...&q=26112229240
Old Mon, Jan-14-2019, 04:15:05 AM   #33
HassanEido
HassanEido's Avatar
Lebanon
Originally Posted by Paulo M View Post
It’s carbon composite, not steel covered by cf lol. It was designed for strength sure, but still light
This suggests it's steel core and it's heavy. Granted forums are not the best source for info, but who gives a fuk about 350zs anyway lol
https://www.350z-tech.com/forums/190...riveshaft.html
PM for performance tune requests
Mods:
-Custom CF airbox
-Cat Cams 280 272.
-Custom dyno tune
385.7 whp 288 wtq
Old Mon, Jan-14-2019, 01:50:45 PM   #34
Paulo M
Everything Iíve seen said nothing of steel wrapped in cf, thereís no benefit to doing that. But I agree, donít really care at this point.
BREMBO APEX DIXIS
Old Mon, Jan-14-2019, 04:00:58 PM   #35
m3 hal
Originally Posted by stash1 View Post
As I stated in my previous d/s thread, I'm not sure what the science works out to in terms of d/s dia vs. rotational mass vs the gravity on the moon...but there is MOST def a noticeable increase in engine response/rpm's vs a factory d/s. It's def not placebo! I'm sure that forum member Wubai can also attest to the effect.
It may feel more responsive since the center bearing joint was deleted, but if you're suggesting a gain in power, then it came from something other than the weight loss.
Old Mon, Jan-14-2019, 07:48:45 PM   #36
Dr M3an M3
GroupBuyingPower@outlook. com
Dr M3an M3's Avatar
Going off of this...I am also not sure I am seeing the connection of this product and "faster SMG shift times." Someone help me understand this...
The shifts are now so fast that I can't even make micro adjustments because by the time I even think about it, its already in gear.
IG: DrM3anM3
Mods: Genuine OE CSL Bumper, Both Karbonius and Streamline CSL Airboxes, OE CSL Snorkel w/ working Flap, OE Map Sensor + OE Air Rail, Paul Claude Custom Tune, CSL Engine management with CSL converted DME, Supersprint V1 Stepped Headers w/ Oversized HJS Race Catted section 1, SS 2.5" Twin-Piped Oversized Custom section 2, Custom Oversized Supersprint muffler, Catcam's Billet 280/272 cams, WPC treated rod-bearings, VinceBar (weld) + Redish Plates, Full Beisan VANOS lockdown, BBS LMs w/ PSS, Brembo GT6 (front) + GT4 (rear) BBK, CSL style CF diffuser, Vorsteiner CF CSL Bootlid, CSL SMG Engine DME tune, CSL '255' SMG DME tune, SMG Pump Relocated.
For Sale: BNIB OE CSL Wheels
Active Group-Buys (PM if Interested):OE CSL Bootlids, Supersprint Headers/Exhaust thread, New Supersprint Oversized Twin-Piped Section 2, HTE Tuning Group-Buy
Old Mon, Jan-14-2019, 08:44:19 PM   #37
Pdelamare
Reputation: 0 Pdelamare is on a distinguished road
United Kingdom
Seems the E92 DCT version is 13.1kg (29lbs). This would be a substantial saving if the CF one is 5.4kg (11.9lbs). Not sure why the E92’s driveshaft is so much heavier.
http://www.realoem.com/bmw/enUS/part...&q=26102283665
Jump to top Pdelamare is offline   Reply With Quote
Old Mon, Jan-14-2019, 09:03:50 PM   #38
E92 M3 shaft weights I saw were 12.2 for the MFactory CF and 22.8 for the factory aluminum. Guibo not included.
Old Mon, Jan-14-2019, 09:18:29 PM   #39
stash1
Then I'd suggest everyone figure out a way to remove their CSB I guess-lol In all seriousness though, I'm really not sure exactly what is responsible for the increased throttle response and seemingly quicker acceleration, but whatever it is...it's real. This isn't my review, and I have no horse in the race, just confirming what's been mentioned-take it for what it's worth.
'04 AW/IR...some mods
Old Mon, Jan-14-2019, 09:49:29 PM   #40
dothraki
Reputation: 0 dothraki is on a distinguished road
I would speculate the removal of the CSB is a factor among other things. The stock DS probably has some winding flex involved as well. The carbon DS being bigger in diameter also makes it more rigid when turned. All added up and with the minor weight savings is what is being felt in the reviews. Again, just all speculative since this mod is not one most folks will get to experience.
Jump to top dothraki is offline   Reply With Quote
Discussing J-Fiber E46 M3 CF Driveshaft Review in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
