Old Tue, Apr-18-2017, 02:05:36 AM   #1
Bmwpower603
Default Manual transmission fluid
Which to use when changing transmission fluid?
The BMW MTL is no longer available.
Will this work?
MTL 75w 80
https://www.ecstuning.com/b-redline-.../rl-space-mtl/
Also ... will I really need to replace the fill plug? And drain plug?
Old Tue, Apr-18-2017, 11:37:26 AM   #2
Solaris99
Reputation: 0 Solaris99 is on a distinguished road
Default Re: Manual transmission fluid
The Redline MTL is what I use. I've changed the trans fluid a few times and haven't replaced the original plugs.
1999 BMW M3
2009 Chevy Cobalt SS turbocharged coupe
2000 Ford F350 7.3L 4x4
Jump to top Solaris99 is online now   Reply With Quote
Old Tue, Apr-18-2017, 12:16:30 PM   #3
gingerELITE
Reputation: 0 gingerELITE is on a distinguished road
I use Redline MTL as well. Never replaced the plugs either. I'd suggest pulling the fill plug first though. If you pull the drain plug and then for whatever reason you can't get the fill plug out you're SOL. These things almost never get touched and can seize pretty bad.
Summer Daily --- '99 M3 Convertible 5MT
Winter Beater --- '02 VW GTI 1.8t 5MT
Jump to top gingerELITE is offline   Reply With Quote
Old Tue, Apr-18-2017, 01:23:16 PM   #4
mitch500
mitch500's Avatar
Reputation: 0 mitch500 is on a distinguished road
Redline MTL here as well and Original plugs
97 E36 M3 Coupe Alpine white
s54 swap in progress
Jump to top mitch500 is online now   Reply With Quote
Old Tue, Apr-18-2017, 03:03:08 PM   #5
JitteryJoe
Redline MTL is what I use. Buy a gallon and get one of these to make the job easy.
Cheap & effective. Pump is great for diff as well.
Old Tue, Apr-18-2017, 11:55:31 PM   #6
j0rdan J
Reputation: 0 j0rdan J is on a distinguished road
I use Redline Mt90 or Ac-Delco synchromesh with great results.
Jump to top j0rdan J is offline   Reply With Quote
Old Wed, Apr-19-2017, 12:09:23 AM   #7
Matt15
Reputation: 0 Matt15 is on a distinguished road
Redline D4 ATF for me
Jump to top Matt15 is offline   Reply With Quote
Old Wed, Apr-19-2017, 01:39:51 PM   #8
LockDots
LockDots's Avatar
Same for me.
Isn't ATF what's supposed to be used? At least that what the sticker on my transmission says.
Old Wed, Apr-19-2017, 02:19:04 PM   #9
Solaris99
The ATF is fine. If you live in warmer climates or track your car, you might want the MTF. What bothered me most about the ATF was the transmission would leak every time it got under 45 in my garage. Even though that's like 10 days/year.
1999 BMW M3
Old Wed, Apr-19-2017, 03:57:48 PM   #10
Tove
They See Me Rollin'
Tove's Avatar
Reputation: 0 Tove is on a distinguished road
Redline is what my friend uses on his E36.
BMW Enthusiast since 1987 | Tove aka Genuine
Jump to top Tove is offline   Reply With Quote
Discussing Manual transmission fluid in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
