Old Tue, Jun-26-2018, 08:58:10 PM   #41
Default Re: M3 E46 Pre Cat O2 sensor replacement...
Im pretty sure there are only 3 differrent O2s for this car - one of the pre cats is used again in post cat. The simplest plug patter in yellow. Might save some money buying 2 of the cheapers ones instead of 1 and 1.
_
OE CSL trunk Sportline 8S 18"x8.5/9.5" + 10mm spacers MPSS 245/275 APEX 75mm Studs Brembo 996 4 pot 36/40 345mm CSL & 28/30 328mm CSL ZHP "712" rack Pioneer/CDT/Eclipse/Kicker
Old Tue, Jun-26-2018, 09:01:48 PM   #42
dutchhome
Reputation: 0 dutchhome is on a distinguished road
That may very well be. I just looked them up from Bosch themselves. It sounds like the wild price differences may simply be different connectors or wire lengths but I have no way to determine that.
Jump to top dutchhome is offline   Reply With Quote
Discussing M3 E46 Pre Cat O2 sensor replacement... in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
