Old Thu, Apr-20-2017, 01:39:02 AM   #1
indy98m3
Reputation: 0 indy98m3 is on a distinguished road
Default Oil filter housing HELP!
Ok, guys, need your help. Sent my oil filter housing off for a powder coat, and it came back without this little torx panhead screw. Can you guys either help me find the P/N or appropriate dimensions, so I can buy a replacement? See the red circle.
Thanks so much.
Indy98m3
Jump to top indy98m3 is offline   Reply With Quote
Old Thu, Apr-20-2017, 01:39:15 PM   #2
englishtom1596q
englishtom1596q's Avatar
Default Re: Oil filter housing HELP!
Do you have a tap and die set? If so you can just figure out what size it is. I always thought about putting an oil temp sensor in there
Old Thu, Apr-20-2017, 03:11:47 PM   #3
Take it with you to the hardware store? Shouldn't be hard to find a suitable bolt that will plug it.
Old Thu, Apr-20-2017, 03:32:23 PM   #4
indy98m3
Thanks, guys.
It's an m8x1.25 if I recall correctly, based on some hw I tested from Home Depot.
What I'm not sure of is:
*Required length of the bolt/screw, and
*type/hardness of bolt material I should use
Thanks again!
Rimas
Old Thu, Apr-20-2017, 04:42:30 PM   #5
LockDots
LockDots's Avatar
I can't comment but I would think that it couldn't hurt going with stronger hardware (10.9 vs 8.8).
Old Thu, Apr-20-2017, 05:22:39 PM   #6
englishtom1596q
Hardness doesn't matter, it's not under any stress restricting oil. I would get a set screw over a bolt and make sure you use tephlon around it to make sure it seals completely.
Old Thu, Apr-20-2017, 05:32:18 PM   #7
indy98m3
Thanks much, guys.
Any thoughts on length of set screw?
Old Thu, Apr-20-2017, 06:32:15 PM   #8
englishtom1596q
Never pulled the plug to see how deep it is. Can you take a picture of the hole and if it does go into the oil passage? I'm going to put a 8x1.25 -> 1/8th adapter then a temp sensor in there if I can
Old Thu, Apr-20-2017, 07:06:40 PM   #9
LockDots
LockDots's Avatar
I figured it wasn't really structural. I just typically go for stronger bolts any time I have to replace any.
Sent from my SAMSUNG-SM-G920A using Tapatalk
Old Fri, Apr-21-2017, 12:24:49 AM   #10
indy98m3
I'll try to take a pic, but it's installed in the car. In fact, I only discovered that the bolt was missing when I was trying to start the car, following the m50 manifold install I did. (Which included "while you're in there" projects like the oil filter housing and alternator)
Because the bolt wasn't there, it shot oil (many quarts) all over the wall and engine bay.
I don't have enough faces or palms for the face palm level.
Discussing Oil filter housing HELP! in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
