Old Mon, Apr-17-2017, 09:12:08 PM   #1
NSX7
Reputation: 0 NSX7 is on a distinguished road
Default Competition pkg. front brakes
Did anyone track their comp. pkg M3 with the OEM/aftermarket cross drilled rotors and pads.
I can't seem to find other aftermarket options such as Brembo for that car.
I am looking at 4-5 track sessions per year - but I don't want to replace the brakes every year as these are expensive - also when I tracked my S2000 last year, the OEM brakes faded after 2 laps only.
Any help would be appreciated on this subject as I need to change the front brakes ASAP and need to make the right decision.
Jump to top NSX7 is offline   Reply With Quote
Old Mon, Apr-17-2017, 10:05:50 PM   #2
EYEHAVEYOU
likes it raspy
EYEHAVEYOU's Avatar
Default Re: Competition pkg. front brakes
I used the OEM ZCP (comp pkg) rotors and got about 10 days worth of track time on my last car before the stress cracks stretched from hole-to-hole, which is when I've been advised it means it's time to replace (if you're tracking, this will likely occur before they are at min spec). This was with Motul RBF600 fluid, track pads (mostly PFC01s), and Yokohama AD08 tires
Obviously YMMV as there are a lot of variables at play here - the tracks you're on, weight of your car, pad selection, tires, how aggressively you're driving etc.
The bigger pain was that my rubber dust boot would melt/fall apart due to the heat, had to rebuild the calipers one time during that period, and they were probably due for another rebuild by the last day.
Simon
2005 M3 ZCP 6MT - Alpine White /// Imola Red - RIP
Jump to top EYEHAVEYOU is online now   Reply With Quote
Old Mon, Apr-17-2017, 10:39:24 PM   #3
MrCooperS
Reputation: 0 MrCooperS is on a distinguished road
Which aftermarket rotors did you end up with after?
Jump to top MrCooperS is offline   Reply With Quote
Old Mon, Apr-17-2017, 10:44:53 PM   #4
EYEHAVEYOU
likes it raspy
EYEHAVEYOU's Avatar
None, the car was flooded out before I could replace them
My current car has ZCP rotors which I'll be tracking with this season. When it comes time to replace I'll either stay OEM or go full-retard with a BBK.
Simon
Old Tue, Apr-18-2017, 07:13:03 PM   #5
MarcZCP
MarcZCP's Avatar
Reputation: 0 MarcZCP is on a distinguished road
I've done the equivalent of 3 full track days on the rotors that my car came with. The rotors at this point have only minor cracking - I figure I will get about 3 more days before the cracks are spanning adjacent holes at which time I will replace them with new ZCP rotors.
The ZCP brake setup performs ok on track. With stock pads I did get some brake fade so definitely recommend upgraded pads (PFC 08 is what I am running now).
Upgrade options are somewhat limited, but PFC offers direct drive rotors in ZCP size. Comments I've read on this forum indicate that those rotors combined with good pads and upgraded (brass) sliders in the calipers give an excellent braking system for track use. It is not cheap though, and given stock ZCP rotors are good for ~6-10 track days it will take some time to recover the up-front cost of the PFC rotor upgrade.
Also consider that your driving will influence the life of the rotors. If you're hard on the brakes immediately after getting on track you will have more severe thermal shock and the cracking will be worse. If you heat them up gradually over 1 or 2 laps it should help extend the life considerably.
2006 M3 ZCP 6MT Interlagos blue on grey
2008 Mazda3 - Daily driver
2005 Mazda RX8 - Gone but not forgotten
Jump to top MarcZCP is offline   Reply With Quote
Old Wed, Apr-19-2017, 04:56:20 PM   #6
Tove
They See Me Rollin'
Tove's Avatar
Reputation: 0 Tove is on a distinguished road
ZCP might be the best choice.
BMW Enthusiast since 1987 | Tove aka Genuine
Jump to top Tove is offline   Reply With Quote
Old Thu, Apr-20-2017, 12:38:04 AM   #7
M3 dude
there's a crowd in Australia (Harrop) that now make a 2 piece fully floating race disk in the oem csl/zcp size.
unfortunately, there's a dimension issue with their rotors that they reckon it wont fit oem caliper hardware. luckily you can buy their calipers from them.
Old Thu, Apr-20-2017, 04:46:44 PM   #8
Monte0704
Monte0704's Avatar
Reputation: 0 Monte0704 is on a distinguished road
I would stay away from crossdrilled rotors, because they ALL crack.
Blank face rotors are completely acceptable for track use. NASCAR, even on road courses, only use blank rotors, as do many many other motorsports series.
Use high quality track pads (That you change at the track, I may add.... a track pad isn't safe to drive to the track, due to trash performance when cold.) and really good fluid. I like to use RBF600, or even RBF660.
2004 E46 M3 SMG II | 1990 Nissan Skyline GTR
Jump to top Monte0704 is offline   Reply With Quote
Discussing Competition pkg. front brakes in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
