Old Mon, Apr-17-2017, 01:27:29 PM   #1
Lightship
Lightship's Avatar
Reputation: 0 Lightship is on a distinguished road
Default Subframe front mount point problem
Hey guys,
Anyone familiar with subframe/RACP issues know how this might occur?
I have had my RACP sorted, rear bar welded, Redish plates. So far it's been fine. Here is the rear mounts solution which, top and bottom, is so far intact.
I noticed this today at the front mount point, (drivers side US).
No welding work was done on the front mount points other than the Redish plates which are between the subframe and body.
Could the original welds inside the cavity have popped and/or the body torn away or has the rod un-threaded itself? Without cutting into the floor I have no idea what's caused this.
Appreciate your thoughts.
Cheers
2002 . RHD Euro E46 M3 . Avus Blue . 260 style E92 18" wheels . Bilstein B6 . CSL Springs . CSL Sways . CG .
Win at the slowest possible speed!
Journal: http://m3forum.net/m3forum/showthread.php?t=492037
Jump to top Lightship is offline   Reply With Quote
Old Mon, Apr-17-2017, 02:00:40 PM   #2
PITT M3 RR
PA
PITT M3 RR's Avatar
Default Re: Subframe front mount point problem
You'll see once you get in there that the fronts are just as likely as the rear to tear away. Seach vinces thread or some posts he made and youll see the inside of that mount with a cut away from under the reat seats. Once you visualize the issue...youll see many ways to correct it. Personally a reinforced bolt through I think is the only way!
HIS PHOTOS
S54 E36 BUILD
Old Mon, Apr-17-2017, 02:08:21 PM   #3
Lightship
Lightship's Avatar
Thanks man.. I've been perusing those threads and looking at the pics. I'm still uncertain as to what may have happened with mine even after looking at those photos... or perhaps I just don't want to know!
Old Mon, Apr-17-2017, 02:08:26 PM   #4
Pahkthebeemah
Reputation: 0 Pahkthebeemah is on a distinguished road
love this car. hate these threads. look at the vince bar threads!
http://www.m3forum.net/m3forum/showthread.php?t=555302
and I'm sure he'll be popping his head in here soon.
06' VW GTI, Stage II+ (first car, gone)
08' BMW 328xi, Stock (gone)
06' Kawazaki 636 (gone)
12' Jeep Sport (gone)
13' BMW 335i MSport, Stock (gone...regret it)
13' Kia Rio (current daily driver)
03' BMW M3 SMG (pleasure only)
Jump to top Pahkthebeemah is offline   Reply With Quote
Old Mon, Apr-17-2017, 02:24:18 PM   #5
PITT M3 RR
PA
PITT M3 RR's Avatar
If it were me I'd see if it backed out. Have you noticed any driveability issues? Why did you find it? Has anyone worked back there? Are you sure it was threaded fully when reinstalled?
S54 E36 BUILD
Old Mon, Apr-17-2017, 02:47:20 PM   #6
Lightship
Lightship's Avatar
Almost zero driveability issues. I've noticed some slight knocking noise which I solved today (slightly loose camber arm bolt). I was poking around and noticed that gap.
Last thing I did back there was install the diff front bush and above mentioned camber arms, but I didn't notice if that mount had dropped at the time. I don't know how long it's been like that!
Last guys to touch that mount were the guys that did the entire reinforcement job back in 2014.
Old Mon, Apr-17-2017, 02:51:20 PM   #7
schoonerm3
Reputation: 0 schoonerm3 is on a distinguished road
Ireland
It's backed out I'm almost certain of it. There would be major metal chunks if it had ripped fully. You probably have cracks there but i don't think it's ripped out.
I bet what happened was the bolt was torqued against a painted surface or onto seam sealer and sometimes when tightened against fresh paint the bolt isn't as tight was we think. The material under the bolts breaks down and bolts loses the purchase it had originally.
Get it tightened back up but while your there you should fix the broken welds which are inevitable imo and add a through bolt to the front mount.
Jump to top schoonerm3 is offline   Reply With Quote
Old Mon, Apr-17-2017, 02:53:28 PM   #8
PITT M3 RR
PA
PITT M3 RR's Avatar
Could have been that way all along then. I'd see if they cross threaded it or if you can back it out and or in slowly, smoothly.
Up at the plate, can you tell if there are engagement marks from torquing? If the plates were installed and coated then the bolt was threaded in and tightened all the way, there will be the scratches / marks from it touching and rotating. If they're not there, it was never tight.
S54 E36 BUILD
Old Mon, Apr-17-2017, 03:01:39 PM   #9
Lightship
Lightship's Avatar
Thanks for the insight man.. Was starting to think along those lines. Checking out Vince's front bolt solution looks to be the business too!
Old Mon, Apr-17-2017, 03:03:32 PM   #10
Lightship
Lightship's Avatar
Cheers.. checking the marking on the plate is a great suggestion, thanks man, I'll have to check that!
racp, redish, subframe
Discussing Subframe front mount point problem in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
