Old Thu, Apr-20-2017, 09:02:19 PM   #1
4stripes
Reputation: 0 4stripes is on a distinguished road
Default 2001 E46 M3 convertible top only opens partway and stops. CVM DTC codes 67 68 12 53
After winter my top won't fully open (it had worked fine previously and was opened mid winter for a nice day or two). Car driven regularly and battery in good condition. It lifts front and window area but the top storage cover doesn't open! No strange noises from gearbox in back seat. Storage lid does unlock but won't lift with normal hydraulics. The top will close after reselecting ignition switch off and on.
Scanned CVM and got DTC codes
67 Cowl doesn't move up
68 Cowl doesn't move downwards
12 Open control button permanently active
53 Relay,convertible top drive,open circuit
I haven't found any leaks and fluid level was in the circle with top closed. Couldn't stow the top to see what it is fully open and stowed. Checked the wire bundle at the front hinge point and found some insulation cracks but no broken wires.
Appreciate your help on this from anyone who has had similar issue (opens but won't open storage cover).
Thanks Eric
Jump to top 4stripes is offline   Reply With Quote
Old Thu, Apr-20-2017, 09:18:58 PM   #2
lmattiso
lmattiso's Avatar
Reputation: 0 lmattiso is on a distinguished road
Default Re: 2001 E46 M3 convertible top only opens partway and stops. CVM DTC codes 67 68 12
Thanks Eric
I had a similar issue and it turned out to be the top relay in the trunk. It's a pretty easy part to get to if you want to replace just in case. The relay is the same one as the fuel pump, here's the part I used.
Jump to top lmattiso is offline   Reply With Quote
Old Fri, Apr-21-2017, 01:40:35 AM   #3
M3Vert03
Reputation: 0 M3Vert03 is on a distinguished road
Check the wiring in the soft top frame, just above the driver seat. The wiring can fray at the pivot point causing this to happen.
Good luck
Jump to top M3Vert03 is offline   Reply With Quote
Discussing 2001 E46 M3 convertible top only opens partway and stops. CVM DTC codes 67 68 12 53 in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
