Old Sat, Jul-20-2019, 04:39:27 AM   #21
Default Re: Poor man's Euro headers
Do you current have an e46 m3 or looking to get another? Your work looks great!
/// 2004 SilberGrau M3 Coupe 6MT slicktop zero options ~3200lbs JOURNAL
_
Evolve-R Alpha N Evolve CSL CF Airbox Eventuri Scoop Supersprint V1 stepped 2.5" SS V1 S pipes 2.5" + 200 cell HFC OE sect 2 SCZA 2.5" sect 3 Besian RE pullies fan/SAP/washer delete CSL battery
Bilstein HD B6 + GroundControl/Eibach 325/550lb + GC "tall" RSMs Hotchkis front sway (med) rear strut bar TMS camber & subframe plates Eibach alu rear camber arms RE trans mounts AKG poly subf/diff 95a SDW RTAB OE weighted ///M knob + ZHP alcantara boot + UUC DSSR + delrin bushing
OE CSL trunk Cobra Nogaros + BK + manual OE bases TMS black pedals Sportline 8S 18"x 8.5/9.5" MPSS 245/275 APEX 75mm Studs Brembo 996 4 pot 36/40 345mm CSL & 28/30 328mm CSL ZHP "712" rack Pioneer/CDT/Eclipse/Kicker
Old Sat, Jul-20-2019, 06:56:18 AM   #22
Cronenberged
Cronenberged's Avatar
Reputation: 0 Cronenberged is on a distinguished road
Originally Posted by Dr M3an M3 View Post
Ouch...At that point, once you factor in welding, you may as well get the real deal Supersprint setup (especially through the 'Group-Buy' pricing)
it's a constant pricing though.
Formerly known as ///M3_Letty
Jump to top Cronenberged is offline   Reply With Quote
Old Sat, Jul-20-2019, 12:42:15 PM   #23
PITT M3 RR
PA
PITT M3 RR's Avatar
Do you current have an e46 m3 or looking to get another? You're work looks great!
Sold the SG/IR which I probably shouldnít have...Iím kicking around the idea of another E46 or something completely off the wall. I donít think the E36 is going anywhere and definitely fills my hard roof raw car needs.
Next set of headers in the works is keeping stock primaries for 8Ē, then 10Ē of 1 7/8 to a custom collector into 2.5Ē outlet to 2.5 sec 1.
S54 E36 BUILD
Jump to top PITT M3 RR is online now   Reply With Quote
Old Sun, Jul-21-2019, 12:24:37 PM   #24
bigjae1976
Iím in the process of copying your jig. Is it necessary to back purge? I plan to swaintech coat the ones Iím making. Also wonder if I swaintech cost does that avoid having me to backpurge the weld as well.
2013 F30 328i - Melbourne Red
2004 E46 M3 - Imola Red
Old Sun, Jul-21-2019, 01:11:29 PM   #25
PITT M3 RR
PA
PITT M3 RR's Avatar
You need to back purge stainless or it’ll “sugar” and create peaks. Use solar flux B. It’s a powder that you mix with water then brush on. It dries and shields the back of the weld. Works well too.
Also, surprisingly, ceramic spray paint from autozone works as far as durability. I coated welds on my sec 2 three years ago and it still looks like that day.
S54 E36 BUILD
Old Sun, Jul-21-2019, 01:33:02 PM   #26
bigjae1976
Originally Posted by PITT M3 RR View Post
You need to back purge stainless or itíll ďsugarĒ and create peaks. Use solar flux B. Itís a powder that you mix with water then brush on. It dries and shields the back of the weld. Works well too.
Thanks! So you just used the flux?
Did you use tri mix gas or an argon/CO2 mix? Those welds look pretty good.
Can you get the insides of the pipes like Swaintech? Wonder if itís even worth it...Iím all about the rattle can if it gets good results.
Old Sun, Jul-21-2019, 01:43:36 PM   #27
PITT M3 RR
PA
PITT M3 RR's Avatar
I used pure argon throughout the entire process. You donít need to weld inside because the penetration makes it in there and the solar flex shields itÖ Thereís a nice low smooth bead inside. And yes I only used the solar flux.
All the welds I did were fusion welds, without any filler. When I was doing the fusion welds I forget my exact settings right now but I know I used a pulse and that was able to pull the Puddle along real easily
S54 E36 BUILD
Old Sun, Jul-21-2019, 03:46:26 PM   #28
bigjae1976
TIG? I need to get one. But MIG is so much easier.
Old Sun, Jul-21-2019, 04:12:51 PM   #29
PITT M3 RR
PA
PITT M3 RR's Avatar
Yea TIG, Lincoln square wave tig 200. Really great for the home garage. I tried flux core SS MiG and it was disastrous. Maybe Gas shielded mig will be much better. Iím worlds better with mig but under the right conditions I can tig like a machine.
S54 E36 BUILD
Old Tue, Jul-23-2019, 02:19:53 AM   #30
T3AMFiSh
Your mom goes to college
T3AMFiSh's Avatar
I mig welder my stainless exhaust, I used a higher argon gas mix. I was told it’s all about the correct wire, which I got from Blue Devil welding, no sugaring
Discussing Poor man's Euro headers in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
