Old Wed, Apr-19-2017, 10:15:24 PM   #1
Pirelli Condoms
Pirelli Condoms's Avatar
Reputation: 0 Pirelli Condoms is on a distinguished road
Default Charleston Sc subframe reinforcement.
I believe my subframe is starting to tear, best place to get it done within 300 miles?
“On a given day, a given circumstance, you think you have a limit. And you then go for this limit and you touch this limit, and you think, 'Okay, this is the limit'. And so you touch this limit, something happens and you suddenly can go a little bit further. With your mind power, your determination, your instinct, and the experience as well, you can fly very high.”
― Ayrton Senna
2002 E46 M3 CB/Cinn. 102k 6MT
AST 4200 Coilovers | Square 67's with 275 NT01's | Swaybarian front bar | Poly errthing | Powerflex lca | Gtfour cage | Rogue front strut bar | Recaro SPG w/ black vinyl cover | Z3 shifter | Gloc R12/10 | Macht schnell elbow/filter | Mishimoto efan |
Jump to top Pirelli Condoms is offline   Reply With Quote
Old Wed, Apr-19-2017, 10:29:55 PM   #2
m3az05
m3az05's Avatar
Reputation: 0 m3az05 is on a distinguished road
Default Re: Charleston Sc subframe reinforcement.
Total Mini and BMW, did all my vanos work on my old M3, was gonna have them do my subframe until that car was totalled. Good little indy shop and local to Charleston.
Sent from my SM-G930V using Tapatalk
Jump to top m3az05 is offline   Reply With Quote
Old Thu, Apr-20-2017, 12:51:16 AM   #3
Pirelli Condoms
Will check them out!
― Ayrton Senna
Old Thu, Apr-20-2017, 01:47:54 AM   #4
Fhcrubarb
Fhcrubarb's Avatar
Reputation: 0 Fhcrubarb is on a distinguished road
Is your trunk floor tearing or do you see cracks around the Subframe mounting points?
Jump to top Fhcrubarb is offline   Reply With Quote
Old Thu, Apr-20-2017, 01:50:14 AM   #5
Pirelli Condoms
I think it's mounting points. I have a cage so I know it's not the floor.
― Ayrton Senna
Old Thu, Apr-20-2017, 01:56:02 AM   #6
Fhcrubarb
Fhcrubarb's Avatar
Damn, all that work and you neglected the mounting points? That's usually the first place to go. There's plenty of shops in charlotte that could do it. Good luck
Old Thu, Apr-20-2017, 01:58:27 AM   #7
Pirelli Condoms
Po did turner motorsport plates. Never thought twice about it. I then realized the difference between turners and redish. Ugh this better not be a panel replacement job.
― Ayrton Senna
Old Thu, Apr-20-2017, 02:02:16 AM   #8
Fhcrubarb
Fhcrubarb's Avatar
I've only seen panel replacement from the RACP tearing away from the chassis. Keep us updated please
Old Thu, Apr-20-2017, 02:03:37 AM   #9
Pirelli Condoms
Will do, calling Total bmw and mini tomorrow for an inspection. I'll keep your guys updated.
― Ayrton Senna
Old Thu, Apr-20-2017, 02:37:58 AM   #10
PITT M3 RR
PA
PITT M3 RR's Avatar
So the cage looks to be bolt through to the SF at the rear and front. This is interesting. What's your symptoms and have you confirmed anything?
S54 E36 BUILD
Discussing Charleston Sc subframe reinforcement. in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
