Old Thu, Apr-20-2017, 07:52:52 AM   #1
Rajvosa
Reputation: 0 Rajvosa is on a distinguished road
Default Drilling Vanos disc
Are there any online guides as to how to exactly drill the new holes on the disc? Size , position etc?
Thinking of getting vanos done in near future
Jump to top Rajvosa is online now   Reply With Quote
Old Thu, Apr-20-2017, 01:23:37 PM   #2
BergA
Reputation: 0 BergA is on a distinguished road
Default Re: Drilling Vanos disc
Some preliminary research I've done shows the typical diameter to drill/mill is 9.75mm or 9.8mm.
I would like to know the distance between the holes, though. That's something I haven't found in my searching.
Update: I just ordered a "letter size W" chucking reamer, at 9.804mm. It was $11 shipped from eBay -- beats $150 from Beisan. If you have the right tools, why not do it yourself? Let us know if you find the correct pitch between holes, as will I.
Jump to top BergA is offline   Reply With Quote
Old Thu, Apr-20-2017, 01:26:34 PM   #3
TheSt|G
Resident Curmudgeon
TheSt|G's Avatar
Isle of Man
You can just get it perfectly done already.
http://www.beisansystems.com/products.html
Andrew
Current - '05 Interlagos E46 M3 SMG Delete 6MT Coupe - 3350lbs
911 Journal/Build Thread
No fun no care
Jump to top TheSt|G is online now   Reply With Quote
Old Thu, Apr-20-2017, 02:10:31 PM   #4
Rajvosa
yes i know already. i plan to get seals off Beisan, but trying to get cheaper option on the disc. i am in Australia so by time i pay USD and shipping plus shipping core back... you get the picture.
if i can get it done cheaper and achieve same result why not then
Old Thu, Apr-20-2017, 02:50:22 PM   #5
Monte0704
Monte0704's Avatar
Reputation: 0 Monte0704 is on a distinguished road
I mean, from everything ive seen, the disk is perfectly round.
You drill two 9.8mm holes at 90 degrees from the originals. I have a friend with a multi million dollar cnc shop. I'm sure he could bust out my new holes easy.
2004 E46 M3 SMG II | 1990 Nissan Skyline GTR
Jump to top Monte0704 is offline   Reply With Quote
Old Thu, Apr-20-2017, 03:46:53 PM   #6
billybilly
XBox one peasant
billybilly's Avatar
Reputation: 0 billybilly is on a distinguished road
Its not rocket surgery, just drill the smaller holes 90 degrees from factory to the same depth, if you have access to a drill press you are gtg, just go slow, use oil and a pilot drill, dont just go right for the 9.8mm.
Jump to top billybilly is offline   Reply With Quote
Old Thu, Apr-20-2017, 06:30:30 PM   #7
stash1
OP, I've got a buddy (actually a forum member here) who does this on the side, and I believe he's very reasonable. PM me if you want his contact info...
'04 AW/IR...Not Stock
Old Thu, Apr-20-2017, 06:37:33 PM   #8
M3_#67
Reputation: 0 M3_#67 is on a distinguished road
I've done 4 of them for friends and myself where I work. Pretty easy on the cnc.
'02 Imola Red on Black
Jump to top M3_#67 is offline   Reply With Quote
Old Fri, Apr-21-2017, 12:52:20 AM   #9
BergA
What is the distance between holes?
Old Fri, Apr-21-2017, 07:24:03 AM   #10
M3_#67
No, never on just any old drill press. That would be a recipe for tab failure or not fitting. Especially if A. The center to center distance is off from the center bore from one drilled hole to the other. B. The drilled holes are off center (not in a straight line with the center bore). C. The part isn't sitting flat one way or an other...etc..It's a task that needs to be precise. Reason being is you want both tabs to contact the walls of holes at the same time. Otherwise one tab is taking all the stress.
Can't remember off the top of my head. It's been a year or so since I've done one. I should still have my notes in my tool box at work but I'm off til Monday.
Discussing Drilling Vanos disc in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
