Old Fri, Apr-21-2017, 12:32:29 AM   #11
Bmwpower603
Default Re: Oil filter housing HELP!
Originally Posted by indy98m3 View Post
Ok, guys, need your help. Sent my oil filter housing off for a powder coat, and it came back without this little torx panhead screw. Can you guys either help me find the P/N or appropriate dimensions, so I can buy a replacement? See the red circle.
Thanks so much.
Indy98m3
Random question ...
Does the tensioner come off with the oil filter housing ? And do bolts that hold the tensioner need to be loosened to remove the housing ?
I'm going to be doing The housing gasket soon. I'm sure it's a mess!
Old Fri, Apr-21-2017, 01:01:20 AM   #12
indy98m3
Reputation: 0 indy98m3 is on a distinguished road
Yes. The tensioner comes off with the housing. No, you basically have to take the belt off, take the two alternator bolts out (one is holding a pulley), and then take out the 6 bolts holding it to the block.
Jump to top indy98m3 is offline   Reply With Quote
Old Fri, Apr-21-2017, 07:56:54 AM   #13
Go to the junkyard armed with a torx socket and ratchet.
Discussing Oil filter housing HELP! in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
