Old Thu, Apr-20-2017, 02:11:03 PM   #1
gam3cock
Reputation: 0 gam3cock is on a distinguished road
Default New member, need help with headlight alignment (?)
Hey guys, new member but not new to BMWs or forums, so I did use the search function but I am still stuck.
I have recently picked up a 2004 M3 with stock BiXenons. The first time I drove the car at night, I was shocked about how crappy the lights were. I went straight to the forums and read about bulbs and also the bulb housing that is a common problem on some OEM lights. I fortunately do not have those light. I have the Bosch lights.
First step was getting the headlights "restored." They were a tad faded when I bought the car, so I assumed this would help. IT helped on my x5, so I was optimistic. It did not.
Second step was attempting to adjust the lights with the knobs as I have done on previous cars and they actually got worse.
Third step was replacing the bulbs. I didn't get the OEM or Phillips, I went with the Morimotos so that If the bulbs were not the problem, I wouldn't be out $200 for nothing. This helped a little, but they are still HORRIBLE.
Fourth, I tried to adjust them again, nothing. This is where I currently am. The "beams" seem to be pointing WAY to the left (from in the car) and when you are looking at the headlights, the projectors appear to be angled towards the center of the car. So I am stuck here. Here are some options that I think I might have. Please let me know what yall think.
- Take of the lense and Manually adjust the projector?
- Purchase new projector lens from TRS
- Purchase new headlights (worst case)
I can get some pictures tonight, if you think it'll help. If so, let me know what angles you'd need.
Cheers!
Jump to top gam3cock is offline   Reply With Quote
Old Thu, Apr-20-2017, 02:30:03 PM   #2
Kcalhoun27
Reputation: 0 Kcalhoun27 is on a distinguished road
Default Re: New member, need help with headlight alignment (?)
From what ive seen, replacing the lens seems to really help. From my own searching, it seems like the consensus is that theyre just poorly designed, but replacing the internals can make a big difference. As with everything on this car, it comes down to how much you are willing to spend.
Jump to top Kcalhoun27 is offline   Reply With Quote
Old Thu, Apr-20-2017, 02:31:41 PM   #3
gam3cock
Yeah, after writing the above post, I just went ahead and ordered new lenses When you say "internals," what are you referring to? Ballasts and wiring or projector and housing?
Last edited by gam3cock; Thu, Apr-20-2017 at 02:32:12 PM. Reason: didnt finish thought
Old Thu, Apr-20-2017, 02:41:21 PM   #4
WOLFN8TR
"MONEY"
WOLFN8TR's Avatar
Search ZKW Lens upgrade.
Old Thu, Apr-20-2017, 02:46:50 PM   #5
Kcalhoun27
Exactly what Wolf posted actually haha. Those lenses are on my long term list to replace. A little more work seems to produce pretty respectable results, from what ive seen. And for the price, they seem worth it vs a complete rebuild for 300ish
Old Thu, Apr-20-2017, 02:50:00 PM   #6
gam3cock
Yup, these are the ones I just ordered. Have you installed these? If so, how was it. I've found some DIYs and talked to TRS and the DIYs make it seem like a 5/10 (difficulty) and TRS make it seem like a 1or2/10
Also, do you have a specific DIY that you followed?
Old Thu, Apr-20-2017, 03:14:59 PM   #7
gam3cock
Nvm - search is my friend
Old Thu, Apr-20-2017, 04:02:42 PM   #8
sergbaja5t
Uncle Grandpa
sergbaja5t's Avatar
Reputation: 0 sergbaja5t is on a distinguished road
Easy to do the swap. But....... the lens will not quit right. You will have to work the metal frame that holds the lens in place. I had to enlarge it just enough so the new lens fit squarely into the frame. Then slide the lock ring in. Take pictures of the position of the buckets before taking them apart. Beware DO NOT TOUCH ANY OF THE CHROME PART BEAR HANDED! Use gloves!
Also DO NOT USE ANY LIQUID CLEANER ON THE HIGH BEAM LENS!
Use a microfiber eyeglass cloth to wipe out any dust. Good luck!
2016 Ford F150 Screw sport Egoboost
2005 SilberGrau Met/Schwarz M3 Smg, VMR 703 reps, Megan Racing sec 3, Bilstein PSS10/Koni
2002 StahlGrau MET/Schwarz M3 6spd AA headers, Supersprint x-pipe, AA Gen 4 sec3, Besian hub and seals, Turbotoy hardware, Rouge Engineering Vanos & Coolant pipe, Arp studded, H&R/ST/Bilstein coilovers, M220 19's. S54 timing tool w/ two guide pins**FOR RENT** Atlanta valve adjustment service(ask about rates)! Simple coding & DME scanning (Atlanta area)
Jump to top sergbaja5t is offline   Reply With Quote
Old Thu, Apr-20-2017, 04:29:53 PM   #9
gam3cock
Hahah thanks for the advice. Already have latex gloves and I will not use liquid cleaner.
I do have a few eye glass things laying around. thanks for that tip
Old Sat, Apr-22-2017, 01:51:32 PM   #10
WOLFN8TR
"MONEY"
WOLFN8TR's Avatar
X2 on Serg's advice.
Also the chrome scratches really easy. If you buy OEM ZKW lenses they will fit perfectly without any grinding but they are twice the cost. Also once you get them to fit mount them back into the reflector and plug them in to test the light pattern before completely reinstalling the entire light assembly back into the car. On mine I had to use some washers to adjust the light pattern. This is a great upgrade and makes a big difference in the light output and pattern.
Before
After
Discussing New member, need help with headlight alignment (?) in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
