Old Thu, Apr-20-2017, 09:24:07 PM   #1
Bananaskin
Reputation: 0 Bananaskin is on a distinguished road
Default Some help w Iddle issue.. ICV done..
Hi
First of all thank you to whoever is reading this..
Now,
I have been struggling with this sudden iddle drop at the light or while im parking.. This is with the car already warm up..
I did a search and went thru a lot of threads talking about the ICV.
So, i cleaned the ICV, clean throttle, replace vent piece that goes from valve cover to IM. replaced TPS (2), re-tight hoses that connect the ICV, replaced intake boot, replaced maf, change plugs and i still have the same dam issue.
History of car, 150k miles, vanos are good, Rod bearings replaced at dealer, vanos filter is new, coils are new, i got an AFE stage 2 intake.
At this point, i'm thinking on replacing the ICV with a new one, or maybe the coolant temp sensor? EGR valve could be dirty?
I have the o2 sensor code cuz im running headers, but that have never been the issue..
Any input to help out ill really appreciated..
I dont have one of those fancy scanners. just a typical obd2 scanner..
The only code that shows up is the o2 sensor bank 2 i believe. The same one that shows after u put catless headers.
Thanks
Stan
Jump to top Bananaskin is offline   Reply With Quote
Old Thu, Apr-20-2017, 09:51:35 PM   #2
Monte0704
Monte0704's Avatar
Reputation: 0 Monte0704 is on a distinguished road
Default Re: Some help w Iddle issue.. ICV done..
Well, start with the O2 sensor.
I'm in a unique situation where I have a car with a motor with only 7k miles on it.(roughly) That means new ICV, new TPS, new Throttle Bodies, everything.
I have a small idle stumble as well, one that you can't see on the tach. If you CAN see it on the tach, then we are probably having different issues.
I replaced fuel filter, plugs, all 4 o2 sensors, cleaned my MAF, really everything I could think of. You know what solved the issue? I removed my oiled KnN air filter and put a cheap OEM style paper filter in. Cleaned the idle right up.
2004 E46 M3 SMG II | 1990 Nissan Skyline GTR
Jump to top Monte0704 is offline   Reply With Quote
Old Thu, Apr-20-2017, 10:40:58 PM   #3
Bananaskin
My filter is clean, and even if i replace the o2, the light will come up again since i got headers...
I checked the boot at the IM and they are all good too..
Any other thoughts?
Old Thu, Apr-20-2017, 11:17:20 PM   #4
Monte0704
Monte0704's Avatar
Any other thoughts?
Honestly, not really.
Replace your fuel filter.
Try a filter without oil in it.
Old Mon, Apr-24-2017, 09:43:57 PM   #5
Bananaskin
Ok replaced fuel filter.. No change
Im replacing the dam ICV..
Any other tip?
Old Mon, Apr-24-2017, 10:05:58 PM   #6
2001E46m
Reputation: 0 2001E46m is on a distinguished road
May as well replace the coils.
Jump to top 2001E46m is offline   Reply With Quote
Old Mon, Apr-24-2017, 11:47:23 PM   #7
Bananaskin
I dont think the coil is a problem, but ill check on pricing..
If it was the coil, i would be having a missfire..
Car is runniing on all 6
Old Mon, May-08-2017, 09:40:26 PM   #8
Bananaskin
Update..
Took the hit on the ICV from bosch.. 200 bucks and no no sudden drop on iddle..
I still have the normal hunting when car is cold but after that.. all good
I guess my ICV was bad alrady, didnt work even after the whole cleaning..
Old Tue, May-09-2017, 07:05:03 AM   #9
bigjae1976
I would reset your adaptations. That will make a huge difference.
2013 F30 328i - Melbourne Red
2004 E46 M3 - Imola Red
Old Thu, May-11-2017, 04:47:59 PM   #10
zippity
Reputation: 0 zippity is on a distinguished road
I have this exact problem. I have purchased a lot to chase it down. I guess I will buy a new bosch ICV
Jump to top zippity is online now   Reply With Quote
Discussing Some help w Iddle issue.. ICV done.. in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
