Old Thu, Apr-20-2017, 10:13:40 PM   #11
Monte0704
Monte0704's Avatar
Reputation: 0 Monte0704 is on a distinguished road
Default Re: New owner - what preventive maintenance should start thinking about?
^updated oe line is cheaper and better
Is it? That's the very first I'm hearing of it then, after countless hours of searching.
If that's so then I'll pull the Rouge one, because I'm just trying to figure out how to forget about the Vanos entirely. I don't care what it costs, I just want the best.
2004 E46 M3 SMG II | 1990 Nissan Skyline GTR
Jump to top Monte0704 is offline   Reply With Quote
Old Thu, Apr-20-2017, 11:33:19 PM   #12
TheSt|G
Resident Curmudgeon
TheSt|G's Avatar
Isle of Man
Originally Posted by suaveflooder View Post
Link to what is different on the updated one? I've never heard of this failing and not finding much on google other than the braided one.
https://www.ecstuning.com/b-genuine-...e/11367837614/
There's the part.
Andrew
Current - '05 Interlagos E46 M3 SMG Delete 6MT Coupe - 3350lbs
911 Journal/Build Thread
No fun no care
Jump to top TheSt|G is online now   Reply With Quote
Old Fri, Apr-21-2017, 12:06:09 AM   #13
gam3cock
Reputation: 0 gam3cock is on a distinguished road
Awesome guys. Thanks a bunch. I'll probably start piecing the parts together for a rebuild within the next month or so. Getting married in 3 weeks so the fiancée will be pissed if I spend too much money on my car. I already spend wayyy to much on golf equipment and cigars.
Plussss I'm eyeing a set of CSL reps because the wheels the previous owner had on this are awful....
Jump to top gam3cock is offline   Reply With Quote
Old Fri, Apr-21-2017, 11:35:41 AM   #14
They added an additional mount point (to one of the vanos mounting bolts) to address the vibration that was causing the original line to fail.
11367837614
Rouge suggests replacing theirs yearly. The updated OE is one and done, cheaper, and nobody has reported a failure on one yet.
Old Fri, Apr-21-2017, 02:07:04 PM   #15
repoman89
Reputation: 0 repoman89 is on a distinguished road
11367837614
Did the updated part come originally in any later model cars?
Jump to top repoman89 is offline   Reply With Quote
Old Fri, Apr-21-2017, 02:35:44 PM   #16
m3nt0s
Reputation: 0 m3nt0s is on a distinguished road
Good question, I see it listed on Realoem here: http://www.realoem.com/bmw/enUS/partxref?q=11367837614
Unsure if this means that the part was used on production cars from 10/17/05 onwards, or if the part was simply just available. Can anyone clarify?
Jump to top m3nt0s is offline   Reply With Quote
Old Fri, Apr-21-2017, 02:37:40 PM   #17
suaveflooder
suaveflooder's Avatar
Reputation: 0 suaveflooder is on a distinguished road
11367837614
Awesome. Thank you!
2004 IR Slicktop
Jump to top suaveflooder is offline   Reply With Quote
Old Fri, Apr-21-2017, 02:48:52 PM   #18
I've never seen a car that came with it, though that does imply that late 2006s came with it.
That said, you have one on your car-- you installed the bottom banjo bolt while I was doing your vanos overhaul
Old Fri, Apr-21-2017, 02:56:52 PM   #19
Monte0704
Monte0704's Avatar
I have a crate motor that was installed in 2016. I want to see if the crate motor has the updated line.
So the difference is a third mount to prevent vibration?
Old Fri, Apr-21-2017, 03:01:45 PM   #20
Yes, stealing and modifying a picture from my own journal, the additional mount point is here:
File Type: jpg CD9BD234-1F1A-4FE4-A7E7-D30D9F6A7ED0_zps7qjst0ey.jpg (267.8 KB, 46 views)
Discussing New owner - what preventive maintenance should start thinking about? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
