Old Thu, Jul-19-2018, 08:30:31 PM   #411
Default Re: Best Daily Driver Suspension?
Originally Posted by M spec View Post
I take it you all are not too informed on the DINAN catalog parts over the years.
The DINAN JRZ's are no longer offered (1wy/NR), so you don't really have that choice anymore. The only difference was the JRZ's supposedly had a better build quality and adjustment range. For the street, the overall feeling is about the same when DD'ing. Only in the canyons or track/autoX would the JRZ's start to feel $1200 more.
Of course reservoir/multiple adjustment JRZ's aren't an apples to apples comparison, so not sure why you brought those up?
I am, I almost bought a set used. Didn't because JRZ told me it was impossible to source rebuild parts, so they were effectively a part with an expiration date.
Old Thu, Jul-19-2018, 08:32:03 PM   #412
Blaikenstein
Blaikenstein's Avatar
Reputation: 0 Blaikenstein is on a distinguished road
Iím planning to run GC DAís with a medium spring and eventually their sway bar. I dd my car so my thinking is use the sway bar to keep the car flat vs spring. The DA will allow me to do more fine tuning as I grow into HPDE. I think this set up with weight jacks and hybrid camber plates is around 2800 or so, awesome value.
Jump to top Blaikenstein is online now   Reply With Quote
Old Thu, Jul-19-2018, 08:51:48 PM   #413
M spec
Rembrandt Audio
Reputation: 0 M spec is on a distinguished road
Austria
Odd, who did you speak with? The re-valving parts aren't any different than the standard 1wy they produce. I called about 2 months ago and was given two different shops to send them out to.
Jump to top M spec is offline   Reply With Quote
Old Thu, Jul-19-2018, 09:06:54 PM   #414
twentyseven
@itsmejonnyv
twentyseven's Avatar
Except the Ohlins need a $1300 rebuild every 25,000 miles. Negates them if the car sees any transportation use, imo.
I wouldn't put the PSS10s where they are, either, with their limited spring rate options.
That’s why I only put the Ohlins at ‘Sporty Street’(aka not Daily) and the tail end of the ‘Tracked Street’ due to their compromises you’ve published.
You should. PSS10 (B16) work great with linear spring conversions. Monotube + digressive valving can handle big spring rates, Bilstein durability/lifetime warranty, and none of the travel issues the Ohlins have with camber plates. They are an excellent dual duty damper for the money. I’d take them over a 1way JRZ or MCS.
V-CSL, BBS CH, ÷hlins R&T, Supersprint, Brembo GT, custom Z4M seats, AVIN, G5R projector swap
Jump to top twentyseven is offline   Reply With Quote
Old Fri, Jul-20-2018, 12:08:24 AM   #415
Exclusivs
Exclusivs's Avatar
Reputation: 0 Exclusivs is on a distinguished road
^The PSS10 kit has peaked my interest at times. I think their upper priced kits are far superior to their regular strut HD offerings. Good info thanks for chiming in with actual knowledge.
Jump to top Exclusivs is offline   Reply With Quote
Old Fri, Jul-20-2018, 12:43:27 AM   #416
mrgizmo04
mrgizmo04's Avatar
Where are you guys getting quotes of $1300 rebuilds for Ohlins? In Norcal, $160 a pop.
'85 528e 164k miles (sold)
'05 M3 6MT coupe
Old Fri, Jul-20-2018, 12:52:00 AM   #417
L0ADED
L0ADED's Avatar
Ohlins.
$160 is much more reasonable considering it's just some seals and fluid.
Old Fri, Jul-20-2018, 12:11:12 PM   #418
That quote was from Ohlins.
By "a pop", do you mean per shock?
The $1300 I quoted was for all 4.
Old Fri, Jul-20-2018, 12:15:37 PM   #419
I don't know-- this was two years ago. I was considering the set Braymond was selling for the wagon.
The underlying issue was that the Dinan JRZ's used a 46mm piston. Years ago JRZ switched to 44mm pistons, hasn't made new parts for the 46s since, and new old stock has run out at this point.
I tried ~5 rebuild shops that JRZ said might have parts, as well as Dinan themselves, before giving up and going with the Konis. My hope was just to stockpile a bunch of rebuild kits
Old Fri, Jul-20-2018, 10:18:24 PM   #420
mrgizmo04
mrgizmo04's Avatar
Originally Posted by L0ADED View Post
Ohlins.
Yeah, "a pop" is per corner, but still nowhere near Ohlins quoted.
I wouldn't even think of going to Ohlins for this. Similar to doing an oil change or a valve adjustment at the dealer .
PSI (performance shock inc) in Sonoma does rebuilds.
'05 M3 6MT coupe
Discussing Best Daily Driver Suspension? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
