Old Fri, Apr-21-2017, 03:53:38 AM   #1
Toxic0n
Default Should I replace my FCABs while I'm replacing my control arms?
I replaced my FCABs at 125k km (~75k miles), my car now has 195k km (~120k miles). However, this was done just over 6 years ago.
Now the outer ball joint on one of the control arms seems to be gone.
If I'm replacing these, should I do the FCABs again while I'm down there? Tie rods, too?
Anything else?
Ground Control, Mason Engineering, HRE, ACS, Rogue Engineering
Jump to top Toxic0n is offline   Reply With Quote
Old Fri, Apr-21-2017, 05:11:56 AM   #2
WyattH
Default Re: Should I replace my FCABs while I'm replacing my control arms?
I would do the FCABs and Tie Rods at that point, they're cheap compared to the FCAs.
Maybe do end links also.
Old Fri, Apr-21-2017, 01:35:05 PM   #3
Zroman610
Zroman610's Avatar
Reputation: 0 Zroman610 is on a distinguished road
Agreed. Might as well do it all while you're in there if you plan on keeping it for a while.
Jump to top Zroman610 is offline   Reply With Quote
Old Fri, Apr-21-2017, 02:05:42 PM   #4
MarcZCP
MarcZCP's Avatar
Reputation: 0 MarcZCP is on a distinguished road
BMW TIS says that once an FCAB is removed from the LCA it cannot be reused. I would go ahead and replace them.
2006 M3 ZCP 6MT Interlagos blue, black retrofit interior
2013 Acura TL SHAWD 6MT - Daily driver
2005 Mazda RX8 - Gone but not forgotten
Jump to top MarcZCP is offline   Reply With Quote
Old Fri, Apr-21-2017, 04:08:19 PM   #5
Toxic0n
Thanks, that makes sense. Probably easier to get the FCAB on with the LCA's removed anyway.
Now, do I go OEM again or something like Powerflex?
What about end links and tie rods? I'm slightly dropped, will the OEM ones be fine again?
Old Fri, Apr-21-2017, 04:29:25 PM   #6
Prevailm
Prevailm's Avatar
Reputation: 0 Prevailm is on a distinguished road
I just replaced mine with Lemforders, cheap and they are fine. They just grind off the BMW emblem.
Jump to top Prevailm is offline   Reply With Quote
Old Fri, Apr-21-2017, 06:15:35 PM   #7
MarcZCP
MarcZCP's Avatar
I went with the Whiteline poly FCABs. They are a PITA to install. So far so good, they seem to tighten steering response a bit and no noticeable increase in NVH. I've got less than 300 kms on them so far so can't comment on durability, which I know has been an issue with other poly FCABs.
Old Fri, Apr-21-2017, 07:00:24 PM   #8
Mr. Black
Registered Drug User
Reputation: 0 Mr. Black is on a distinguished road
I replaced mine with the Turner delrin FCABs, love the crisp steering feel
Jump to top Mr. Black is offline   Reply With Quote
Old Fri, Apr-21-2017, 07:59:12 PM   #9
Toxic0n
Looks like FCP has a kit for what I need.
https://www.fcpeuro.com/products/bmw...e46m3cakitfull
All Lemforder with Meyle HD end links. Does anyone know if any extra parts are needed? Some bolts are one time use only I think and maybe clamps on the boots for the tie rod ends?
Old Fri, Apr-21-2017, 08:18:33 PM   #10
nbriggs1988
Reputation: 0 nbriggs1988 is on a distinguished road
Don't mean to threadjack, but I don't want to clutter the forum with a new thread of my own.
I have a question regarding my rear control arms/trailing arms. My rear camber is really bad on my left rear. The camber adjuster is maxed out and I have crazy inner tire wear.
My question is, do you guys think it's just the RTAB or possibly a bent upper arm? Just trying to find a place to start for now. Subframe is fine btw, no cracks and nothing looks bent.
I still need to put it on an alignment rack hopefully in the next couple weeks to get some specs on how far out of spec my rear wheels are.
Thanks guys
Sent from my HTC 10 using Tapatalk
Jump to top nbriggs1988 is offline   Reply With Quote
Discussing Should I replace my FCABs while I'm replacing my control arms? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
